[SCM] PostGIS branch master updated. 3.6.0rc2-24-g53acdc0c7
git at osgeo.org
git at osgeo.org
Thu Sep 4 15:19:41 PDT 2025
the project "PostGIS".
via 53acdc0c7f718518b3c0966d4fa1a792ca4e18cf (commit)
via c21377c8111c55afc0df62d03a8877e7ad38e4df (commit)
from 4a04d921c5fb3f0d659b3cac53979706a86e73ea (commit)
revisions in full, below.
commit 53acdc0c7f718518b3c0966d4fa1a792ca4e18cf
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Thu Sep 4 22:19:27 2025 +0000
Translated PostGIS Manual using Weblate (Spanish)
Currently translated at 20.6% (1207 of 5857 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/es/
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 22610f07b..f919f492c 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-08-21 03:28+0000\n"
"PO-Revision-Date: 2025-09-04 22:19+0000\n"
-"Last-Translator: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/es/>\n"
"Language: es\n"
@@ -64,7 +64,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "If you want to enable offline raster:"
-msgstr ""
+msgstr "Si desea activar la trama sin conexión:"
#. Tag: para
#, no-c-format
commit c21377c8111c55afc0df62d03a8877e7ad38e4df
Author: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>
Date: Thu Sep 4 22:19:10 2025 +0000
index 9c09601be..22610f07b 100644
@@ -2,13 +2,14 @@
# Automatically generated, 2023.
# DeepL <noreply-mt-deepl at weblate.org>, 2025.
+# Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>, 2025.
msgid ""
msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"Last-Translator: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>\n"
"Language: es\n"
@@ -52,10 +53,10 @@ msgid ""
"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
"corresponding <xref linkend=\"PostGIS_GUC\"/>."
msgstr ""
-"A partir de PostGIS 2.1.3, los raster fuera de base de datos y todos los "
-"controladores raster están desactivados por defecto. Para volver a "
-"habilitarlos, es necesario establecer las siguientes variables de entorno "
-"<varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> y "
+"A partir de PostGIS 2.1.3, los raster fuera de la base de datos y todos los "
+"controladores raster están desactivados de manera predeterminada. Para "
+"volver a habilitarlos, es necesario establecer las siguientes variables de "
+"entorno <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> y "
"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> en el entorno del servidor. "
"Para PostGIS 2.2, puede utilizar el enfoque más multiplataforma de "
"establecer las correspondientes <xref linkend=\"PostGIS_GUC\"/>."
Summary of changes:
doc/po/es/postgis-manual.po | 11 ++++++-----
1 file changed, 6 insertions(+), 5 deletions(-)
hooks/post-receive
