[SCM] PostGIS branch master updated. 3.6.0rc2-55-gfda22140e
Tue Sep 23 09:34:40 PDT 2025
the project "PostGIS".
       via  fda22140ee28de287fd61bb943cad155dc277ee2 (commit)
      from  e587b6f655b37d925edcd7df08d77cf9e76295de (commit)
revisions in full, below.
commit fda22140ee28de287fd61bb943cad155dc277ee2
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 22 17:38:53 2025 +0200
    Add max_edges parameter to TopoGeo_AddLinestring
    Includes documentation and regression tests
    Closes #5993
diff --git a/NEWS b/NEWS
index 980a3c7b4..47a5314c6 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,11 @@
 PostGIS 3.7.0dev
 xxxx/xx/xx
+* New Features *
+ - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
+          (Sandro Santilli)
 PostGIS 3.6.0
 2025/09/01
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 3854a4a93..edd46320d 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1669,6 +1669,7 @@ Adds a linestring to an existing topology using a tolerance and possibly splitti
 						<paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
 						<paramdef><type>geometry </type> <parameter>aline</parameter></paramdef>
 						<paramdef choice="opt"><type>float8 </type> <parameter>tolerance</parameter></paramdef>
+						<paramdef choice="opt"><type>int </type> <parameter>max_edges</parameter></paramdef>
 					</funcprototype>
 				</funcsynopsis>
 			</refsynopsisdiv>
@@ -1678,10 +1679,24 @@ Adds a linestring to an existing topology using a tolerance and possibly splitti
                 <para>
 Adds a linestring to an existing topology and returns a set of signed edge identifiers forming it up
-(negative identifies mean the edge goes in the opposite direction of
-the input linestring).
+(negative identifies mean the edge goes in the opposite direction of the input linestring).
+                </para>
+                <para>
 The given line will snap to existing nodes or edges within given tolerance.
-Existing edges and faces may be split by the line.  New nodes and faces may be added.
+Existing edges and faces may be split by the line.  New nodes and faces may be added, in addition to new edges.
+                </para>
+                <para>
+The returned edge identifiers may be either existing edges or newly
+created edges as needed to fully represent the input line as closely
+as possible.
+                </para>
+<para>
+The number of newly created edges (either covering space previously
+uncovered or resulting from split of existing edges) may be limited
+by the <varname>max_edges</varname> parameter.
                 </para>
                 <note><para>
@@ -1692,6 +1707,7 @@ up to caller, see <xref linkend="Topology_StatsManagement"/>.
                 <!-- use this format if new function -->
                 <para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
                 <para role="enhanced" conformance="3.2.0">Enhanced: 3.2.0 added support for returning signed identifier.</para>
+                <para role="enhanced" conformance="3.7.0">Enhanced: 3.7.0 added support for limiting the number of new edges created in the topology.</para>
 			</refsection>
diff --git a/liblwgeom/topo/liblwgeom_topo.h b/liblwgeom/topo/liblwgeom_topo.h
index b1278aaf5..65c9f4efb 100644
--- a/liblwgeom/topo/liblwgeom_topo.h
+++ b/liblwgeom/topo/liblwgeom_topo.h
@@ -1060,13 +1060,17 @@ LWT_ELEMID lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol);
  * @param nedges output parameter, will be set to number of edges the
  *               line was split into, or -1 on error
  *               (liblwgeom error handler will be invoked with error message)
+ * @param max_edges the maximum number of edges to allow the input
+ *                  line to be split into. 0 for no limits.
+ *                  An error will be returned if number of edges would
+ *                  exceed this number.
  * @return an array of <nedges> edge identifiers that sewed together
  *         will build up the input linestring (after snapping). Caller
  *         will need to free the array using lwfree(), if not null.
 LWT_ELEMID* lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol,
-                        int* nedges);
+                        int* nedges, int max_edges);
  * Adds a linestring to the topology without determining generated faces
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 7f2df42c7..c0d6d5356 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -6747,10 +6747,12 @@ _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t nu
  *        isolated)
  * @param moved if not-null will be set to 0 if the point was added
  *              w/out any snapping or 1 otherwise.
