[SCM] PostGIS branch master updated. 3.6.0rc2-61-ge8e5e31d4
Sun Sep 28 23:20:57 PDT 2025
the project "PostGIS".
       via  e8e5e31d452c3d7324d81a7ac1bd72b9d2f61400 (commit)
       via  26e16ebb2a88f59a75653ea4ce11c3ef22598c51 (commit)
       via  8388e12fabf27f0ed535e1fc4978e6e00639c31c (commit)
       via  27c14b0ebe009d0c40cc7af5c65c96a79d55137e (commit)
       via  8c1e29a301e4a6f5443005a97d02e2ab1debbf32 (commit)
       via  33c4f02e755d04649f58e8eec6b9048b3b7c4c2d (commit)
      from  fda22140ee28de287fd61bb943cad155dc277ee2 (commit)
revisions in full, below.
commit e8e5e31d452c3d7324d81a7ac1bd72b9d2f61400
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Sep 26 17:30:38 2025 +0200
    fix(loader): add NULL checks for malloc/calloc in shpopen
diff --git a/loader/shpopen.c b/loader/shpopen.c
index 63d301e06..3fe86874d 100644
--- a/loader/shpopen.c
+++ b/loader/shpopen.c
@@ -367,6 +367,8 @@ SHPOpenLL( const char * pszLayer, const char * pszAccess, SAHooks *psHooks )
 /*  Initialize the info structure.                  */
     psSHP = STATIC_CAST(SHPHandle, calloc(sizeof(SHPInfo),1));
+    if( psSHP == SHPLIB_NULLPTR )
+        return SHPLIB_NULLPTR;
     psSHP->bUpdated = FALSE;
     memcpy( &(psSHP->sHooks), psHooks, sizeof(SAHooks) );
@@ -377,6 +379,11 @@ SHPOpenLL( const char * pszLayer, const char * pszAccess, SAHooks *psHooks )
     nLenWithoutExtension = SHPGetLenWithoutExtension(pszLayer);
     pszFullname = STATIC_CAST(char *, malloc(nLenWithoutExtension + 5));
+    if( pszFullname == SHPLIB_NULLPTR )
+        free( psSHP );
     memcpy(pszFullname, pszLayer, nLenWithoutExtension);
     memcpy(pszFullname + nLenWithoutExtension, ".shp", 5);
     psSHP->fpSHP = psSHP->sHooks.FOpen(pszFullname, pszAccess );
@@ -746,6 +753,8 @@ SHPRestoreSHX ( const char * pszLayer, const char * pszAccess, SAHooks *psHooks
+        return FALSE;
     fpSHP = psHooks->FOpen(pszFullname, pszAccess );
@@ -1023,6 +1032,8 @@ SHPCreateLL( const char * pszLayer, int nShapeType, SAHooks *psHooks )
     fpSHP = psHooks->FOpen(pszFullname, "wb" );
commit 26e16ebb2a88f59a75653ea4ce11c3ef22598c51
Date:   Fri Sep 26 17:30:26 2025 +0200
    fix(loader): fix memory leaks and replace deprecated GTK constants
diff --git a/loader/shp2pgsql-gui.c b/loader/shp2pgsql-gui.c
index 7e357d58b..847e69af7 100644
--- a/loader/shp2pgsql-gui.c
+++ b/loader/shp2pgsql-gui.c
@@ -913,9 +913,22 @@ create_new_file_config(const char *filename)
 	   type set in set_loader_config_defaults() and each config needs its own copy
 	   of any referenced items */
 	loader_file_config->encoding = strdup(global_loader_config->encoding);
+	if ( loader_file_config->encoding == NULL )
+		free(loader_file_config);
+		pgui_seterr("Unable to allocate memory for encoding");
+		return 0;
 	/* Copy the filename (we'll remove the .shp extension in a sec) */
 	loader_file_config->shp_file = strdup(filename);
+	if ( loader_file_config->shp_file == NULL )
+		free(loader_file_config->encoding);
+		pgui_seterr("Unable to allocate memory for filename");
+		return 0;
 	/* Generate the default table name from the filename */
 	table_start = loader_file_config->shp_file + strlen(loader_file_config->shp_file);
@@ -1319,6 +1332,12 @@ pgui_action_open_file_dialog(GtkWidget *widget, gpointer data)
 			filename = g_slist_nth_data(filename_item, 0);
 			loader_file_config = create_new_file_config(filename);
+			if (loader_file_config == NULL) {
+				pgui_raise_error_dialogue();
+				g_free(filename);
+				filename_item = g_slist_next(filename_item);
+				continue;
 			add_loader_file_config_to_list(loader_file_config);
 			/* Grab the next filename */
@@ -2005,6 +2024,12 @@ process_single_uri(char *uri)
 	/* Create a new row in the listview */
+		g_free(filename);
+		g_free(hostname);
+		return;
 	g_free(filename);
@@ -2622,11 +2647,11 @@ pgui_create_folderchooser_dialog(void)
 static void
-pgui_create_progress_dialog()
+pgui_create_progress_dialog(void)
 	GtkWidget *vbox_progress, *table_progress;
