[SCM] PostGIS branch stable-3.6 updated. 3.6.0rc2-9-g4c1967d95
git at osgeo.org
git at osgeo.org
Mon Sep 1 18:18:36 PDT 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
via 4c1967d95be2e1a473f638eb5fe6d7a6a1e1b842 (commit)
via 0f36a0223098993d9a0e43a945b7abf614e7873e (commit)
from beef19480e0e7588f8c4e8337872ef61bcd30e34 (commit)
revisions in full, below.
commit 4c1967d95be2e1a473f638eb5fe6d7a6a1e1b842
Author: Regina Obe <lr at pcorp.us>
Date: Mon Sep 1 18:57:41 2025 -0400
Prep for PostGIS 3.6.0 release
diff --git a/NEWS b/NEWS
index d2fcad843..7435a37ec 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
PostGIS 3.6.0
-2025/09/xx
+2025/09/01
This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.14+ is needed.
diff --git a/Version.config b/Version.config
index cf6d63e9f..272078014 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index f750b9637..68fa8bc79 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -5,7 +5,7 @@
<section>
<title>PostGIS 3.6.0</title>
<para>2025/09/01</para>
- <para>This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
+ <para>This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.</para>
commit 0f36a0223098993d9a0e43a945b7abf614e7873e
Date: Mon Sep 1 18:33:00 2025 -0400
Note that GEOS 3.14 is required to take advantage of all features
diff --git a/configure.ac b/configure.ac
index 61ab6bbf2..dbd4f59c3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -2058,12 +2058,12 @@ AC_MSG_RESULT([ dblatex: ${DBLATEX}])
AC_MSG_RESULT([ convert: ${CONVERT}])
AC_MSG_RESULT()
-if test "$POSTGIS_GEOS_VERSION" -lt 31200; then
+if test "$POSTGIS_GEOS_VERSION" -lt 31400; then
AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
AC_MSG_WARN([ You are building against GEOS ${GEOS_VERSION}.])
AC_MSG_WARN([])
AC_MSG_WARN([ To take advantage of _all_ the features of ])
-AC_MSG_WARN([ PostGIS, GEOS 3.12.0 or higher is required.])
+AC_MSG_WARN([ PostGIS, GEOS 3.14.0 or higher is required.])
AC_MSG_WARN([])
AC_MSG_WARN([ You can download the latest versions from ])
AC_MSG_WARN([ http://geos.osgeo.org/ ])
Summary of changes:
NEWS | 2 +-
Version.config | 2 +-
configure.ac | 4 ++--
doc/release_notes.xml | 2 +-
4 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
