[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
PostGIS trac at osgeo.org
Fri Sep 5 12:26:08 PDT 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 3.3.9
 Component:  postgis   |    Version:  3.5.x
Resolution:  fixed     |   Keywords:
Comment (by pramsey):
 Due to #5978, this needs to be reverted, and then re-done, maybe, ensuring
 that our ancient 'AddGeometryColumn' and other functions are also updated
 to not add constraints.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:11>
