[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Tue Sep 23 01:41:07 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone:
Component: topology | Version: 3.0.x
Resolution: | Keywords: performance
Changes (by strk):
* milestone: PostGIS 3.7.0 =>
* type: enhancement => defect
* version: 3.6.x => 3.0.x
Comment:
At the moment if you run `TopoGeo_addLinestring('topology',geom,0)` you
get to use the precision in the topology.topology record where
name='topology', and if that is also 0 you get to use an automatically
computed snapping tolerance.
For the record, I've filed #5993 for the specific action of adding the
`max_edges` parameter, so the issue title is clear. I guess we can keep
this issue open to request an improvement of performances for when you DO
want all those new edges.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:17>
