[SCM] PostGIS branch master updated. 3.6.0rc2-168-g5f1330931
git at osgeo.org
git at osgeo.org
Thu Oct 30 09:48:51 PDT 2025
the project "PostGIS".
via 5f13309312fb79142c5d870828e17455c6f8f93d (commit)
from 8c0a1555e2d7d4234419b3ddb6af7ecaeedc2f82 (commit)
revisions in full, below.
commit 5f13309312fb79142c5d870828e17455c6f8f93d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Oct 30 20:48:35 2025 +0400
Clarify the scope of several Function Reference categories
Closes #4332
diff --git a/NEWS b/NEWS
index eb5464cde..06b41d6f1 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,8 @@ xxxx/xx/xx
- #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
- #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
- #5950, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)
+ - #4332, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)
* Bug Fixes *
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index b75f26317..4cbcd8f74 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -1,6 +1,13 @@
<!-- Converted by db4-upgrade version 1.1 -->
<section xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Geometry_Accessors">
- <title>Geometry Accessors</title>
+ <title>Geometry Accessors</title><info>
+ <abstract>
+ <para>These functions expose structural information about an existing geometry
+ without changing it. They provide access to metadata such as geometry
+ type, dimensionality, or coordinate components so that spatial
+ expressions can interrogate complex objects in a controlled way.</para>
+ </abstract>
+ </info>
<refentry xml:id="GeometryType">
<refnamediv>
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index e849926c5..324424a7b 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1,6 +1,12 @@
<section xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Geometry_Constructors">
- <title>Geometry Constructors</title>
+ <title>Geometry Constructors</title><info>
+ <abstract>
+ <para>These functions instantiate new geometry or geography values. They
+ assemble primitives, coordinate sequences, or existing geometries into
+ well-formed spatial objects that can participate in subsequent analysis.</para>
+ </abstract>
+ </info>
<refentry xml:id="ST_Collect">
<refnamediv>
diff --git a/doc/reference_exception.xml b/doc/reference_exception.xml
index 51c3301b7..79155219a 100644
--- a/doc/reference_exception.xml
+++ b/doc/reference_exception.xml
@@ -1,8 +1,12 @@
<section xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Exceptional_Functions">
- <title>Exceptional Functions</title>
- <para>These functions are rarely used functions that should only be used if your data is corrupted in someway. They are used for troubleshooting corruption
- and also fixing things that should under normal circumstances, never happen.</para>
+ <title>Exceptional Functions</title><info>
+ <abstract>
+ <para>These routines are reserved for diagnosing and repairing data
+ corruption. They provide last-resort maintenance operations that are not
+ required during normal spatial workflows.</para>
+ </abstract>
+ </info>
<refentry xml:id="PostGIS_AddBBox">
<refnamediv>
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 46ceb15ed..570d4daea 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -1,6 +1,13 @@
<section xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Linear_Referencing">
- <title>Linear Referencing</title>
+ <title>Linear Referencing</title><info>
+ <abstract>
+ <para>These functions measure and locate events along linear features.
+ They support the classic linear referencing workflow of expressing
+ positions as fractions or measures along routes and of projecting
+ those measures back into spatial coordinates.</para>
+ </abstract>
+ </info>
<refentry xml:id="ST_LineInterpolatePoint">
<refnamediv>
diff --git a/doc/reference_operator.xml b/doc/reference_operator.xml
index 00e219685..8f1bf8655 100644
--- a/doc/reference_operator.xml
+++ b/doc/reference_operator.xml
@@ -1,6 +1,15 @@
<section xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Operators">
- <title>Operators</title>
+ <title>Operators</title><info>
+ <abstract>
+ <para>These entries document the spatial operators defined by PostGIS.
+ Operators complement the function catalogue by supplying concise
+ symbolic predicates for bounding-box interactions and spatial
+ relationships. Their semantics follow the same geometric rules as the
+ corresponding functions but are optimised for use in SQL expressions
+ and index-supported filtering.</para>
+ </abstract>
+ </info>
<section xml:id="operators-bbox">
<title>Bounding Box Operators</title>
Summary of changes:
NEWS | 2 ++
doc/reference_accessor.xml | 9 ++++++++-
doc/reference_constructor.xml | 8 +++++++-
doc/reference_exception.xml | 10 +++++++---
doc/reference_lrs.xml | 9 ++++++++-
doc/reference_operator.xml | 11 ++++++++++-
6 files changed, 42 insertions(+), 7 deletions(-)
hooks/post-receive
