[SCM] PostGIS branch master updated. 3.7.0beta1-195-g1dea1ba1ad
Mon Aug 3 02:31:35 PDT 2026
the project "PostGIS".
       via  1dea1ba1ade42f25d8d28b981eddd857a6710dae (commit)
       via  43d35acf56cb1a93aaa10bc7d127532f34c3ca64 (commit)
      from  2631fe89f3c7918d2a5e25e4d8dd74aef4b0dec8 (commit)
revisions in full, below.
commit 1dea1ba1ade42f25d8d28b981eddd857a6710dae
Merge: 2631fe89f3 43d35acf56
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Aug 3 02:31:26 2026 -0700
    Merge pull request 'ci: give every localized docs step the same path filter' (!659) from Komzpa/postgis:ci/docs-locale-filter-20260803 into master
    Pipeline **6570 on master died before running a single step**:
    step 'check-cheatsheets-ja' depends on step 'check-cheatsheets-de'
    which is filtered out by its conditions
    Woodpecker refuses a whole pipeline when an included step depends on a step its own
    conditions leave out. The localized steps are chained to each other to cap memory
    (14bec3c66, 74ac1ee1c), but each one was filtered to its own language's `.po` files, so
    the chain only held together when a commit touched every language at once. Every
    single-language translation commit — which is exactly what Weblate produces — breaks it.
    The commit 6570 built, `c69b4727c`, touches Japanese only.
    The chain is worth keeping, so the filters have to agree instead. All localized steps now
    share one `when_localized` anchor: the languages are included or excluded together, a
    translation commit runs the localized targets for every language serialized as before,
    and no step can depend on a step that is not there.
    Checked before pushing:
    * `woodpecker-cli lint .woodpecker/docs.yml` → `Config is valid`
    * cross-language dependencies whose filters disagree: **60 on master, 0 here** (same 72 steps)
    * the memory-control chain is unchanged — `depends_on: [ prepare, check-xml-it_IT ]` and
      friends are all still there
    * `update-docs-localized.sh` is idempotent: running it twice produces a byte-identical file
    One thing found on the way: the comment explaining why the chain exists sat *past* the
    `DO NOT EDIT PAST THIS LINE` marker, so `update-docs-localized.sh` deleted it on every
    run. It is now printed by the generator, and says what the filter has to do with the chain.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/659
commit 43d35acf56cb1a93aaa10bc7d127532f34c3ca64
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Aug 3 05:53:02 2026 +0400
    A pipeline for master died before it ran a single step:
    Woodpecker refuses the whole pipeline when an included step depends on a step
    that its own conditions leave out. The localized steps are chained to each other
    to cap memory, but each one was filtered to its own language's .po files, so the
    single-language translation commit -- which is what Weblate produces -- broke it.
    Pipeline 6570 on master is one; the commit it built touched Japanese only.
    Keeping the chain matters, so the filters have to agree instead: all localized
    steps now share when_localized, and the languages are included or excluded
    together. A translation commit runs the localized targets for every language,
    serialized as before, rather than erroring the pipeline.
    The comment explaining why the chain exists lived past the DO NOT EDIT line, so
    update-docs-localized.sh deleted it every time it ran. It is now printed by the
    generator and says what the filter has to do with the chain.
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 26b9b5c1b2..137d24911a 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -5,7 +5,5 @@
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
     depends_on: @DEP@
     when:
-       - path:
-          include:
-            - "doc/po/@LANG@/*.po"
+      - path: *when_localized
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 86f9a75db0..51ee6147cc 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -32,6 +32,16 @@ variables:
         # Any localized assets
         - "doc/po/*/Makefile.in"
         - "doc/po/*/*.po"
+  # Every localized step shares this one filter on purpose. The localized steps are
+  # chained to each other to cap memory (see the generated section below), and
+  # Woodpecker rejects a whole pipeline when an included step depends on a step that
+  # its conditions filtered out. Per-language filters made that happen on every
+  # single-language translation commit, so the languages must be included or
+  # excluded together.
