[SCM] PostGIS branch master updated. 3.7.0beta1-215-g59dce1353c
Mon Aug 3 14:45:35 PDT 2026
the project "PostGIS".
       via  59dce1353cc498bb657b19336ed4e6622fcfb873 (commit)
       via  2dd8052b88e9aed59dfa9e2f72bfa09ec75830d7 (commit)
      from  beac83bc71bd7442b69da1053f6b1aab98fffa0f (commit)
revisions in full, below.
commit 59dce1353cc498bb657b19336ed4e6622fcfb873
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 3 17:45:27 2026 -0400
    Only run mingw-wine,portability during tag, cron events
diff --git a/.woodpecker/mingw-wine.yml b/.woodpecker/mingw-wine.yml
index ed79a30953..94b427d5c4 100644
--- a/.woodpecker/mingw-wine.yml
+++ b/.woodpecker/mingw-wine.yml
@@ -1,7 +1,7 @@
 labels:
   platform: linux/amd64
 when:
-  event: [push, pull_request, tag]
+  event: [tag]
 clone:
   git:
diff --git a/.woodpecker/portability.yml b/.woodpecker/portability.yml
index d6aa7accb1..5e9b3bf867 100644
--- a/.woodpecker/portability.yml
+++ b/.woodpecker/portability.yml
@@ -2,7 +2,7 @@ labels:
   qemu: "true"
 when:
-  event: [push, pull_request, tag, cron]
+  event: [tag, cron]
 # This workflow keeps the existing amd64 CI honest by attacking ABI properties
 # that normal amd64 builds cannot falsify.
commit 2dd8052b88e9aed59dfa9e2f72bfa09ec75830d7
Date:   Mon Aug 3 16:32:12 2026 -0400
    Schema qualify all references to pg_catalog and postgis
     - geometry_columns view
     - geography_columns view
diff --git a/NEWS b/NEWS
index 65e6328bc5..11dd7c99e9 100644
--- a/NEWS
+++ b/NEWS
@@ -40,6 +40,8 @@ These are only changes since 3.7.0beta1.
  - #6109, Out-of-bounds heap read in BOX2D_out and BOX2D_expand
    on 65-byte box2d under ASAN (Dennis Tighe, Google)
  - #6110, regression in speed with geometry_columns (Regina Obe)
+ - Schema qualify references to pg_catalog and postgis
+   in geometry_columns and geography_columns views (Regina Obe)
 * Enhancements *
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index edfd09d424..e7c1f5d32b 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -166,22 +166,22 @@ CREATE OR REPLACE VIEW geography_columns AS
 		n.nspname AS f_table_schema,
 		c.relname AS f_table_name,
 		a.attname AS f_geography_column,
-		postgis_typmod_dims(a.atttypmod) AS coord_dimension,
-		postgis_typmod_srid(a.atttypmod) AS srid,
-		postgis_typmod_type(a.atttypmod) AS type
+		@extschema at .postgis_typmod_dims(a.atttypmod) AS coord_dimension,
+		@extschema at .postgis_typmod_srid(a.atttypmod) AS srid,
+		@extschema at .postgis_typmod_type(a.atttypmod) AS type
 	FROM
-		pg_class c,
-		pg_attribute a,
-		pg_type t,
-		pg_namespace n
-	WHERE t.typname = 'geography'
-		AND a.attisdropped = false
-		AND a.atttypid = t.oid
-		AND a.attrelid = c.oid
-		AND c.relnamespace = n.oid
-		AND c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"] )
+		pg_catalog.pg_class c,
+		pg_catalog.pg_attribute a,
+		pg_catalog.pg_type t,
+		pg_catalog.pg_namespace n
+	WHERE t.typname OPERATOR(pg_catalog.=) 'geography'::pg_catalog.name
+		AND a.attisdropped OPERATOR(pg_catalog.=) false
+		AND a.atttypid OPERATOR(pg_catalog.=) t.oid
+		AND a.attrelid OPERATOR(pg_catalog.=) c.oid
+		AND c.relnamespace OPERATOR(pg_catalog.=) n.oid
+		AND c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['r'::pg_catalog."char", 'v'::pg_catalog."char", 'm'::pg_catalog."char", 'f'::pg_catalog."char", 'p'::pg_catalog."char"] )
 		AND NOT pg_catalog.pg_is_other_temp_schema(c.relnamespace)
-		AND pg_catalog.has_column_privilege(c.oid, a.attname,'SELECT'::text);
+		AND pg_catalog.has_column_privilege(c.oid, a.attname, 'SELECT'::pg_catalog.text);
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION geography(geometry)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 57088ad4d7..1df0e2b0bf 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6709,95 +6709,95 @@ WITH constraint_defs AS NOT MATERIALIZED (
