[PostGIS] #5984: PostGIS selectivity is screwing up queries and forcing it to choose a spatial index when it's inappropriate
trac at osgeo.org
Fri Sep 12 13:32:11 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
For completeness I installed PostGIS 3.3.9dev on same server I have
PostGIS 3.6.0 and my results match what Bas provided for the 3.3 case.
Namely
SELECT _postgis_selectivity ('nodes', 'geom',
ST_GeomFromEWKT('SRID=4326;POLYGON((6.11982 52.6121955,6.11982
53.2038323,7.0927397 53.2038323,7.0927397 52.6121955,6.11982
52.6121955))'), '2');
Yields - 0.07927752284407437
and the explain plan for both ST_Contains and ST_Intersects are decent,
don't use the spatial index
EXPLAIN ANALYZE SELECT wn.way_id FROM way_nodes AS wn INNER JOIN nodes AS
n ON wn.node_id = n.id
WHERE wn.node_id = 8646506472 AND
ST_Intersects(ST_GeomFromEWKT('SRID=4326;POLYGON((6.1198199
52.612195500000006,6.1198199 53.2038323,7.0927397 53.2038323,7.0927397
52.612195500000006,6.1198199 52.612195500000006))'), n.geom);
Nested Loop (cost=1.14..42.18 rows=1 width=8) (actual time=0.055..0.056
rows=0 loops=1)
-> Index Scan using idx_way_nodes_node_id on way_nodes wn
(cost=0.57..8.59 rows=1 width=16) (actual time=0.028..0.028 rows=1
loops=1)
Index Cond: (node_id = '8646506472'::bigint)
-> Index Scan using pk_nodes on nodes n (cost=0.57..33.59 rows=1
width=8) (actual time=0.024..0.024 rows=0 loops=1)
Index Cond: (id = '8646506472'::bigint)
Filter:
st_intersects('0103000020E61000000100000005000000D5A35F11B27A184013A1116C5C4E4A40D5A35F11B27A18402A2F432D179A4A40D529EA27F75E1C402A2F432D179A4A40D529EA27F75E1C4013A1116C5C4E4A40
D5A35F11B27A184013A1116C5C4E4A40'::geometry, geom)
Rows Removed by Filter: 1
Planning Time: 2.835 ms
Execution Time: 0.171 ms
(9 rows)
Contains is same plan as what he had.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5984#comment:7>
