[PostGIS] #5978: geometry_columns not showing right SRID and Type for constraint based geometry columns
PostGIS trac at osgeo.org
Fri Sep 5 12:35:41 PDT 2025
geometry columns
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.5.4
 Component:  postgis  |    Version:  3.5.x
Resolution:           |   Keywords:
Comment (by pramsey):
 Aha, the Esri code is deliberately being obtuse by using the "use_typemod"
 flag at the end of AddGeometryColumn(), forcing the system to use ancient
 behaviour. Was EGDB using those constraints itself in some way, and
 somebody added the flag when we changed the default?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5978#comment:3>
