[SCM] PostGIS branch master updated. 3.6.0rc2-173-gd19e312fc
git at osgeo.org
git at osgeo.org
Thu Oct 30 12:52:18 PDT 2025
the project "PostGIS".
via d19e312fccf56ee6b50e1e90f1dfeffadb0eb336 (commit)
from a474eff150abde9c83b0385cac88cb529779f705 (commit)
revisions in full, below.
commit d19e312fccf56ee6b50e1e90f1dfeffadb0eb336
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Oct 30 23:46:20 2025 +0400
[doc] Clean up mentions of legacy software versions
diff --git a/doc/administration.xml b/doc/administration.xml
index da9f063f4..9756f184b 100644
--- a/doc/administration.xml
+++ b/doc/administration.xml
@@ -384,7 +384,5 @@ ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));
</section>
</section>
+ </section>
</chapter>
diff --git a/doc/extras_tigergeocoder.xml b/doc/extras_tigergeocoder.xml
index 92005387e..ffacaeaf3 100644
--- a/doc/extras_tigergeocoder.xml
+++ b/doc/extras_tigergeocoder.xml
@@ -20,14 +20,14 @@
<para> <note><para>
-If you are using tiger geocoder (tiger_2010),
+If you are using the TIGER Geocoder (tiger_2010),
you can upgrade the scripts using the accompanying upgrade_geocoder.bat
/ .sh scripts in extras/tiger. One major change between <varname>tiger_2010</varname> and <varname>tiger_2011+</varname> is that the <varname>county</varname> and <varname>state</varname> tables are no longer broken out by state. If you have data from tiger_2010 and want to replace with tiger_2015, refer to <xref linkend="upgrade_tiger_geocoder"/>
</para></note>
<note>
- <para>New in PostGIS 2.2.0 release is support for Tiger 2015 data and inclusion of Address Standardizer as part of PostGIS.</para>
- <para>New in PostGIS 2.1.0 release is ability to install tiger geocoder with PostgreSQL extension model if you are running PostgreSQL 9.1+. Refer to <xref linkend="install_tiger_geocoder_extension"/> for details.</para></note>
+ <para>New in PostGIS 2.2.0 release is support for TIGER 2015 data and inclusion of Address Standardizer as part of PostGIS.</para>
+ <para>New in PostGIS 2.1.0 release is ability to install the TIGER Geocoder with the PostgreSQL extension model. Refer to <xref linkend="install_tiger_geocoder_extension"/> for details.</para></note>
</para>
<para>The <xref linkend="Pagc_Normalize_Address"/> function as a drop in replacement for in-built <xref linkend="Normalize_Address"/>. Refer to <xref linkend="installing_pagc_address_standardizer"/> for compile and installation instructions.</para>
@@ -48,11 +48,11 @@ you can upgrade the scripts using the accompanying upgrade_geocoder.bat
</info>
- <para>There are a couple other open source geocoders for PostGIS, that unlike tiger geocoder have the advantage of multi-country geocoding support</para>
+ <para>There are a couple other open source geocoders for PostGIS, that unlike the TIGER Geocoder have the advantage of multi-country geocoding support</para>
<itemizedlist>
<listitem><para><link xlink:href="http://wiki.openstreetmap.org/wiki/Nominatim">Nominatim</link>
uses OpenStreetMap gazeteer formatted data. It requires osm2pgsql for loading the data together with PostgreSQL and PostGIS. It is packaged as a webservice interface and seems designed to be called as a webservice.
