[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
PostGIS trac at osgeo.org
Mon Sep 22 00:23:14 PDT 2025
have
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  reopened
  Priority:  medium             |  Milestone:  PostGIS 3.6.1
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 When I get a to a "many edges Exception", I will add the line into a
 postjob list .
 So all lines added OK with zero tolerance and a selected value for
 max_edges will be done step one.
 The postjob we will add lines that failed with tolerance 0 so then we
 adjust tolerance or maybe also max edges .
 A issue when we use snap lines to already added edges, is that it would be
 nice if end and start point did not move if possible.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:10>
