[PostGIS] #5978: geometry_columns not showing right SRID and Type for constraint based geometry columns
trac at osgeo.org
Tue Sep 23 09:30:19 PDT 2025
geometry columns
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Resolution: fixed | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"e587b6f655b37d925edcd7df08d77cf9e76295de/git" e587b6f/git]:
{{{#!CommitTicketReference repository="git"
revision="e587b6f655b37d925edcd7df08d77cf9e76295de"
Remove backported bugfix reference from NEWS file of master branch
References #5978 which was backported, so we assume by the time 3.7.0
will be out the latest stable release will be (3.6.1) which already
has the fix included.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5978#comment:8>