+  - &when_localized
+      include:
+        - "doc/po/*/Makefile.in"
+        - "doc/po/*/*.po"
 steps:
   prepare:
@@ -123,6 +133,9 @@ steps:
 ### TARGET check-xml
   # Localized check-xml steps are intentionally chained to cap memory per step; this is a memory-control
   # measure, not a dependency between languages. Breaking the chain restores the fan-out that caused the kills.
+  # The chain is why every localized step carries the same when_localized filter: Woodpecker refuses a whole
+  # pipeline when an included step depends on one its conditions filtered out, so the languages are included
+  # or excluded together. Per-language filters broke every single-language translation commit.
   check-xml-it_IT:
     image: *test_image
     pull: true
@@ -130,9 +143,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-xml
     depends_on: prepare
     when:
-       - path:
-          include:
-            - "doc/po/it_IT/*.po"
   check-xml-pt_BR:
     image: *test_image
@@ -141,9 +152,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     when:
-       - path:
-          include:
-            - "doc/po/pt_BR/*.po"
   check-xml-fr:
     image: *test_image
@@ -152,9 +161,7 @@ steps:
       - make -C build-docs/doc/po/fr local-check-xml
     depends_on: [ prepare, check-xml-pt_BR ]
     when:
-       - path:
-          include:
-            - "doc/po/fr/*.po"
   check-xml-es:
     image: *test_image
@@ -163,9 +170,7 @@ steps:
       - make -C build-docs/doc/po/es local-check-xml
     depends_on: [ prepare, check-xml-fr ]
     when:
-       - path:
-          include:
-            - "doc/po/es/*.po"
   check-xml-pl:
     image: *test_image
@@ -174,9 +179,7 @@ steps:
       - make -C build-docs/doc/po/pl local-check-xml
     depends_on: [ prepare, check-xml-es ]
     when:
-       - path:
-          include:
-            - "doc/po/pl/*.po"
   check-xml-ka:
     image: *test_image
@@ -185,9 +188,7 @@ steps:
       - make -C build-docs/doc/po/ka local-check-xml
     depends_on: [ prepare, check-xml-pl ]
     when:
-       - path:
-          include:
-            - "doc/po/ka/*.po"
   check-xml-ko_KR:
     image: *test_image
@@ -196,9 +197,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     depends_on: [ prepare, check-xml-ka ]
     when:
-       - path:
-          include:
-            - "doc/po/ko_KR/*.po"
   check-xml-da:
     image: *test_image
@@ -207,9 +206,7 @@ steps:
       - make -C build-docs/doc/po/da local-check-xml
     depends_on: [ prepare, check-xml-ko_KR ]
     when:
-       - path:
-          include:
-            - "doc/po/da/*.po"
   check-xml-de:
     image: *test_image
@@ -218,9 +215,7 @@ steps:
       - make -C build-docs/doc/po/de local-check-xml
     depends_on: [ prepare, check-xml-da ]
     when:
-       - path:
-          include:
-            - "doc/po/de/*.po"
   check-xml-ja:
     image: *test_image
@@ -229,9 +224,7 @@ steps:
       - make -C build-docs/doc/po/ja local-check-xml
     depends_on: [ prepare, check-xml-de ]
     when:
-       - path:
-          include:
-            - "doc/po/ja/*.po"
   check-xml-ru:
     image: *test_image
@@ -240,9 +233,7 @@ steps:
       - make -C build-docs/doc/po/ru local-check-xml
     depends_on: [ prepare, check-xml-ja ]
     when:
-       - path:
-          include:
-            - "doc/po/ru/*.po"
   check-xml-zh_Hans:
     image: *test_image
@@ -251,9 +242,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     depends_on: [ prepare, check-xml-ru ]
     when:
-       - path:
-          include:
-            - "doc/po/zh_Hans/*.po"
   check-xml-ro:
     image: *test_image
@@ -262,9 +251,7 @@ steps:
       - make -C build-docs/doc/po/ro local-check-xml
     depends_on: [ prepare, check-xml-zh_Hans ]
     when:
-       - path:
-          include:
-            - "doc/po/ro/*.po"
   check-xml-sv:
     image: *test_image
@@ -273,9 +260,7 @@ steps:
       - make -C build-docs/doc/po/sv local-check-xml
     depends_on: [ prepare, check-xml-ro ]
     when:
-       - path:
-          include:
-            - "doc/po/sv/*.po"
   check-xml-uk:
     image: *test_image
@@ -284,9 +269,7 @@ steps:
       - make -C build-docs/doc/po/uk local-check-xml
     depends_on: [ prepare, check-xml-sv ]
     when:
-       - path:
-          include:
-            - "doc/po/uk/*.po"
   check-xml-be:
     image: *test_image
@@ -295,11 +278,14 @@ steps:
       - make -C build-docs/doc/po/be local-check-xml
     depends_on: [ prepare, check-xml-uk ]
     when:
-       - path:
-          include:
-            - "doc/po/be/*.po"
 ### TARGET html
+  # Localized html steps are intentionally chained to cap memory per step; this is a memory-control
+  # measure, not a dependency between languages. Breaking the chain restores the fan-out that caused the kills.
