[PostGIS] #5965: PG19 compile is spitting out warnings about PG_GSERIALIZED_DATUM_NEEDS_DETOAST
trac at osgeo.org
Sun Sep 7 10:38:21 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Laurenz Albe):
I need this additional patch for the build to succeed:
{{{#!diff
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index 102d84f35..d7a7c0755 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -92,7 +92,7 @@ void pg_install_lwgeom_handlers(void);
#define PG_GSERIALIZED_DATUM_NEEDS_DETOAST(datum) \
(VARATT_IS_EXTENDED((datum)) || VARATT_IS_EXTERNAL((datum)) ||
VARATT_IS_COMPRESSED((datum)))
#define PG_GETARG_GSERIALIZED_HEADER(varno) \
- PG_GSERIALIZED_DATUM_NEEDS_DETOAST(PG_GETARG_DATUM(varno)) \
PG_GSERIALIZED_DATUM_NEEDS_DETOAST(DatumGetPointer(PG_GETARG_DATUM(varno)))
? ((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno),
0, gserialized_max_header_size())) \
: ((GSERIALIZED *)(PG_GETARG_DATUM(varno)))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5965#comment:6>
