[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Tue Sep 23 04:52:38 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone:
Component: topology | Version: 3.0.x
Resolution: | Keywords: performance
Comment (by Lars Aksel Opsahl):
Replying to [comment:17 strk]:
> At the moment if you run `TopoGeo_addLinestring('topology',geom,0)` you
get to use the precision in the topology.topology record where
name='topology', and if that is also 0 you get to use an automatically
computed snapping tolerance.
So what happens if I use TopoGeo_addLinestring('topology',geom,0) and the
precision in the topology.topology is 1e-07 ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:18>
