[PostGIS] #5992: DEBUG: picksplit method for column 1 of index "edge_gist" failed
PostGIS trac at osgeo.org
Tue Sep 23 01:31:14 PDT 2025
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.6.1
Component:  postgis  |    Version:  3.5.x
 Keywords:           |
 I receive this message during TopoGeom_AddLinestring operation when adding
 a set of edges to a topology which started as a single-edge topology (so
 all queries are happening within a transaction):
 The existing edge has a bbox which fully covers the line being added,
 during operations the existing edge is being updated due to splitting, and
 new edges are being created, a lot of them (see #5990 for the test SQL
 file to reproduce). You get a flood of these debug messages during
 operations.
 It could be harmless but the HINT that follows suggests we might be doing
 something about it:
 > HINT:  The index is not optimal. To optimize it, contact a developer, or
 try to use the column as the second one in the CREATE INDEX command.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5992>
