[SCM] PostGIS branch master updated. 3.6.0rc2-28-g533e1cb0b
git at osgeo.org
git at osgeo.org
Thu Sep 4 15:22:11 PDT 2025
the project "PostGIS".
via 533e1cb0b610826343812e0fbe80feb746b88968 (commit)
via b464de5e34637eec92d1f8ac9ff66764c3744048 (commit)
from 412cddc5f201db8c1b0adb2bce0c44f3216f8b9c (commit)
revisions in full, below.
commit 533e1cb0b610826343812e0fbe80feb746b88968
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Thu Sep 4 22:20:43 2025 +0000
Translated PostGIS Manual using Weblate (Spanish)
Currently translated at 20.6% (1212 of 5857 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/es/
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 2c90450de..478a27815 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-08-21 03:28+0000\n"
"PO-Revision-Date: 2025-09-04 22:22+0000\n"
-"Last-Translator: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/es/>\n"
"Language: es\n"
@@ -79,6 +79,8 @@ msgid ""
"In order to enable all GDAL drivers available in your GDAL install, set this "
"environment variable as follows"
msgstr ""
+"Para habilitar todos los controladores de GDAL disponibles en su instalación "
+"de GDAL, configure esta variable de entorno del siguiente modo"
#. Tag: para
#, no-c-format
@@ -86,11 +88,13 @@ msgid ""
"If you want to only enable specific drivers, set your environment variable "
"as follows:"
msgstr ""
+"Si sólo desea habilitar controladores específicos, configure su variable de "
+"entorno de la siguiente manera:"
#. Tag: para
#, no-c-format
msgid "If you are on windows, do not quote the driver list"
-msgstr ""
+msgstr "Si está en windows, no cite la lista de controladores"
#. Tag: para
#, no-c-format
@@ -128,7 +132,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Spatially enable database using EXTENSION"
-msgstr ""
+msgstr "Habilitar espacialmente la base de datos mediante EXTENSION"
#. Tag: para
#, no-c-format
commit b464de5e34637eec92d1f8ac9ff66764c3744048
Author: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>
Date: Thu Sep 4 22:20:11 2025 +0000
index d11ae72e4..2c90450de 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2025-09-04 22:20+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2025-09-04 22:22+0000\n"
+"Last-Translator: Paulo Cesar Coronado <paulocoronado at udistrital.edu.co>\n"
"Language: es\n"
@@ -70,7 +70,7 @@ msgstr "Si desea activar raster sin conexión:"
#, no-c-format
msgid "Any other setting or no setting at all will disable out of db rasters."
msgstr ""
-"Cualquier otro ajuste o ningún ajuste desactivará los rasterizados fuera de "
+"Cualquier otro ajuste, o ningún ajuste, desactivará los rasters fuera de la "
"db."
#. Tag: para
Summary of changes:
doc/po/es/postgis-manual.po | 12 ++++++++----
1 file changed, 8 insertions(+), 4 deletions(-)
hooks/post-receive