- Just like the tiger geocoder, it has both a geocoder and a reverse geocoder component. From the documentation, it is unclear if it has a pure SQL interface like the tiger geocoder, or if a good deal of the logic is implemented in the web interface.</para></listitem>
+ Just like the TIGER Geocoder, it has both a geocoder and a reverse geocoder component. From the documentation, it is unclear if it has a pure SQL interface like the TIGER Geocoder, or if a good deal of the logic is implemented in the web interface.</para></listitem>
<listitem><para><link xlink:href="http://www.gisgraphy.com/">GIS Graphy</link> also utilizes PostGIS and like Nominatim works with OpenStreetMap (OSM) data. It comes with a loader to load OSM data and similar to Nominatim is capable of geocoding not just US. Much like Nominatim, it runs as a webservice and relies on Java 1.5, Servlet apps, Solr. GisGraphy is cross-platform and also has a reverse geocoder among some other neat features.</para></listitem>
</itemizedlist>
@@ -632,7 +632,7 @@ tract_id
</listitem>
</orderedlist>
<para role="availability" conformance="2.0.0">Availability: 2.0.0 </para>
- <note><para><xref linkend="Loader_Generate_Script"/> includes this logic, but if you installed the tiger geocoder with older scripts, rerun it on the states you have already processed
+ <note><para><xref linkend="Loader_Generate_Script"/> includes this logic, but if you installed the TIGER Geocoder with older scripts, rerun it on the states you have already processed
to get these additional tables.</para></note>
</refsection>
@@ -646,7 +646,7 @@ set STATEDIR="\gisdata\www2.census.gov\geo\pvs\tiger2010st\25_Massachusetts"
set TMPDIR=\gisdata\temp\
set UNZIPTOOL="C:\Program Files\7-Zip\7z.exe"
set WGETTOOL="C:\wget\wget.exe"
-set PGBIN=C:\projects\pg\pg<version>win\bin\
+set PGBIN=C:\projects\pg\pg[version]win\bin\
set PGPORT=5432
set PGHOST=localhost
set PGUSER=postgres
@@ -675,7 +675,7 @@ cd %TMPDIR%
TMPDIR="/gisdata/temp/"
UNZIPTOOL=unzip
WGETTOOL="/usr/bin/wget"
-export PGBIN=/usr/pgsql-<version>/bin
+export PGBIN=/usr/pgsql-[version]/bin
export PGPORT=5432
export PGHOST=localhost
export PGUSER=postgres
@@ -759,7 +759,7 @@ for z in *.zip; do $UNZIPTOOL -o -d $TMPDIR $z; done
-set PGBIN=C:\Program Files\PostgreSQL\<version>\bin\
+set PGBIN=C:\Program Files\PostgreSQL\[version]\bin\
set PGPORT=5432
set PGUSER=postgres
@@ -780,7 +780,7 @@ cd \gisdata/ftp2.census.gov/geo/tiger/TIGER2015/PLACE
UNZIPTOOL=unzip
-export PGBIN=/usr/lib/postgresql/<version>/bin
+export PGBIN=/usr/lib/postgresql/[version]/bin
-- variables used by psql: https://www.postgresql.org/docs/current/static/libpq-envars.html
export PGPORT=5432
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index 62ce603dc..c6a264d30 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -1076,8 +1076,8 @@ ST_GeogFromWKB(E'\\001\\002\\000\\000\\000\\002\\000\\000\\000\\037\\205\\353Q\\
\\312Q\\300\\366{b\\235*!E@\\225|\\354.P\\312Q
\\300p\\231\\323e1!E@');</programlisting>
- <note><para>In PostgreSQL 9.1+ - standard_conforming_strings is set to on by default, where as in past versions it was set to off. You can change defaults as needed
- for a single query or at the database or server level. Below is how you would do it with standard_conforming_strings = on. In this case we escape the ' with standard ansi ',
+ <note><para>In PostgreSQL, standard_conforming_strings is set to on by default. You can change the default as needed
+ for a single query or at the database or server level. Below is how you would do it with standard_conforming_strings = on. In this case we escape the ' with standard ANSI ',
but slashes are not escaped</para></note>
<programlisting>
set standard_conforming_strings = on;
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 4e15fd519..d50c5758c 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -1012,7 +1012,7 @@ SELECT DISTINCT ON (buildings.gid) buildings.gid, parcels.parcel_id
The units of length is determined by the
spatial reference system of the geometry.</para>
<para>For geography types: computation is performed using the inverse geodesic calculation. Units of length are in meters.
- If PostGIS is compiled with PROJ version 4.8.0 or later, the spheroid is specified by the SRID, otherwise it is exclusive to WGS84.
+ The spheroid is specified by the SRID; when no SRID is provided, WGS84 is used.
If <varname>use_spheroid = false</varname>, then the calculation is based on a sphere instead of a spheroid.
</para>
@@ -1722,7 +1722,7 @@ LINESTRING(0.5 0.00032,0.5 0)
non-areal geometries. For linear geometries use <xref linkend="ST_Length"/>. For geometry types, units for perimeter measures are specified by the
<para>For geography types, the calculations are performed using the inverse geodesic problem, where perimeter units are in meters.