     SELECT connamespace,
            conrelid,
            conkey,
-           regexp_replace(pg_get_constraintdef(oid), $$\s+NOT\s+VALID$$, '', 'i') AS consrc
-      FROM pg_constraint
+           pg_catalog.regexp_replace(pg_catalog.pg_get_constraintdef(oid), $$\s+NOT\s+VALID$$, '', 'i') AS consrc
+      FROM pg_catalog.pg_constraint
-SELECT current_database()::character varying(256) AS f_table_catalog,
+SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog,
     a.attname AS f_geometry_column,
-    COALESCE(postgis_typmod_dims(a.atttypmod), sn.ndims, 2) AS coord_dimension,
-    COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), sr.srid, 0) AS srid,
-    replace(replace(COALESCE(NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::text), st.type, 'GEOMETRY'::text), 'ZM'::text, ''::text), 'Z'::text, ''::text)::character varying(30) AS type
-   FROM pg_class c
-     JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
-     JOIN pg_namespace n ON c.relnamespace = n.oid
-     JOIN pg_type t ON a.atttypid = t.oid
+    COALESCE(@extschema at .postgis_typmod_dims(a.atttypmod), sn.ndims, 2) AS coord_dimension,
+    COALESCE(NULLIF(@extschema at .postgis_typmod_srid(a.atttypmod), 0), sr.srid, 0) AS srid,
+    pg_catalog.replace(pg_catalog.replace(COALESCE(NULLIF(pg_catalog.upper(@extschema at .postgis_typmod_type(a.atttypmod)), 'GEOMETRY'::pg_catalog.text), st.type, 'GEOMETRY'::pg_catalog.text), 'ZM'::pg_catalog.text, ''::pg_catalog.text), 'Z'::pg_catalog.text, ''::pg_catalog.text)::pg_catalog.varchar(30) AS type
+   FROM pg_catalog.pg_class c
+     JOIN pg_catalog.pg_attribute a ON a.attrelid OPERATOR(pg_catalog.=) c.oid AND NOT a.attisdropped
+     JOIN pg_catalog.pg_namespace n ON c.relnamespace OPERATOR(pg_catalog.=) n.oid
+     JOIN pg_catalog.pg_type t ON a.atttypid OPERATOR(pg_catalog.=) t.oid
      -- Direct view columns have rewrite-rule target entries with origin metadata.
      -- Use only top-level bare VAR target entries, so expressions keep needing explicit casts.
      LEFT JOIN LATERAL (
            SELECT origin.base_relid,
                   origin.base_attnum
-             FROM pg_rewrite AS r
-             CROSS JOIN LATERAL _postgis_geometry_columns_view_column_origin(r.ev_action, a.attnum) AS origin
-            WHERE c.relkind = ANY (ARRAY['v'::"char", 'm'::"char"])
-              AND r.ev_class = c.oid
-              AND r.rulename = '_RETURN'
+             FROM pg_catalog.pg_rewrite AS r
+             CROSS JOIN LATERAL @extschema at ._postgis_geometry_columns_view_column_origin(r.ev_action, a.attnum) AS origin
+            WHERE c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['v'::pg_catalog."char", 'm'::pg_catalog."char"])
+              AND r.ev_class OPERATOR(pg_catalog.=) c.oid
+              AND r.rulename OPERATOR(pg_catalog.=) '_RETURN'
      ) AS vco ON true
      LEFT JOIN (
            SELECT s.connamespace,
                   s.conrelid,
                   s.conkey,
-                  (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
+                  (pg_catalog.regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::pg_catalog.text AS type
              FROM constraint_defs AS s
-            WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
-     ) st ON st.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (st.conkey))
+            WHERE s.consrc OPERATOR(pg_catalog.~*) $$geometrytype\(\w+\)\s*=\s*'\w+'$$::pg_catalog.text
+     ) st ON st.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (st.conkey))
      LEFT JOIN (
                   s.conrelid,
                   s.conkey,
