[SCM] PostGIS branch master updated. 3.6.0rc2-22-g4a04d921c
git at osgeo.org
git at osgeo.org
Thu Sep 4 15:19:23 PDT 2025
the project "PostGIS".
via 4a04d921c5fb3f0d659b3cac53979706a86e73ea (commit)
from 799c1d873c39a3ae9c475c24e9dfeda6078aa956 (commit)
revisions in full, below.
commit 4a04d921c5fb3f0d659b3cac53979706a86e73ea
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Thu Sep 4 22:17:48 2025 +0000
Translated PostGIS Manual using Weblate (Spanish)
Currently translated at 20.5% (1206 of 5857 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/es/
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index f18e0e63a..9c09601be 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -1,26 +1,27 @@
# Spanish translations for postgis package.
# Automatically generated, 2023.
+# DeepL <noreply-mt-deepl at weblate.org>, 2025.
msgid ""
msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-08-21 03:28+0000\n"
-"PO-Revision-Date: 2023-09-22 19:23+0000\n"
-"Last-Translator: Anonymous <noreply at weblate.org>\n"
-"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/es/>\n"
+"PO-Revision-Date: 2025-09-04 22:19+0000\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/es/>\n"
"Language: es\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 5.0\n"
+"X-Generator: Weblate 5.4.3\n"
#. Tag: chapter
#, no-c-format
msgid "&database_tuning;"
-msgstr ""
+msgstr "&database_tuning;"
#. Tag: title
#, no-c-format
@@ -30,7 +31,7 @@ msgstr "Administración de PostGIS"
#. Tag: title
#, no-c-format
msgid "Configuring raster support"
-msgstr ""
+msgstr "Configuración del soporte raster"
#. Tag: para
#, no-c-format
@@ -38,6 +39,8 @@ msgid ""
"If you enabled raster support you may want to read below how to properly "
"configure it."
msgstr ""
+"Si ha activado el soporte raster, le recomendamos que lea a continuación "
+"cómo configurarlo correctamente."
#. Tag: para
#, no-c-format
@@ -49,6 +52,13 @@ msgid ""
"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
"corresponding <xref linkend=\"PostGIS_GUC\"/>."
msgstr ""
+"A partir de PostGIS 2.1.3, los raster fuera de base de datos y todos los "
+"controladores raster están desactivados por defecto. Para volver a "
+"habilitarlos, es necesario establecer las siguientes variables de entorno "
+"<varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> y "
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> en el entorno del servidor. "
+"Para PostGIS 2.2, puede utilizar el enfoque más multiplataforma de "
+"establecer las correspondientes <xref linkend=\"PostGIS_GUC\"/>."
#. Tag: para
#, no-c-format
@@ -7250,6 +7260,10 @@ msgid ""
"<link xlink:href=\"https://github.com/json-c/json-c/releases\">https://"
"github.com/json-c/json-c/releases/</link>."
msgstr ""
+"JSON-C, versión 0.9 o superior. JSON-C se utiliza actualmente para importar "
+"GeoJSON a través de la función ST_GeomFromGeoJson. JSON-C puede descargarse "
+"de <link xlink:href=\"https://github.com/json-c/json-c/releases\""
+">https://github.com/json-c/json-c/releases/</link>."
#. Tag: para
#, no-c-format
@@ -7258,6 +7272,9 @@ msgid ""
"xlink:href=\"https://gdal.org/download.html\">https://gdal.org/download."
"html</link>."
msgstr ""
+"Se prefiere GDAL, versión 3+. Esto es necesario para el soporte raster. "
+"<link xlink:href=\"https://gdal.org/download.html\">https://gdal.org/download"
+".html</link>."
#. Tag: para
#, no-c-format
@@ -7266,6 +7283,9 @@ msgid ""
"xlink:href=\"https://trac.osgeo.org/postgis/ticket/4125\">https://trac.osgeo."
"org/postgis/ticket/4125</link>."
msgstr ""
+"Si se compila con PostgreSQL+JIT, se requiere la versión >=6 de LLVM "
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4125\">https://trac."
+"osgeo.org/postgis/ticket/4125</link>."
#. Tag: emphasis
#, no-c-format
@@ -7279,6 +7299,9 @@ msgid ""
"Also make sure to enable the drivers you want to use as described in <xref "
"linkend=\"raster_configuration\"/>."
msgstr ""
+"GDAL (pseudo opcional) solo si no quieres raster puedes dejarlo fuera. "
+"También asegúrese de habilitar los controladores que desea utilizar como se "
+"describe en <xref linkend=\"raster_configuration\"/>."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/es/postgis-manual.po | 37 ++++++++++++++++++++++++++++++-------
1 file changed, 30 insertions(+), 7 deletions(-)
hooks/post-receive
