[PostGIS] #5832: Intersection test error with curved polygons
trac at osgeo.org
Fri Oct 31 17:16:04 PDT 2025
Reporter: aaime | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by pramsey):
Erm, yeah, kind of scary. Right now all curves are stroked on the postgis
side and then handed over to GEOS as linear geometries, and that's true
for all functions, so the stroking is all nice and centralized (if curved
then stroke()). However, if we are going to start to have partial support
for curves on GEOS, that implies either (a) making sure all GEOS use cases
do stroking on curves or (b) selectively stroking on the postgis side.
But yeah, probably needs to be done, to make the "move to curve" more
real.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5832#comment:6>
