[PostGIS] #5983: Potential data corruption in topology.topoelement after upgrade to 3.6.0
PostGIS trac at osgeo.org
Wed Sep 10 17:45:25 PDT 2025
  Reporter:  packi     |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.6.1
 Component:  topology  |    Version:  3.6.x
Resolution:            |   Keywords:
Comment (by robe):
 this behaves correctly, so it must be as a whole it knows it's a int[]
 masquerading as a bigint, so at least the data is salvagable:
 SELECT (t::int[])[1], (t::int[])[2] FROM postgis_test;
 yields
  t | t
  1 | 2
 (1 row)
 CREATE TABLE postgis_test2 AS SELECT * FROM postgis_test;
 SELECT t[1], t[2] FROM postgis_test2; -- gives garbage
      t      |       t
  8589934593 | 94612851813424
 (1 row)
 CREATE TABLE postgis_test3 AS SELECT t::int[]::topoelement FROM
 postgis_test;
 SELECT t[1], t[2] FROM postgis_test3; -- fixes it
  t | t
  1 | 2
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:6>
