[SCM] PostGIS branch stable-3.5 updated. 3.5.3-56-g50caad929
Tue Sep 30 10:59:12 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  50caad929fce9d57ff633da75e29575b692acaa0 (commit)
       via  6635922a3693a03e5555e24bf067fec582a621ce (commit)
      from  6085536df194f697887048f3c5d80e2b57107c8f (commit)
revisions in full, below.
commit 50caad929fce9d57ff633da75e29575b692acaa0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Sep 30 10:37:09 2025 -0700
    News item for #5994
diff --git a/NEWS b/NEWS
index 683887ff9..67e50c200 100644
--- a/NEWS
+++ b/NEWS
@@ -30,6 +30,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
 - #5082, LRS proportions clamped to [0,1] (Pawel Ostrowski)
 - #5985, Fix configure issue with Debian 12 and 13 (Regina Obe, Sandro Santilli)
 - #5991, CircularString distance error (Paul Ramsey)
+- #5994, Null pointer in ST_AsGeoJsonRow (Alexander Kukushkin)
 PostGIS 3.5.3
commit 6635922a3693a03e5555e24bf067fec582a621ce
Date:   Tue Sep 30 10:29:37 2025 -0700
    Fix null pointer in ST_AsGeoJsonRow, references #5994
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 67c1cafa6..931344c1c 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -88,12 +88,12 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
 	Datum		array = PG_GETARG_DATUM(0);
 	text        *geom_column_text = PG_GETARG_TEXT_P(1);
+	char        *geom_column = PG_ARGISNULL(1) ? "" : text_to_cstring(geom_column_text);
 	int32       maxdecimaldigits = PG_GETARG_INT32(2);
 	bool		do_pretty = PG_GETARG_BOOL(3);
 	text        *id_column_text = PG_GETARG_TEXT_P(4);
-	StringInfo	result;
-	char        *geom_column = text_to_cstring(geom_column_text);
-	char        *id_column = text_to_cstring(id_column_text);
+	char        *id_column = PG_ARGISNULL(4) ? "" : text_to_cstring(id_column_text);
+	StringInfoData result;
 	Oid geom_oid = InvalidOid;
 	Oid geog_oid = InvalidOid;
@@ -107,11 +107,11 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
 	if (strlen(id_column) == 0)
 		id_column = NULL;
-	result = makeStringInfo();
+	initStringInfo(&result);
-	composite_to_geojson(fcinfo, array, geom_column, id_column, maxdecimaldigits, result, do_pretty, geom_oid, geog_oid);
+	composite_to_geojson(fcinfo, array, geom_column, id_column, maxdecimaldigits, &result, do_pretty, geom_oid, geog_oid);
-	PG_RETURN_TEXT_P(cstring_to_text_with_len(result->data, result->len));
+	PG_RETURN_TEXT_P(cstring_to_text_with_len(result.data, result.len));
Summary of changes:
 NEWS                         |  1 +
 postgis/lwgeom_out_geojson.c | 12 ++++++------
 2 files changed, 7 insertions(+), 6 deletions(-)
hooks/post-receive
