[PostGIS] #5984: PostGIS selectivity is screwing up queries and forcing it to choose a spatial index when it's inappropriate
trac at osgeo.org
Tue Sep 23 12:49:59 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Description changed by strk:
Old description:
> Issue discussed in:
> https://lists.osgeo.org/pipermail/postgis-
> users/2025-September/046864.html
> Paul suggested reverting the operator introduced in [31bcb7d414/git]
> ALTER OPERATOR @ (geometry , geometry)
> SET ( RESTRICT = contsel,
> JOIN = contjoinsel )
> and that does indeed return to the old 3.3 behavior for this query:
> EXPLAIN (ANALYZE, BUFFERS) SELECT wn.way_id FROM way_nodes AS wn, nodes
> AS n WHERE wn.node_id = 8646506472 AND wn.node_id = n.id AND
> ST_Contains(ST_GeomFromEWKT('SRID=4326;POLYGON((6.1198199
> 52.612195500000006,6.1198199 53.2038323,7.0927397 53.2038323,7.0927397
> 52.612195500000006,6.1198199 52.612195500000006))'), n.geom);
> QUERY PLAN
> Nested Loop (cost=0.99..29.54 rows=1 width=8) (actual
> time=5648.531..5648.532 rows=0 loops=1)
> Buffers: shared hit=6744524 read=845409 written=5
> -> Index Scan using idx_way_nodes_node_id on way_nodes wn
> (cost=0.57..8.59 rows=1 width=16) (actual time=0.021..0.022 rows=1
> loops=1)
> Index Cond: (node_id = '8646506472'::bigint)
> Buffers: shared read=5
> -> Index Scan using idx_nodes_geom on nodes n (cost=0.42..20.94
> rows=1 width=8) (actual time=5648.507..5648.507 rows=0 loops=1)
> Index Cond: (geom @
> '0103000020E61000000100000005000000D5A35F11B27A184013A1116C5C4E4A40D5A35F11B27A18402A2F432D179A4A40D529EA27F75E1C402A2F432D179A4A40D529EA27F75E1C4013A1116C5C4E4A40D5A35F11B27A184013A1116C5C4E4A40'::geometry)
> Filter: ((id = '8646506472'::bigint) AND
> st_contains('0103000020E61000000100000005000000D5A35F11B27A184013A1116C5C4E4A40D5A35F11B27A18402A2F432D179A4A40D529EA27F75E1C402A2F432D179A4A40D529EA27F75E1C4013A1116C5C4E4A40D5A35F11B27A184013A1116C5C4E4A40'::geometry,
> geom))
> Rows Removed by Filter: 9886042
> Buffers: shared hit=6744524 read=845404 written=5
> Planning:
> Buffers: shared hit=11 read=15
> Planning Time: 0.294 ms
> Execution Time: 5648.551 ms
> (14 rows)
> Note the polygon in question covers a good chunk of the table as is
> somewhat obvious from the 9886042 records that needed to be used by a
> filter,
> compared to same query on a 3.3 instance which doesn't use the spatial
> index at all and thus has only one row to remove using Filter.
New description:
Issue discussed in:
https://lists.osgeo.org/pipermail/postgis-users/2025-September/046864.html
EXPLAIN (ANALYZE, BUFFERS) SELECT wn.way_id FROM way_nodes AS wn, nodes AS
QUERY PLAN
loops=1)
Index Cond: (geom @
geom))
Planning:
(14 rows)
filter,
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5984#comment:12>
