[SCM] PostGIS branch master updated. 3.7.0beta1-188-gc726cfb93c
Sun Aug 2 22:40:14 PDT 2026
the project "PostGIS".
       via  c726cfb93c31609f076ebc33bed2cd976922de51 (commit)
       via  8c7a156de49610d39bb7cde310e2ea998f8f7913 (commit)
       via  31aec6787f974c94ff5fa0180969d73dd1817e14 (commit)
      from  66a5f3d56d091911ff502d207082c0792d3a6931 (commit)
revisions in full, below.
commit c726cfb93c31609f076ebc33bed2cd976922de51
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 3 01:39:57 2026 -0400
    Change to beta2 since too many changes for an RC
diff --git a/NEWS b/NEWS
index 1b3a9e87da..65e6328bc5 100644
--- a/NEWS
+++ b/NEWS
@@ -1,4 +1,4 @@
-PostGIS 3.7.0rc1
+PostGIS 3.7.0beta2
 2026/xx/xx
 This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp.
 To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
commit 8c7a156de49610d39bb7cde310e2ea998f8f7913
Date:   Mon Aug 3 01:38:13 2026 -0400
    Add Dennis Tighe to credits for https://trac.osgeo.org/postgis/ticket/6109
    For PostGIS 3.7.0
diff --git a/.mailmap b/.mailmap
index d72621b923..4508bcf05b 100644
--- a/.mailmap
+++ b/.mailmap
@@ -33,7 +33,7 @@ Darafei Praliaskouski <me at komzpa.net> <komzpa at gojuno.com>
 Darafei Praliaskouski <me at komzpa.net> Darafei <komzpa at gmail.com>
 Dave Blasby <dblasby at gmail.com> David Blasby <dblasby at gmail.com>
+Dennis Tighe <dtighe at google.com>
 Devrim Gündüz <devrim at gunduz.org> Devrim GÜNDÜZ <devrim at gunduz.org>
 Edouard Choinière <echoix at users.noreply.weblate.osgeo.org> Edouard Choiniere <echoix at users.noreply.weblate.osgeo.org>
index d663d01851..1b3a9e87da 100644
--- a/NEWS
+++ b/NEWS
@@ -37,7 +37,9 @@ These are only changes since 3.7.0beta1.
           geometry data (Darafei Praliaskouski)
  - GT-564, Avoid ST_MakePolygon failures with NULL hole array entries
- - #6110, regression in speed with geometry_columns
+ - #6109, Out-of-bounds heap read in BOX2D_out and BOX2D_expand
+   on 65-byte box2d under ASAN (Dennis Tighe, Google)
+ - #6110, regression in speed with geometry_columns (Regina Obe)
 * Enhancements *
diff --git a/doc/credits.xml b/doc/credits.xml
index 8f3517223d..cdb0e7be25 100644
--- a/doc/credits.xml
+++ b/doc/credits.xml
@@ -305,6 +305,7 @@
 					<member>David Garnier</member>
 					<member>David Skea</member>
 					<member>David Techer</member>
+                    <member>Dennis Tighe</member>
 					<member>Denys Kovshun</member>
 					<member>Devrim Gündüz</member>
 					<member>Dian M Fay</member>
commit 31aec6787f974c94ff5fa0180969d73dd1817e14
Author: Dennis Tighe <dtighe at google.com>
Date:   Wed Jul 29 17:49:01 2026 -0700
    Fix out-of-bounds read in BOX2D_out and BOX2D_expand
    box2d is declared with internallength=65 (postgis.sql.in), which is 7
    bytes short of sizeof(GBOX) (72). Copying the full GBOX struct (72 bytes) via
    memcpy in BOX2D_out and BOX2D_expand causes a 7-byte out-of-bounds heap
    read under ASAN. Reference: #6109
    This change fixes this by copying only up to offsetof(GBOX, zmin), which contains all
    2D box fields (xmin, xmax, ymin, ymax, flags, SRID) within the 65-byte payload.
    This also memzeros the target buffer out as a defensive measure where it wasn't
    done previously.
    Add regression test regress/core/box2d.sql (these fail under ASAN today).