If <varname>use_spheroid = false</varname>, then calculations will approximate a sphere instead of a spheroid.</para>
<para>Currently this is an alias for ST_Perimeter2D, but this may change to support higher dimensions.</para>
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 79d82cec2..dc1e99c9b 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -14181,7 +14181,7 @@ FROM (SELECT ST_SetRotation(rast, 0.1, 0.1) As rast
<refsection>
<title>Examples</title>
- <programlisting> -- this syntax requires PostgreSQL 9.3+
+ <programlisting> -- this syntax uses a LATERAL join
SELECT val, ST_AsText(geom) As geomwkt
FROM (
SELECT dp.*
diff --git a/extensions/README b/extensions/README
index 7f941b69d..16729759e 100644
--- a/extensions/README
+++ b/extensions/README
@@ -1,16 +1,11 @@
PostGIS Extension for PostgreSQL
-PostgreSQL 9.6 (and up) supports PostGIS extensions. A database can easily be
-extended to use PostGIS using the syntax::
+A database can easily be extended to use PostGIS using the syntax::
CREATE EXTENSION postgis; -- Includes raster
CREATE EXTENSION postgis_topology; -- Depends on postgis
-Requirements
- * PostgreSQL 9.6 or later
Building and installing
First, make sure you follow the regular configuration and installation steps,
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 3ac5a3567..06224676f 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -1077,8 +1077,8 @@ Datum gserialized_gist_consistent_2d(PG_FUNCTION_ARGS)
bool result;
BOX2DF query_gbox_index;
- /* PostgreSQL 8.4 and later require the RECHECK flag to be set here,
- rather than being supplied as part of the operator class definition */
+ /* PostgreSQL requires the RECHECK flag to be set here,
+ rather than being supplied as part of the operator class definition */
bool *recheck = (bool *) PG_GETARG_POINTER(4);
/* We set recheck to false to avoid repeatedly pulling every "possibly matched" geometry
diff --git a/postgis/gserialized_gist_nd.c b/postgis/gserialized_gist_nd.c
index 8fe07b0ea..a6e44da63 100644
--- a/postgis/gserialized_gist_nd.c
+++ b/postgis/gserialized_gist_nd.c
@@ -1087,8 +1087,8 @@ Datum gserialized_gist_consistent(PG_FUNCTION_ARGS)
char gidxmem[GIDX_MAX_SIZE];
GIDX *query_gbox_index = (GIDX *)gidxmem;
bool *recheck = (bool *)PG_GETARG_POINTER(4);
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index b07ad9343..308297fa7 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -332,7 +332,7 @@ static uint32 gserialized_typmod_in(ArrayType *arr, int is_geography)
** geography_typmod_in(cstring[]) returns int32
-** Modified from ArrayGetIntegerTypmods in PostgreSQL 8.3
+** Modified from ArrayGetIntegerTypmods in PostgreSQL
PG_FUNCTION_INFO_V1(geography_typmod_in);
Datum geography_typmod_in(PG_FUNCTION_ARGS)
@@ -349,7 +349,7 @@ Datum geography_typmod_in(PG_FUNCTION_ARGS)
** geometry_typmod_in(cstring[]) returns int32
PG_FUNCTION_INFO_V1(geometry_typmod_in);
Datum geometry_typmod_in(PG_FUNCTION_ARGS)
diff --git a/postgis/lwgeom_box3d.c b/postgis/lwgeom_box3d.c
index 11ba71483..1fbde98e2 100644
--- a/postgis/lwgeom_box3d.c
+++ b/postgis/lwgeom_box3d.c
@@ -631,7 +631,7 @@ Datum BOX3D_construct(PG_FUNCTION_ARGS)
PG_RETURN_POINTER(result);
-/** needed for sp-gist support PostgreSQL 11+ **/
+/** Needed for SP-GiST support. **/
* BOX3D functions
diff --git a/postgis/lwgeom_box3d.h b/postgis/lwgeom_box3d.h
index 80107977e..39ec10f3a 100644
--- a/postgis/lwgeom_box3d.h
+++ b/postgis/lwgeom_box3d.h
@@ -63,7 +63,7 @@ bool BOX3D_back_internal(BOX3D *box1, BOX3D *box2);
bool BOX3D_overback_internal(BOX3D *box1, BOX3D *box2);
double BOX3D_distance_internal(BOX3D *box1, BOX3D *box2);
Datum BOX3D_contains(PG_FUNCTION_ARGS);
Datum BOX3D_contained(PG_FUNCTION_ARGS);
Datum BOX3D_overlaps(PG_FUNCTION_ARGS);
Summary of changes:
doc/administration.xml | 4 +---
doc/extras_tigergeocoder.xml | 20 ++++++++++----------
doc/reference_input.xml | 4 ++--
doc/reference_measure.xml | 4 ++--
doc/reference_raster.xml | 2 +-
extensions/README | 7 +------
postgis/gserialized_gist_2d.c | 4 ++--
postgis/gserialized_gist_nd.c | 4 ++--
postgis/gserialized_typmod.c | 4 ++--
postgis/lwgeom_box3d.c | 2 +-
postgis/lwgeom_box3d.h | 2 +-
11 files changed, 25 insertions(+), 32 deletions(-)
hooks/post-receive