   html-it_IT:
     image: *test_image
     pull: true
@@ -307,9 +293,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-html
     depends_on: check-xml-it_IT
     when:
-       - path:
-          include:
   html-pt_BR:
     image: *test_image
@@ -318,9 +302,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-html
     depends_on: [ check-xml-pt_BR, html-it_IT ]
     when:
-       - path:
-          include:
   html-fr:
     image: *test_image
@@ -329,9 +311,7 @@ steps:
       - make -C build-docs/doc/po/fr local-html
     depends_on: [ check-xml-fr, html-pt_BR ]
     when:
-       - path:
-          include:
   html-es:
     image: *test_image
@@ -340,9 +320,7 @@ steps:
       - make -C build-docs/doc/po/es local-html
     depends_on: [ check-xml-es, html-fr ]
     when:
-       - path:
-          include:
   html-pl:
     image: *test_image
@@ -351,9 +329,7 @@ steps:
       - make -C build-docs/doc/po/pl local-html
     depends_on: [ check-xml-pl, html-es ]
     when:
-       - path:
-          include:
   html-ka:
     image: *test_image
@@ -362,9 +338,7 @@ steps:
       - make -C build-docs/doc/po/ka local-html
     depends_on: [ check-xml-ka, html-pl ]
     when:
-       - path:
-          include:
   html-ko_KR:
     image: *test_image
@@ -373,9 +347,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-html
     depends_on: [ check-xml-ko_KR, html-ka ]
     when:
-       - path:
-          include:
   html-da:
     image: *test_image
@@ -384,9 +356,7 @@ steps:
       - make -C build-docs/doc/po/da local-html
     depends_on: [ check-xml-da, html-ko_KR ]
     when:
-       - path:
-          include:
   html-de:
     image: *test_image
@@ -395,9 +365,7 @@ steps:
       - make -C build-docs/doc/po/de local-html
     depends_on: [ check-xml-de, html-da ]
     when:
-       - path:
-          include:
   html-ja:
     image: *test_image
@@ -406,9 +374,7 @@ steps:
       - make -C build-docs/doc/po/ja local-html
     depends_on: [ check-xml-ja, html-de ]
     when:
-       - path:
-          include:
   html-ru:
     image: *test_image
@@ -417,9 +383,7 @@ steps:
       - make -C build-docs/doc/po/ru local-html
     depends_on: [ check-xml-ru, html-ja ]
     when:
-       - path:
-          include:
   html-zh_Hans:
     image: *test_image
@@ -428,9 +392,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-html
     depends_on: [ check-xml-zh_Hans, html-ru ]
     when:
-       - path:
-          include:
   html-ro:
     image: *test_image
@@ -439,9 +401,7 @@ steps:
       - make -C build-docs/doc/po/ro local-html
     depends_on: [ check-xml-ro, html-zh_Hans ]
     when:
-       - path:
-          include:
   html-sv:
     image: *test_image
@@ -450,9 +410,7 @@ steps:
       - make -C build-docs/doc/po/sv local-html
     depends_on: [ check-xml-sv, html-ro ]
     when:
-       - path:
-          include:
   html-uk:
     image: *test_image
@@ -461,9 +419,7 @@ steps:
       - make -C build-docs/doc/po/uk local-html
     depends_on: [ check-xml-uk, html-sv ]
     when:
-       - path:
-          include:
   html-be:
     image: *test_image
@@ -472,11 +428,14 @@ steps:
       - make -C build-docs/doc/po/be local-html
     depends_on: [ check-xml-be, html-uk ]
     when:
-       - path:
-          include:
 ### TARGET cheatsheets
+  # Localized cheatsheets steps are intentionally chained to cap memory per step; this is a memory-control
   cheatsheets-it_IT:
     image: *test_image
     pull: true
@@ -484,9 +443,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
-       - path:
-          include:
   cheatsheets-pt_BR:
     image: *test_image
@@ -495,9 +452,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     depends_on: [ check-xml-pt_BR, cheatsheets-it_IT ]
     when:
-       - path:
-          include:
   cheatsheets-fr:
     image: *test_image
@@ -506,9 +461,7 @@ steps:
       - make -C build-docs/doc/po/fr local-cheatsheets
     depends_on: [ check-xml-fr, cheatsheets-pt_BR ]
     when:
-       - path:
-          include:
   cheatsheets-es:
     image: *test_image
@@ -517,9 +470,7 @@ steps:
       - make -C build-docs/doc/po/es local-cheatsheets
