[SCM] PostGIS branch master updated. 3.6.0rc2-169-gcf5994644
git at osgeo.org
git at osgeo.org
Thu Oct 30 10:21:17 PDT 2025
the project "PostGIS".
via cf5994644e5233da594c17bc3b4fd49a780e72ff (commit)
from 5f13309312fb79142c5d870828e17455c6f8f93d (commit)
revisions in full, below.
commit cf5994644e5233da594c17bc3b4fd49a780e72ff
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Oct 30 21:21:02 2025 +0400
[raster] ST_DumpAsPolygons honours PostgreSQL interrupts
Closes #4222
diff --git a/NEWS b/NEWS
index 06b41d6f1..0c485943c 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,7 @@ xxxx/xx/xx
- #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
- #5950, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)
- #4332, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)
+ - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
* Bug Fixes *
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index cd7ab9b8f..10559043e 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -14169,6 +14169,7 @@ FROM (SELECT ST_SetRotation(rast, 0.1, 0.1) As rast
can be used to expand a single raster into multiple POLYGONS/MULTIPOLYGONS.</para>
<para>Changed 3.3.0, validation and fixing is disabled to improve performance. May result invalid geometries.</para>
+ <para>Changed 3.7.0, the polygonization honours PostgreSQL interrupts so cancellations and statement timeouts halt processing promptly.</para>
<para role="availability" conformance="1.7">Availability: Requires GDAL 1.7 or higher.</para>
<note><para>If there is a no data value set for a band, pixels with that value will not be returned except in the case of exclude_nodata_value=false.</para></note>
<note><para>If you only care about count of pixels with a given value in a raster, it is faster to use <xref linkend="RT_ST_ValueCount"/>.</para></note>
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index b4395ba2b..ded95f1c9 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -2373,6 +2373,9 @@ rt_util_gdal_register_all(int force_register_all);
int
rt_util_gdal_driver_registered(const char *drv);
+int
+rt_util_gdal_progress_func(double dfComplete, const char *pszMessage, void *pProgressArg);
wrapper for GDALOpen and GDALOpenShared
diff --git a/raster/rt_core/rt_gdal.c b/raster/rt_core/rt_gdal.c
index 748a8ff12..ff01c1d66 100644
--- a/raster/rt_core/rt_gdal.c
+++ b/raster/rt_core/rt_gdal.c
@@ -4,6 +4,7 @@
* http://trac.osgeo.org/postgis/wiki/WKTRaster
* Copyright (C) 2021 Paul Ramsey <pramsey at cleverelephant.ca>
+ * Copyright (C) 2025 Darafei Praliaskouski <me at komzpa.net>
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
@@ -55,10 +56,14 @@ typedef struct
/* GDAL progress callback for interrupt handling */
-static int rt_util_gdal_progress_func(
- double dfComplete,
- const char *pszMessage,
- void *pProgressArg)
+ * WHY: We surface a single callback so every GDAL routine invoked from the
+ * raster core can honour PostgreSQL cancellations consistently. Returning
+ * FALSE forces the GDAL algorithm to unwind immediately when liblwgeom has
+ * recorded an interrupt request (#4222).
+int
(void)dfComplete;
(void)pszMessage;
@@ -66,7 +71,7 @@ static int rt_util_gdal_progress_func(
if (_lwgeom_interrupt_requested)
// rtwarn("%s interrupted at %g", (const char*)pProgressArg, dfComplete);
- _lwgeom_interrupt_requested = 0;
+ lwgeom_cancel_interrupt();
return FALSE;
else
diff --git a/raster/rt_core/rt_geometry.c b/raster/rt_core/rt_geometry.c
index 7c997d44f..2c126f4b8 100644
--- a/raster/rt_core/rt_geometry.c
+++ b/raster/rt_core/rt_geometry.c
@@ -10,6 +10,7 @@
* Copyright (C) 2009-2011 Pierre Racine <pierre.racine at sbf.ulaval.ca>
* Copyright (C) 2009-2011 Mateusz Loskot <mateusz at loskot.net>
* Copyright (C) 2008-2009 Sandro Santilli <strk at kbt.io>
@@ -1136,8 +1137,12 @@ rt_raster_gdal_polygonize(
return NULL;
- /* We don't need a raster mask band. Each band has a nodata value. */
- cplerr = GDALFPolygonize(gdal_band, NULL, hLayer, iPixVal, NULL, NULL, NULL);
+ * Why: We pass the shared interrupt-aware progress callback so GDAL can
+ * unwind promptly when PostgreSQL requests cancellation (#4222).
+ cplerr = GDALFPolygonize(
+ gdal_band, NULL, hLayer, iPixVal, NULL, rt_util_gdal_progress_func, (void *)"GDALFPolygonize");
if (cplerr != CE_None) {
rterror("rt_raster_gdal_polygonize: Could not polygonize GDAL band");
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index 421bf93f3..aa53fe268 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -4,6 +4,7 @@
* Copyright (C) 2012 Regents of the University of California
* <bkpark at ucdavis.edu>
@@ -277,6 +278,29 @@ static void test_gdal_polygonize() {
cu_free_raster(rt);
+static void
+test_gdal_polygonize_interrupt(void)
+ rt_raster rt;
+ int nPols = 0;
+ rt_geomval gv = NULL;
+ rt = fillRasterToPolygonize(0, 0.0);
+ CU_ASSERT(rt != NULL);
+ /* Why: confirm that the GDAL callback honours liblwgeom interrupts (#4222). */
+ lwgeom_request_interrupt();
+ gv = rt_raster_gdal_polygonize(rt, 0, TRUE, &nPols);
+ CU_ASSERT_PTR_NULL(gv);
+ CU_ASSERT_EQUAL(nPols, 0);
+ if (gv)
+ rtdealloc(gv);
+ cu_free_raster(rt);
static void test_raster_to_gdal() {
rt_pixtype pixtype = PT_64BF;
rt_raster raster = NULL;
@@ -608,6 +632,7 @@ void gdal_suite_setup(void)
PG_ADD_TEST(suite, test_gdal_drivers);
PG_ADD_TEST(suite, test_gdal_rasterize);
PG_ADD_TEST(suite, test_gdal_polygonize);
+ PG_ADD_TEST(suite, test_gdal_polygonize_interrupt);
PG_ADD_TEST(suite, test_raster_to_gdal);
PG_ADD_TEST(suite, test_gdal_to_raster);
PG_ADD_TEST(suite, test_gdal_warp);
Summary of changes:
NEWS | 1 +
doc/reference_raster.xml | 1 +
raster/rt_core/librtcore.h | 3 +++
raster/rt_core/rt_gdal.c | 15 ++++++++++-----
raster/rt_core/rt_geometry.c | 9 +++++++--
raster/test/cunit/cu_gdal.c | 25 +++++++++++++++++++++++++
6 files changed, 47 insertions(+), 7 deletions(-)
hooks/post-receive
