[SCM] PostGIS branch master updated. 3.6.0rc2-64-g0e46c6f1f
git at osgeo.org
git at osgeo.org
Tue Sep 30 00:14:37 PDT 2025
the project "PostGIS".
via 0e46c6f1f5492e4e164b594172593237cb3565be (commit)
from f6ab40874a85b0c7cbaa419a47029b1ea8428f2e (commit)
revisions in full, below.
commit 0e46c6f1f5492e4e164b594172593237cb3565be
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Sep 30 09:14:05 2025 +0200
Add --help (-h) support
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index db3ba0424..68e9ae229 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -19,9 +19,10 @@ cd - > /dev/null
export PGDATABASE=template1
usage() {
- echo "Usage: $0 [-s] <to_version>"
+ echo "Usage: $0 [<option> ...] <to_version>"
echo "Options:"
- echo "\t-s Stop on first failure"
+ echo "\t--help|-h Print this usage text"
+ echo "\t-s Stop on first failure"
echo "\t--skip <regexp> Do not run tests with label matching given extended regexp"
@@ -31,6 +32,9 @@ while test -n "$1"; do
elif test "$1" = "--skip"; then
shift
SKIP_LABEL_REGEXP=$1
+ elif test "$1" = "-h" -o "$1" = "--help"; then
+ usage
+ exit 0
elif test -z "$to_version_param"; then
to_version_param="$1"
else
Summary of changes:
utils/check_all_upgrades.sh | 8 ++++++--
1 file changed, 6 insertions(+), 2 deletions(-)
hooks/post-receive