+ * @param numSplitEdges if not-null will be set to the number of edges
+ *                      split by this point.
 static LWT_ELEMID
 _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
-              findFace, int *moved)
+              findFace, int *moved, int *numSplitEdges)
   uint64_t num, i;
   double mindist = FLT_MAX;
@@ -6779,6 +6781,9 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
     PGTOPO_BE_ERROR();
     return -1;
+  if ( numSplitEdges ) *numSplitEdges = 0;
   if ( num )
     LWDEBUGF(1, "New point is within %.15g units of %llu nodes", tol, num);
@@ -6846,6 +6851,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
     id = _lwt_SplitAllEdgesToNewNode(topo, edges, num, lwgeom_as_lwpoint(pt), tol, moved);
     _lwt_release_edges(edges, num);
+    if ( numSplitEdges ) *numSplitEdges = num;
   if ( id == 0 )
@@ -6869,7 +6875,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
 LWT_ELEMID
-  return _lwt_AddPoint(topo, point, tol, 1, NULL);
+  return _lwt_AddPoint(topo, point, tol, 1, NULL, NULL);
@@ -6881,15 +6887,21 @@ lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol)
  *        would create new faces accordingly. Otherwise it will
  *        set left_face and right_face to null (-1)
- * @param forward output parameter, will be populated if
- *        a pre-existing edge was found in the topology,
- *        in which case a value of 1 means the incoming
- *        line will have the same direction of the edge,
- *        and 0 that the incomine line has opposite direction
+ * @param forward output parameter, will be set to 1
+ *        if the returned edge has the same direction
+ *        as the requested line and 0 if it goes the
+ *        opposite direction. For new edges this will
+ *        always be 1.
+ * @param numNewEdges output parameter, if not-null will be set to
+ *                    the number of new edges resulting from this
+ *                    incoming new edge, taking into account edges
+ *                    created due to splitting of existing edges.
 static LWT_ELEMID
 _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
-                  int handleFaceSplit, int *forward )
+                  int handleFaceSplit, int *forward, int *numNewEdges )
   LWCOLLECTION *col;
   LWPOINT *start_point, *end_point;
@@ -6900,6 +6912,9 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   POINT4D p4d;
   uint64_t nn, i;
   int moved=0, mm;
+  int pointSplitEdges = -666;
+  if ( numNewEdges ) *numNewEdges = 0;
   LWDEBUGG(1, lwline_as_lwgeom(edge), "_lwtAddLineEdge");
   LWDEBUGF(1, "_lwtAddLineEdge with tolerance %g", tol);
@@ -6912,11 +6927,12 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   nid[0] = _lwt_AddPoint( topo, start_point,
                           _lwt_minTolerance(lwpoint_as_lwgeom(start_point)),
-                          handleFaceSplit, &mm );
+                          handleFaceSplit, &mm, &pointSplitEdges );
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
+  if ( numNewEdges ) *numNewEdges += pointSplitEdges;
   moved += mm;
-  LWDEBUGF(1, "node for start point added or found to be %" LWTFMT_ELEMID " (moved ? %d)", nid[0], mm);
+  LWDEBUGF(1, "node for start point added or found to be %" LWTFMT_ELEMID " (moved ? %d; split %d edges)", nid[0], mm, pointSplitEdges);
   end_point = lwline_get_lwpoint(edge, edge->points->npoints-1);
@@ -6928,11 +6944,12 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   nid[1] = _lwt_AddPoint( topo, end_point,
                           _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
   moved += mm;
-  LWDEBUGF(1, "node for end point added or found to be %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
+  LWDEBUGF(1, "node for end point added or found to be %" LWTFMT_ELEMID " (moved ? %d; split %d edges)", nid[1], mm, pointSplitEdges);
     -- Added endpoints may have drifted due to tolerance, so
@@ -7037,7 +7054,8 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     return id;
-  /* No previously existing edge was found, we'll add one */
+  /* No previously existing edge was found, we'll check after
+   * decimating, if a tolerance was given */
   /* Remove consecutive vertices below given tolerance