    References #6109 for PostGIS 3.7.0
    Closes https://gitea.osgeo.org/postgis/postgis/pulls/628 for PostGIS 3.7.0
diff --git a/postgis/lwgeom_box.c b/postgis/lwgeom_box.c
index 98b39ed955..f53424507a 100644
--- a/postgis/lwgeom_box.c
+++ b/postgis/lwgeom_box.c
@@ -100,9 +100,15 @@ Datum BOX2D_out(PG_FUNCTION_ARGS)
 	int size = 0;
 	GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
-	/* Avoid unaligned access to the gbox struct */
+	/* Avoid unaligned access to the gbox struct.
+	 * box2d can be 65 bytes, which is 7 bytes short of sizeof(GBOX) (72)
+	 * so just copy the required part (xy/min, xy/max) and zero the rest
+	 * (matches BOX2d_expand).
 	GBOX box_aligned;
-	memcpy(&box_aligned, box, sizeof(GBOX));
+	memset(&box_aligned, 0, sizeof(box_aligned));
+	memcpy(&box_aligned, box, offsetof(GBOX, zmin));
 	size = 4;
 	size += lwprint_double(box_aligned.xmin, precision, &tmp[size]);
@@ -387,8 +393,10 @@ PG_FUNCTION_INFO_V1(BOX2D_expand);
 Datum BOX2D_expand(PG_FUNCTION_ARGS)
-	GBOX *result = (GBOX *)palloc(sizeof(GBOX));
-	memcpy(result, box, sizeof(GBOX));
+	/* box2d is 65 bytes (7 bytes short of sizeof(GBOX)) and is a purely
+	 * 2D box; copy only the 2D header */
+	GBOX *result = (GBOX *)palloc0(sizeof(GBOX));
+	memcpy(result, box, offsetof(GBOX, zmin));
 	if (PG_NARGS() == 2)
diff --git a/regress/core/box2d.sql b/regress/core/box2d.sql
new file mode 100644
index 0000000000..746f778603
--- /dev/null
+++ b/regress/core/box2d.sql
@@ -0,0 +1,8 @@
+-- box2d output / expand must not read past a materialised box2d value.
+-- see #6109
+SELECT 'out',        ('LINESTRING(0 0,1 1)'::geometry::box2d)::text;
+SELECT 'out_3d',     ('LINESTRING Z (0 0 9,2 3 9)'::geometry::box2d)::text;
+SELECT 'roundtrip',  'BOX(1.5 2.5,3.5 4.5)'::box2d::text;
+SELECT 'extent',     ST_Extent(g)::text FROM (VALUES ('POINT(0 0)'::geometry),('POINT(5 7)'::geometry)) v(g);
+SELECT 'expand_d',   ST_Expand('LINESTRING(0 0,10 10)'::geometry::box2d, 1)::text;
+SELECT 'expand_dxdy',ST_Expand('LINESTRING(0 0,10 10)'::geometry::box2d, 2, 3)::text;
diff --git a/regress/core/box2d_expected b/regress/core/box2d_expected
index 0000000000..e6ce8e0b6d
--- /dev/null
+++ b/regress/core/box2d_expected
@@ -0,0 +1,6 @@
+out|BOX(0 0,1 1)
+out_3d|BOX(0 0,2 3)
+roundtrip|BOX(1.5 2.5,3.5 4.5)
+extent|BOX(0 0,5 7)
+expand_d|BOX(-1 -1,11 11)
+expand_dxdy|BOX(-2 -3,12 13)
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 1b14fbeebc..784c507130 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -33,6 +33,7 @@ TESTS += \
 	$(top_srcdir)/regress/core/bestsrid \
 	$(top_srcdir)/regress/core/binary \
 	$(top_srcdir)/regress/core/boundary \
+	$(top_srcdir)/regress/core/box2d \
 	$(top_srcdir)/regress/core/catmullrom \
 	$(top_srcdir)/regress/core/chaikin \
 	$(top_srcdir)/regress/core/clean \
Summary of changes:
 .mailmap                    |  2 +-
 NEWS                        |  6 ++++--
 doc/credits.xml             |  1 +
 postgis/lwgeom_box.c        | 16 ++++++++++++----
 regress/core/box2d.sql      |  8 ++++++++
 regress/core/box2d_expected |  6 ++++++
 regress/core/tests.mk.in    |  1 +
 7 files changed, 33 insertions(+), 7 deletions(-)
 create mode 100644 regress/core/box2d.sql
 create mode 100644 regress/core/box2d_expected
hooks/post-receive