-	dialog_progress = gtk_dialog_new_with_buttons(_("Working..."), GTK_WINDOW(window_main), GTK_DIALOG_DESTROY_WITH_PARENT, GTK_STOCK_CANCEL, GTK_RESPONSE_CANCEL, NULL);
+	dialog_progress = gtk_dialog_new_with_buttons(_("Working..."), GTK_WINDOW(window_main), GTK_DIALOG_DESTROY_WITH_PARENT, "_Cancel", GTK_RESPONSE_CANCEL, NULL);
 	gtk_window_set_modal(GTK_WINDOW(dialog_progress), TRUE);
 	gtk_window_set_keep_above(GTK_WINDOW(dialog_progress), TRUE);
commit 8388e12fabf27f0ed535e1fc4978e6e00639c31c
Date:   Fri Sep 26 17:30:15 2025 +0200
    fix(loader): add NULL check for strdup in shp2pgsql-cli
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index 3029ff104..c2c4719a9 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -308,6 +308,12 @@ main (int argc, char **argv)
 		char *shp_file = strdup(config->shp_file);
 		char *ptr;
+		if ( shp_file == NULL )
+			fprintf(stderr, "Unable to allocate memory for shapefile name\n");
+			exit(1);
 		/* Remove the extension, if present */
 		for ( ptr = shp_file + strlen(shp_file); ptr > shp_file; ptr-- )
commit 27c14b0ebe009d0c40cc7af5c65c96a79d55137e
Date:   Fri Sep 26 17:30:04 2025 +0200
    fix(loader): add NULL check for malloc in quote_identifier
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 355ef9a41..0d6e43486 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -2250,6 +2250,9 @@ quote_identifier(const char *s)
 	char	   *result = malloc(strlen(s) * 2 + 3);
 	char	   *r = result;
+	if (result == NULL)
+		return NULL;
 	*r++ = '"';
 	while (*s)
commit 8c1e29a301e4a6f5443005a97d02e2ab1debbf32
Date:   Fri Sep 26 17:29:51 2025 +0200
    fix(loader): add NULL checks for malloc/calloc in dbfopen
diff --git a/loader/dbfopen.c b/loader/dbfopen.c
index 32d11a0c2..5611473f4 100644
--- a/loader/dbfopen.c
+++ b/loader/dbfopen.c
@@ -416,10 +416,17 @@ DBFOpenLL( const char * pszFilename, const char * pszAccess, SAHooks *psHooks )
     nLenWithoutExtension = DBFGetLenWithoutExtension(pszFilename);
     memcpy(pszFullname, pszFilename, nLenWithoutExtension);
     memcpy(pszFullname + nLenWithoutExtension, ".dbf", 5);
     psDBF = STATIC_CAST(DBFHandle, calloc( 1, sizeof(DBFInfo) ));
+    if( psDBF == SHPLIB_NULLPTR )
+        free( pszFullname );
     psDBF->fp = psHooks->FOpen( pszFullname, pszAccess );
     memcpy( &(psDBF->sHooks), psHooks, sizeof(SAHooks) );
@@ -692,6 +699,8 @@ DBFCreateLL( const char * pszFilename, const char * pszCodePage, SAHooks *psHook
@@ -1973,6 +1982,18 @@ DBFReorderFields( DBFHandle psDBF, int* panMap )
     pszHeaderNew = STATIC_CAST(char*, malloc(sizeof(char) * XBASE_FLDHDR_SZ *
                                   psDBF->nFields));
+    if( panFieldOffsetNew == SHPLIB_NULLPTR || panFieldSizeNew == SHPLIB_NULLPTR ||
+        panFieldDecimalsNew == SHPLIB_NULLPTR || pachFieldTypeNew == SHPLIB_NULLPTR ||
+        pszHeaderNew == SHPLIB_NULLPTR )
+        free( panFieldOffsetNew );
+        free( panFieldSizeNew );
+        free( panFieldDecimalsNew );
+        free( pachFieldTypeNew );
+        free( pszHeaderNew );
+        return FALSE;
     /* shuffle fields definitions */
     for(i=0; i < psDBF->nFields; i++)
commit 33c4f02e755d04649f58e8eec6b9048b3b7c4c2d
Date:   Fri Sep 26 17:29:41 2025 +0200
    fix(loader): initialize Point struct z,m fields in shp2pgsql-core
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index b200ee77a..d13f52451 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -531,9 +531,13 @@ FindPolygons(SHPObject *obj, Ring ***Out)
 		pt.x = inner->list[0].x;
 		pt.y = inner->list[0].y;
+		pt.z = 0.0;
+		pt.m = 0.0;
 		pt2.x = inner->list[1].x;
 		pt2.y = inner->list[1].y;
+		pt2.z = 0.0;
+		pt2.m = 0.0;
 		* If we assume that the case of the "big polygon w/o hole
Summary of changes:
 loader/dbfopen.c        | 21 +++++++++++++++++++++
 loader/pgsql2shp-core.c |  3 +++
 loader/shp2pgsql-cli.c  |  6 ++++++
 loader/shp2pgsql-core.c |  4 ++++
 loader/shp2pgsql-gui.c  | 29 +++++++++++++++++++++++++++--
 loader/shpopen.c        | 11 +++++++++++
 6 files changed, 72 insertions(+), 2 deletions(-)
hooks/post-receive
