[SCM] PostGIS branch master updated. 3.6.0rc2-33-gff7d11679
Fri Sep 5 14:56:49 PDT 2025
the project "PostGIS".
       via  ff7d11679c1851caa081a730a70fd29d7e8f84e7 (commit)
      from  c8d484f696bb72327faf4cf0be196cf23964ab3e (commit)
revisions in full, below.
commit ff7d11679c1851caa081a730a70fd29d7e8f84e7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 5 14:53:19 2025 -0700
    Return to regex and constraint support for geometry_columns view, references #5978
diff --git a/NEWS b/NEWS
index af8c01d2f..30797bd86 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,7 @@
 PostGIS 3.7.0dev
 xxxx/xx/xx
+  - #5978, return ability of geometry_columns to read constraints
 PostGIS 3.6.0
 2025/xx/xx
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 50c9ba732..03a7fdde8 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6383,17 +6383,43 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 -- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
 CREATE OR REPLACE VIEW geometry_columns AS
- SELECT current_database()::character varying(256) AS f_table_catalog,
-	n.nspname AS f_table_schema,
-	c.relname AS f_table_name,
-	a.attname AS f_geometry_column,
-	COALESCE(postgis_typmod_dims(a.atttypmod), 2) AS coord_dimension,
-	COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), 0) AS srid,
-	replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
+SELECT current_database()::character varying(256) AS f_table_catalog,
+    n.nspname AS f_table_schema,
+    c.relname AS f_table_name,
+    a.attname AS f_geometry_column,
+    COALESCE(postgis_typmod_dims(a.atttypmod), sn.ndims, 2) AS coord_dimension,
+    COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), sr.srid, 0) AS srid,
+    replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), st.type, 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
    FROM pg_class c
-	 JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
-	 JOIN pg_namespace n ON c.relnamespace = n.oid
-	 JOIN pg_type t ON a.atttypid = t.oid
+     JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
+     JOIN pg_namespace n ON c.relnamespace = n.oid
+     JOIN pg_type t ON a.atttypid = t.oid
+     LEFT JOIN ( SELECT s.connamespace,
+            s.conrelid,
+            s.conkey,
+            (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
+           FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+                FROM pg_constraint) AS s
+          WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
+) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
+            s.conrelid,
+            s.conkey,
+            (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
+          WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
+) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
+            s.conrelid,
+            s.conkey,
+            (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
+          WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
+) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
   WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
   AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
   AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 9ac1f216b..81eae6fae 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1579,3 +1579,22 @@ WHERE ST_DFullyWithin(
 SELECT '#5876', ST_AsText(ST_AddPoint(
 		'LINESTRING (1 1, 2 2)'::geometry,
 		'POINT EMPTY'::geometry), 2);
+-- #5978, geometry_columns not showing right SRID and Type
+-- #5829, SELECT geometry_columns returns unexpected error
+CREATE TABLE test5829 (
+  geom geometry);
+ALTER TABLE test5829
+  ADD CONSTRAINT c1
+  CHECK (ST_SRID(geom)=4326 and ST_IsValid(geom));
+CREATE TABLE public.test5978 (
+  OBJECTID SERIAL NOT NULL,
+  PKEY     INTEGER,
+  PRIMARY KEY (OBJECTID));
+SELECT AddGeometryColumn('public', 'test5978', 'shape',  4326, upper('POINT'), 2, false);
+SELECT AddGeometryColumn('public', 'test5978', 'geometry',  4326, upper('POINT'), 2, true);
+SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type
+ FROM geometry_columns WHERE f_table_name IN ('test5829', 'test5978')
+ ORDER BY f_table_name, f_geometry_column;
+DROP TABLE IF EXISTS test5829, test5978;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index d18abe567..37218c8f9 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -484,3 +484,8 @@ ERROR:  Geometry contains invalid coordinates
 #5747|0
 #5855|Knosesmauet
 #5876|LINESTRING(1 1,2 2)
+public.test5978.shape SRID:4326 TYPE:POINT DIMS:2
+public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
+public|test5829|geom|2|4326|GEOMETRY
+public|test5978|geometry|2|4326|POINT
+public|test5978|shape|2|4326|POINT
Summary of changes:
 NEWS                          |  1 +
 postgis/postgis.sql.in        | 46 +++++++++++++++++++++++++++++++++----------
 regress/core/tickets.sql      | 19 ++++++++++++++++++
 regress/core/tickets_expected |  5 +++++
 4 files changed, 61 insertions(+), 10 deletions(-)
hooks/post-receive
