[PostGIS] #5984: PostGIS selectivity is screwing up queries and forcing it to choose a spatial index when it's inappropriate
trac at osgeo.org
Wed Sep 17 19:26:38 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Okay another datapoint with the full nodes table on my windows box
pg18beta3 seems to replicate the same poor values I was seeing on Debian
Trixie 3.6 install.
SELECT postgis_full_version(), version();
vacuum (analyze,verbose) nodes; --ran 3 times
SELECT _postgis_stats('nodes', 'geom','2');
SELECT _postgis_selectivity ('nodes', 'geom',
ST_GeomFromEWKT('SRID=4326;POLYGON((6.11982 52.6121955,6.11982
53.2038323,7.0927397 53.2038323,7.0927397 52.6121955,6.11982
52.6121955))'), '2');
POSTGIS="3.6.0dev 3.6.0rc1-28-g82b37e677" [EXTENSION] PGSQL="180"
GEOS="3.14.0beta3-CAPI-1.20.2" PROJ="8.2.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj DATABA
SE_PATH=C:\ming64gcc81\projects\proj\rel-
proj-8.2.1w64gcc81/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
(Internal)" (core procs from "3.6.0rc1 3.6.0beta1-4
6-g785b53cd7" need upgrade) | PostgreSQL 18beta3 on x86_64-windows,
compiled by msvc-19.44.35213, 64-bit
_postgis_stats
{"ndims":2,"size":[-2147483648,-2147483648],"extent":{"min":[3.33641,50.7274],"max":[7.22925,53.7169]},"table_features":133464968,
"sample_features":30000,"not_null_features":30000,"histogram_features":30000,"histogram_cells":0,"cells_covered":0}
0
(1 row)
On my pg17 windows 3.4
POSTGIS="3.4.5dev 3.4.4-2-ga02435c79" [EXTENSION] PGSQL="170"
GEOS="3.14.0beta3-CAPI-1.20.2" (compiled against GEOS 3.13.0) PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
r\AppData\Local/proj DATABASE_PATH=C:\ming64gcc81\projects\proj\rel-
proj-8.2.1w64gcc81/share/proj/proj.db" LIBXML="2.12.5" LIBJSON="0.12"
LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" | PostgreSQL 17.5 on
x86_64-windows, compi
led by msvc-19.44.35209, 64-bit
(1 row)
_postgis_stats
{"ndims":2,"size":[1,1],"extent":{"min":[3.35288,50.7182],"max":[7.24345,53.5632]},"table_features":133635512,"sample_features":30000
,"not_null_features":30000,"histogram_features":30000,"histogram_cells":1,"cells_covered":3
0000}
(1 row)
0.05200462239583333
(1 row)
If I upgrade this to 3.5.2
SELECT postgis_extensions_upgrade('3.5.2');
It goes bad.
POSTGIS="3.5.2 3.5.1-6-ge07da2483" [EXTENSION] PGSQL="170"
.5 on x86_64-windows, compiled by msvc-19.44.35209, 64-bit
(1 row)
_postgis_stats
{"ndims":2,"size":[-2147483648,-2147483648],"extent":{"min":[3.29959,50.7385],"max":[7.23308,53.5535]}
,"table_features":133389656,
"sample_features":30000,"not_null_features":30000,"histogram_features":29998,"histogram_cells"
0
So I can't tell if this is just luck of the draw or what
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5984#comment:11>
