[PostGIS] #5984: PostGIS selectivity is screwing up queries and forcing it to choose a spatial index when it's inappropriate
trac at osgeo.org
Fri Oct 31 12:58:23 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Okay that fixed the stats:
After I ran
ALTER EXTENSION postgis UPDATE; -- which brought me from 3.6.0 to 3.7.0dev
master
analyze nodes;
SELECT _postgis_stats('nodes', 'geom','2') ;
Now returns:
{"ndims":2,"size":[97,102],"extent":{"min":[3.2287,50.7289],"max":[7.23561,53.513]},"table_features":133426320,"sample_features":30000,"not_null_features":30000,"histogram_features":30000,"histogram_cells":9894,"cells_covered":30000}
before it was giving me garbage numbers.
SELECT _postgis_selectivity ('nodes', 'geom',
ST_GeomFromEWKT('SRID=4326;POLYGON((6.11982 52.6121955,6.11982
53.2038323,7.0927397 53.2038323,7.0927397 52.6121955,6.11982
52.6121955))'), '2');
Now instead of 0 gives the expected:
0.07097181809551475
and
EXPLAIN ANALYZE SELECT n.id FROM nodes AS n
WHERE n.id = 8646506472 AND
ST_Intersects(ST_GeomFromEWKT('SRID=4326;POLYGON((6.1198199
52.612195500000006,6.1198199 53.2038323,7.0927397 53.2038323,7.0927397
52.612195500000006,6.1198199 52.612195500000006))'), n.geom);
Is now no longer trying to use the spatial index:
Index Scan using pk_nodes on nodes n (cost=0.57..21.08 rows=1 width=8)
(actual time=71.461..71.461 rows=0 loops=1)
Index Cond: (id = '8646506472'::bigint)
Filter:
st_intersects('0103000020E61000000100000005000000D5A35F11B27A184013A1116C5C4E4A40D5A35F11B27A18402A2F432D179A4A40D529EA27F75E1C402A2F432D179A4A40D529EA27F75E1C4013A1116C5C4E4A40D5A35F11B27A184013A1116C5C4E4A40'::geometry,
geom)
Rows Removed by Filter: 1
Planning Time: 30.506 ms
Execution Time: 71.571 ms
I'll do another test before and after to confirm it is all working, but I
think you fixed it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5984#comment:16>