    * on edge addition */
@@ -7072,6 +7090,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
+  /* No previously existing edge was found, we'll add one */
   /* TODO: skip checks ? */
   id = _lwt_AddEdge( topo, nid[0], nid[1], edge, 0, handleFaceSplit ?  1 : -1 );
@@ -7083,7 +7102,9 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   lwgeom_free(tmp); /* possibly takes "edge" down with it */
+  if ( numNewEdges ) ++*numNewEdges;
   *forward = 1;
   return id;
@@ -7113,7 +7134,7 @@ _lwt_split_by_nodes(const LWGEOM *g, const LWGEOM *nodes)
 static LWT_ELEMID*
 _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
-            int handleFaceSplit)
+            int handleFaceSplit, int maxNewEdges)
   LWGEOM *geomsbuf[1];
   LWGEOM **geoms;
@@ -7124,6 +7145,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   LWT_ISO_EDGE *edges;
   LWT_ISO_NODE *nodes;
   uint64_t num, numedges = 0, numnodes = 0;
+  int num_new_edges = 0;
   uint64_t i;
   GBOX qbox;
   int forward;
@@ -7453,6 +7475,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   num = 0;
   for ( i=0; i<ngeoms; ++i )
+    int edgeNewEdges;
     LWT_ELEMID id;
     LWGEOM *g = geoms[i];
     g->srid = noded->srid;
@@ -7466,14 +7489,33 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
 #endif
-    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward );
-    LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID, id);
+    forward = -1; /* will be set to either 0 or 1 if the edge already existed */
+    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward, &edgeNewEdges );
+    num_new_edges += edgeNewEdges;
+    /* if forward is still == -1 this was NOT an existing edge ? */
+    if ( forward == -1 )
+      ++num_new_edges;
+    LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID
+      " (forward ? %d), reported to create %d new edges (total new edges: %d)",
+      id, forward, edgeNewEdges, num_new_edges);
     if ( id < 0 )
       lwgeom_free(noded);
       lwfree(ids);
       return NULL;
+    if ( maxNewEdges >= 0 && num_new_edges > maxNewEdges )
+      lwgeom_free(noded);
+      lwfree(ids);
+      lwerror("Adding line to topology requires creating more edges than the requested limit of %d", maxNewEdges);
+      return NULL;
     if ( ! id )
       LWDEBUGF(1, "Component %llu of split line collapsed", i);
@@ -7495,31 +7537,31 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
 LWT_ELEMID*
-lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges)
+lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges, int max_new_edges)
-  return _lwt_AddLine(topo, line, tol, nedges, 1);
+  return _lwt_AddLine(topo, line, tol, nedges, 1, max_new_edges);
 LWT_ELEMID*
 lwt_AddLineNoFace(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges)
-  return _lwt_AddLine(topo, line, tol, nedges, 0);
+  return _lwt_AddLine(topo, line, tol, nedges, 0, -1);
 static void
 lwt_LoadPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol)
-  _lwt_AddPoint(topo, point, tol, 1, NULL);
+  _lwt_AddPoint(topo, point, tol, 1, NULL, NULL);
 static void
-lwt_LoadLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol)
+lwt_LoadLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int max_new_edges)
   LWT_ELEMID* ids;
   int nedges;
   /* TODO: avoid allocating edge ids */
-  ids = lwt_AddLine(topo, line, tol, &nedges);
+  ids = lwt_AddLine(topo, line, tol, &nedges, max_new_edges);
   if ( nedges > 0 ) lwfree(ids);
@@ -7537,7 +7579,7 @@ lwt_LoadPolygon(LWT_TOPOLOGY* topo, const LWPOLY* poly, double tol)
     /* TODO: avoid the clone here */
     pa = ptarray_clone(poly->rings[i]);
     line = lwline_construct(topo->srid, NULL, pa);
-    lwt_LoadLine(topo, line, tol);
+    lwt_LoadLine(topo, line, tol, -1);
     lwline_free(line);
@@ -8035,7 +8077,7 @@ _lwt_LoadGeometryRecursive(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
       return;
     case LINETYPE:
-      lwt_LoadLine(topo, lwgeom_as_lwline(geom), tol);
+      lwt_LoadLine(topo, lwgeom_as_lwline(geom), tol, -1);
       return;
     case POLYGONTYPE:
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 4a8b82438..a244e8974 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5087,6 +5087,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
