[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Mon Sep 22 23:41:00 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 3.7.0
Component: topology | Version: 3.6.x
Resolution: | Keywords: performance
Comment (by Lars Aksel Opsahl):
Replying to [comment:13 strk]:
> Replying to [comment:9 Lars Aksel Opsahl]:
> > With no snapping (zero Tolerance in the Topology)
> Just a note: right now there is NO WAY to request no snapping (see
#5688), so what where you referring to here ? Is it 0 precision in the
topology record ? In that case a snapping tolerance is computed based on
the input line distance from origin.
Yes when 0 precision in the topology record and about this.
if I run TopoGeo_addLinestring('topology',geom,**0**) will there be any
difference in snapping rules depending precision value in the topology
record for a call like this ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:16>
