[PostGIS] #5978: geometry_columns not showing right SRID and Type for constraint based geometry columns
trac at osgeo.org
Fri Sep 5 12:29:42 PDT 2025
geometry columns
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by pramsey):
So, we have had typmod support for literally decades, but I guess the Esri
code has never been updated, so it's still using the AddGeometryColumn
shim. To make this right we are going to first have to revert #5829 and
replace it with the discussed regexp fix instead. Then we are going to
have to update AddGeometryColumn and associated friends to *not* create
constraints anymore (why didn't we do this originally???) but to just use
normal `CREATE TABLE` syntax with typmods.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5978#comment:2>