   GSERIALIZED *geom;
   LWGEOM *lwgeom;
   LWLINE *ln;
+  int max_new_edges = -1; /* defaults to unlimited */
   LWT_TOPOLOGY *topo;
   FuncCallContext *funcctx;
   MemoryContext oldcontext, newcontext;
@@ -5106,6 +5107,11 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
       PG_RETURN_NULL();
+    if (PG_NARGS() > 3 && !PG_ARGISNULL(3))
+      max_new_edges = PG_GETARG_INT32(3);
     toponame_text = PG_GETARG_TEXT_P(0);
     toponame = text_to_cstring(toponame_text);
     PG_FREE_IF_COPY(toponame_text, 0);
@@ -5166,7 +5172,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
     POSTGIS_DEBUG(1, "Calling lwt_AddLine");
-    elems = lwt_AddLine(topo, ln, tol, &nelems);
+    elems = lwt_AddLine(topo, ln, tol, &nelems, max_new_edges);
     POSTGIS_DEBUG(1, "lwt_AddLine returned");
     lwgeom_free(lwgeom);
     PG_FREE_IF_COPY(geom, 1);
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index 87506e36c..d24ef61db 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -741,7 +741,7 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPoint(atopology varchar, apoint g
 -- Changed: 3.6.0 uses bigint for IDs
 -- Replaces topogeo_addlinestring(varchar, geometry, float8) deprecated in 3.6.0
-CREATE OR REPLACE FUNCTION topology.TopoGeo_AddLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
+CREATE OR REPLACE FUNCTION topology.TopoGeo_AddLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0, max_edges int DEFAULT -1)
 	RETURNS SETOF bigint AS
 	'MODULE_PATHNAME', 'TopoGeo_AddLinestring'
   LANGUAGE 'c' VOLATILE;
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 1b35ba150..7acb1f350 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -556,3 +556,36 @@ SELECT NULL FROM topology.TopoGeo_addLinestring('t5782',
 SELECT '#5782', 'valid_after', * FROM topology.ValidateTopology('t5782');
 ROLLBACK;
+-- See https://trac.osgeo.org/postgis/ticket/5993
+SELECT NULL FROM topology.CreateTopology ('t5993');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5993',
+'LINESTRING(0 2, 100 2)'
+-- We expect this to succeed, as we added no new edges
+SELECT '#5993.0', 'existing-data', count(*) FROM topology.TopoGeo_addLinestring('t5993',
+  'LINESTRING(0 2,100 2)', max_edges => 0
+-- This should fail because the existing edge is split
+-- creating a new edge while we limit to 0
+SELECT '#5993.1', 'single-split', count(*) FROM topology.TopoGeo_addLinestring('t5993',
+  'LINESTRING(0 2,80 2)', max_edges => 0
+-- creating two new edge while we limit to 1
+SELECT '#5993.2', 'double-split-off-limit', count(*) FROM topology.TopoGeo_addLinestring('t5993',
+  'LINESTRING(10 2,80 2)', max_edges => 1
+-- This should succeed because the existing edge is split
+SELECT '#5993.3', 'double-split-in-limit', count(*) FROM topology.TopoGeo_addLinestring('t5993',
+  'LINESTRING(10 2,80 2)', max_edges => 2
+-- This should fail because the existing edge is snap-split
+SELECT '#5993.4', 'snap-split-off-limit', * FROM topology.TopoGeo_addLinestring('t5993',
+  ST_MakeLine(ST_MakePoint(5, 0), ST_MakePoint(5, 2 - 1e-20)),
+  max_edges => 1,
+  tolerance => 2
+SELECT NULL FROM topology.DropTopology ('t5993');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 6757356c1..a9ecae7b9 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -228,3 +228,8 @@ b5234.0|1
 b5234.1|1
 t5568|invalidities at start|
 t5568|invalidities at end|
+#5993.0|existing-data|1
+ERROR:  Adding line to topology requires creating more edges than the requested limit of 0
+ERROR:  Adding line to topology requires creating more edges than the requested limit of 1
+#5993.3|double-split-in-limit|1
Summary of changes:
 NEWS                                               |  5 ++
 doc/extras_topology.xml                            | 22 +++++-
 liblwgeom/topo/liblwgeom_topo.h                    |  6 +-
 liblwgeom/topo/lwgeom_topo.c                       | 90 ++++++++++++++++------
 topology/postgis_topology.c                        |  8 +-
 topology/sql/populate.sql.in                       |  2 +-
 topology/test/regress/topogeo_addlinestring.sql    | 33 ++++++++
 .../test/regress/topogeo_addlinestring_expected    |  5 ++
 8 files changed, 141 insertions(+), 30 deletions(-)
hooks/post-receive
