[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Mon Sep 22 07:03:46 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords: performance
Changes (by strk):
* keywords: => performance
Comment:
Replying to [comment:8 Lars Aksel Opsahl]:
> Is this how snapping works today in Topology ?
> The first line is added with no changes because there are no lines to
snap to and do not depend on tolerance settings.
> The second line is then added by using
ST_Snap(line1,topology.edge,1e-07) because there is existing edge close by
to snapto when calling addLineString with tolerance 1e-07.
Yes, this is how snapping works today in PostGIS Topology.
But we always only snap against *vertices* (not "lines"). This is what
ST_Snap does.
The problem of frequent updates is a known one and is already ticketed in
#2993
A methodology recommendation: when doing research is better to use a
mailing list thread rather than a trac ticket.
I'm writing this before trying your input, will do now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:11>