     depends_on: [ check-xml-es, cheatsheets-fr ]
     when:
-       - path:
-          include:
   cheatsheets-pl:
     image: *test_image
@@ -528,9 +479,7 @@ steps:
       - make -C build-docs/doc/po/pl local-cheatsheets
     depends_on: [ check-xml-pl, cheatsheets-es ]
     when:
-       - path:
-          include:
   cheatsheets-ka:
     image: *test_image
@@ -539,9 +488,7 @@ steps:
       - make -C build-docs/doc/po/ka local-cheatsheets
     depends_on: [ check-xml-ka, cheatsheets-pl ]
     when:
-       - path:
-          include:
   cheatsheets-ko_KR:
     image: *test_image
@@ -550,9 +497,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     depends_on: [ check-xml-ko_KR, cheatsheets-ka ]
     when:
-       - path:
-          include:
   cheatsheets-da:
     image: *test_image
@@ -561,9 +506,7 @@ steps:
       - make -C build-docs/doc/po/da local-cheatsheets
     depends_on: [ check-xml-da, cheatsheets-ko_KR ]
     when:
-       - path:
-          include:
   cheatsheets-de:
     image: *test_image
@@ -572,9 +515,7 @@ steps:
       - make -C build-docs/doc/po/de local-cheatsheets
     depends_on: [ check-xml-de, cheatsheets-da ]
     when:
-       - path:
-          include:
   cheatsheets-ja:
     image: *test_image
@@ -583,9 +524,7 @@ steps:
       - make -C build-docs/doc/po/ja local-cheatsheets
     depends_on: [ check-xml-ja, cheatsheets-de ]
     when:
-       - path:
-          include:
   cheatsheets-ru:
     image: *test_image
@@ -594,9 +533,7 @@ steps:
       - make -C build-docs/doc/po/ru local-cheatsheets
     depends_on: [ check-xml-ru, cheatsheets-ja ]
     when:
-       - path:
-          include:
   cheatsheets-zh_Hans:
     image: *test_image
@@ -605,9 +542,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     depends_on: [ check-xml-zh_Hans, cheatsheets-ru ]
     when:
-       - path:
-          include:
   cheatsheets-ro:
     image: *test_image
@@ -616,9 +551,7 @@ steps:
       - make -C build-docs/doc/po/ro local-cheatsheets
     depends_on: [ check-xml-ro, cheatsheets-zh_Hans ]
     when:
-       - path:
-          include:
   cheatsheets-sv:
     image: *test_image
@@ -627,9 +560,7 @@ steps:
       - make -C build-docs/doc/po/sv local-cheatsheets
     depends_on: [ check-xml-sv, cheatsheets-ro ]
     when:
-       - path:
-          include:
   cheatsheets-uk:
     image: *test_image
@@ -638,9 +569,7 @@ steps:
       - make -C build-docs/doc/po/uk local-cheatsheets
     depends_on: [ check-xml-uk, cheatsheets-sv ]
     when:
-       - path:
-          include:
   cheatsheets-be:
     image: *test_image
@@ -649,11 +578,14 @@ steps:
       - make -C build-docs/doc/po/be local-cheatsheets
     depends_on: [ check-xml-be, cheatsheets-uk ]
     when:
-       - path:
-          include:
 ### TARGET check-cheatsheets
+  # Localized check-cheatsheets steps are intentionally chained to cap memory per step; this is a memory-control
   check-cheatsheets-it_IT:
     image: *test_image
     pull: true
@@ -661,9 +593,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
     depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
-       - path:
-          include:
   check-cheatsheets-pt_BR:
     image: *test_image
@@ -672,9 +602,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     depends_on: [ cheatsheets-pt_BR, build-cheatsheets, check-cheatsheets-it_IT ]
     when:
-       - path:
-          include:
   check-cheatsheets-fr:
     image: *test_image
@@ -683,9 +611,7 @@ steps:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     depends_on: [ cheatsheets-fr, build-cheatsheets, check-cheatsheets-pt_BR ]
     when:
-       - path:
-          include:
   check-cheatsheets-es:
     image: *test_image
@@ -694,9 +620,7 @@ steps:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     depends_on: [ cheatsheets-es, build-cheatsheets, check-cheatsheets-fr ]
     when:
-       - path:
-          include:
   check-cheatsheets-pl:
     image: *test_image
@@ -705,9 +629,7 @@ steps:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     depends_on: [ cheatsheets-pl, build-cheatsheets, check-cheatsheets-es ]
     when:
-       - path:
-          include:
   check-cheatsheets-ka:
     image: *test_image
@@ -716,9 +638,7 @@ steps:
       - make -C build-docs/doc/po/ka local-check-cheatsheets
     depends_on: [ cheatsheets-ka, build-cheatsheets, check-cheatsheets-pl ]
     when:
-       - path:
-          include:
   check-cheatsheets-ko_KR:
     image: *test_image
@@ -727,9 +647,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     depends_on: [ cheatsheets-ko_KR, build-cheatsheets, check-cheatsheets-ka ]
     when:
-       - path:
-          include:
   check-cheatsheets-da:
     image: *test_image
@@ -738,9 +656,7 @@ steps:
       - make -C build-docs/doc/po/da local-check-cheatsheets
     depends_on: [ cheatsheets-da, build-cheatsheets, check-cheatsheets-ko_KR ]
     when:
-       - path:
-          include:
   check-cheatsheets-de:
     image: *test_image
@@ -749,9 +665,7 @@ steps:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     depends_on: [ cheatsheets-de, build-cheatsheets, check-cheatsheets-da ]
     when:
-       - path:
-          include:
   check-cheatsheets-ja:
     image: *test_image
@@ -760,9 +674,7 @@ steps:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     depends_on: [ cheatsheets-ja, build-cheatsheets, check-cheatsheets-de ]
     when:
-       - path:
-          include:
   check-cheatsheets-ru:
     image: *test_image
@@ -771,9 +683,7 @@ steps:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     depends_on: [ cheatsheets-ru, build-cheatsheets, check-cheatsheets-ja ]
     when:
-       - path:
-          include:
   check-cheatsheets-zh_Hans:
     image: *test_image
@@ -782,9 +692,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     depends_on: [ cheatsheets-zh_Hans, build-cheatsheets, check-cheatsheets-ru ]
     when:
-       - path:
-          include:
   check-cheatsheets-ro:
     image: *test_image
@@ -793,9 +701,7 @@ steps:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     depends_on: [ cheatsheets-ro, build-cheatsheets, check-cheatsheets-zh_Hans ]
     when:
-       - path:
-          include:
   check-cheatsheets-sv:
     image: *test_image
@@ -804,9 +710,7 @@ steps:
       - make -C build-docs/doc/po/sv local-check-cheatsheets
     depends_on: [ cheatsheets-sv, build-cheatsheets, check-cheatsheets-ro ]
     when:
-       - path:
-          include:
   check-cheatsheets-uk:
     image: *test_image
@@ -815,9 +719,7 @@ steps:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
     depends_on: [ cheatsheets-uk, build-cheatsheets, check-cheatsheets-sv ]
     when:
-       - path:
-          include:
   check-cheatsheets-be:
     image: *test_image
@@ -826,6 +728,4 @@ steps:
       - make -C build-docs/doc/po/be local-check-cheatsheets
     depends_on: [ cheatsheets-be, build-cheatsheets, check-cheatsheets-uk ]
     when:
-       - path:
-          include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index e2409df615..39d34a88a4 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -16,6 +16,14 @@ exec >> docs.yml.new
 for target in ${TARGETS}
 do
   echo "### TARGET ${target}"
+  # This comment has to be printed, not written into docs.yml by hand: everything
+  # past the DO NOT EDIT line is regenerated, so a warning left there is deleted by
+  # the next run of this script.
+  echo "  # Localized ${target} steps are intentionally chained to cap memory per step; this is a memory-control"
+  echo "  # measure, not a dependency between languages. Breaking the chain restores the fan-out that caused the kills."
+  echo "  # The chain is why every localized step carries the same when_localized filter: Woodpecker refuses a whole"
+  echo "  # pipeline when an included step depends on one its conditions filtered out, so the languages are included"
+  echo "  # or excluded together. Per-language filters broke every single-language translation commit."
   previous_step=
   for lang in ${SUPPORTED_LANGUAGES};
   do
Summary of changes:
 .woodpecker/docs-localized.yml.in    |   4 +-
 .woodpecker/docs.yml                 | 284 ++++++++++++-----------------------
 .woodpecker/update-docs-localized.sh |   8 +
 3 files changed, 101 insertions(+), 195 deletions(-)
hooks/post-receive
