[SCM] PostGIS branch stable-3.6 updated. 3.6.0-3-gd1f739e43
git at osgeo.org
git at osgeo.org
Wed Sep 17 11:34:28 PDT 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
via d1f739e438913c9e72c0711ab945ea514299ed31 (commit)
from e97a587dadf3972676aee3d39c28517154241ad5 (commit)
revisions in full, below.
commit d1f739e438913c9e72c0711ab945ea514299ed31
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 17 11:34:19 2025 -0700
geometry_columns needs to still parse table constraints, references #5978
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 50c9ba732..03a7fdde8 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6383,17 +6383,43 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
-- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
CREATE OR REPLACE VIEW geometry_columns AS
- SELECT current_database()::character varying(256) AS f_table_catalog,
- n.nspname AS f_table_schema,
- c.relname AS f_table_name,
- a.attname AS f_geometry_column,
- COALESCE(postgis_typmod_dims(a.atttypmod), 2) AS coord_dimension,
- COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), 0) AS srid,
- replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
+SELECT current_database()::character varying(256) AS f_table_catalog,
+ n.nspname AS f_table_schema,
+ c.relname AS f_table_name,
+ a.attname AS f_geometry_column,
+ COALESCE(postgis_typmod_dims(a.atttypmod), sn.ndims, 2) AS coord_dimension,
+ COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), sr.srid, 0) AS srid,
+ replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), st.type, 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
FROM pg_class c
- JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
- JOIN pg_namespace n ON c.relnamespace = n.oid
- JOIN pg_type t ON a.atttypid = t.oid
+ JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
+ JOIN pg_namespace n ON c.relnamespace = n.oid
+ JOIN pg_type t ON a.atttypid = t.oid
+ LEFT JOIN ( SELECT s.connamespace,
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
+ FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+ FROM pg_constraint) AS s
+ WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
+) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
+ WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
+) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
+ WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
+) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 9ac1f216b..81eae6fae 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1579,3 +1579,22 @@ WHERE ST_DFullyWithin(
SELECT '#5876', ST_AsText(ST_AddPoint(
'LINESTRING (1 1, 2 2)'::geometry,
'POINT EMPTY'::geometry), 2);
+-- #5978, geometry_columns not showing right SRID and Type
+-- #5829, SELECT geometry_columns returns unexpected error
+CREATE TABLE test5829 (
+ geom geometry);
+ALTER TABLE test5829
+ ADD CONSTRAINT c1
+ CHECK (ST_SRID(geom)=4326 and ST_IsValid(geom));
+CREATE TABLE public.test5978 (
+ OBJECTID SERIAL NOT NULL,
+ PKEY INTEGER,
+ PRIMARY KEY (OBJECTID));
+SELECT AddGeometryColumn('public', 'test5978', 'shape', 4326, upper('POINT'), 2, false);
+SELECT AddGeometryColumn('public', 'test5978', 'geometry', 4326, upper('POINT'), 2, true);
+SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type
+ FROM geometry_columns WHERE f_table_name IN ('test5829', 'test5978')
+ ORDER BY f_table_name, f_geometry_column;
+DROP TABLE IF EXISTS test5829, test5978;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index d18abe567..37218c8f9 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -484,3 +484,8 @@ ERROR: Geometry contains invalid coordinates
#5747|0
#5855|Knosesmauet
#5876|LINESTRING(1 1,2 2)
+public.test5978.shape SRID:4326 TYPE:POINT DIMS:2
+public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
+public|test5829|geom|2|4326|GEOMETRY
+public|test5978|geometry|2|4326|POINT
+public|test5978|shape|2|4326|POINT
Summary of changes:
postgis/postgis.sql.in | 46 +++++++++++++++++++++++++++++++++----------
regress/core/tickets.sql | 19 ++++++++++++++++++
regress/core/tickets_expected | 5 +++++
3 files changed, 60 insertions(+), 10 deletions(-)
hooks/post-receive