-                  (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
+                  (pg_catalog.regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
-            WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
-     ) sn ON sn.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (sn.conkey))
+            WHERE s.consrc OPERATOR(pg_catalog.~*) $$ndims\(\w+\)\s*=\s*\d+$$::pg_catalog.text
+     ) sn ON sn.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (sn.conkey))
      LEFT JOIN (
                   s.conrelid,
                   s.conkey,
-                  (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
+                  (pg_catalog.regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
-            WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
-     ) sr ON sr.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (sr.conkey))
-  WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
-  AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
-  AND NOT pg_is_other_temp_schema(c.relnamespace)
+            WHERE s.consrc OPERATOR(pg_catalog.~*) $$srid\(\w+\)\s*=\s*\d+$$::pg_catalog.text
+     ) sr ON sr.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (sr.conkey))
+  WHERE (c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['r'::pg_catalog."char", 'v'::pg_catalog."char", 'm'::pg_catalog."char", 'f'::pg_catalog."char", 'p'::pg_catalog."char"]))
+  AND NOT c.relname OPERATOR(pg_catalog.=) 'raster_columns'::pg_catalog.name AND t.typname OPERATOR(pg_catalog.=) 'geometry'::pg_catalog.name
+  AND NOT pg_catalog.pg_is_other_temp_schema(c.relnamespace)
   -- A stale MVCC snapshot can still see a dropped pg_class row (#6038).
   -- Re-resolve the qualified relation name only when the schema is visible,
   -- because to_regclass reports permission errors for inaccessible schemas.
   -- Without schema visibility, keep the old OID-based privilege semantics.
   -- Keep the visible-schema SELECT check in the same CASE branch as the
   -- re-resolution guard so PostgreSQL cannot evaluate it for a stale OID.
-  AND CASE WHEN has_schema_privilege(c.relnamespace, 'USAGE'::text)
-           THEN CASE WHEN pg_catalog.to_regclass(pg_catalog.format('%I.%I', n.nspname, c.relname)) = c.oid
-                     THEN pg_catalog.has_column_privilege(c.oid, a.attname, 'SELECT'::text)
+  AND CASE WHEN pg_catalog.has_schema_privilege(c.relnamespace, 'USAGE'::pg_catalog.text)
+           THEN CASE WHEN pg_catalog.to_regclass(pg_catalog.format('%I.%I', n.nspname, c.relname)) OPERATOR(pg_catalog.=) c.oid
+                     THEN pg_catalog.has_column_privilege(c.oid, a.attname, 'SELECT'::pg_catalog.text)
                      ELSE false
                 END
-           ELSE pg_catalog.has_column_privilege(c.oid, a.attname, 'SELECT'::text)
+           ELSE pg_catalog.has_column_privilege(c.oid, a.attname, 'SELECT'::pg_catalog.text)
       END
   AND (
     EXISTS (
       SELECT 1
-      FROM pg_roles
-      WHERE rolname = current_user
+      FROM pg_catalog.pg_roles
+      WHERE rolname OPERATOR(pg_catalog.=) current_user
         AND rolsuper
     OR EXISTS (
       SELECT 1
-      FROM pg_roles
-      WHERE rolname = 'pg_read_all_data'
-        AND pg_has_role(current_user, oid, 'USAGE')
+      WHERE rolname OPERATOR(pg_catalog.=) 'pg_read_all_data'
+        AND pg_catalog.pg_has_role(current_user, oid, 'USAGE')
     OR EXISTS (
       SELECT 1
-      FROM aclexplode(COALESCE(c.relacl, acldefault('r', c.relowner))) AS acl
-      WHERE acl.privilege_type = 'SELECT'
-        AND (acl.grantee = 0 OR pg_has_role(acl.grantee, 'USAGE'))
+      FROM pg_catalog.aclexplode(COALESCE(c.relacl, pg_catalog.acldefault('r', c.relowner))) AS acl
+      WHERE acl.privilege_type OPERATOR(pg_catalog.=) 'SELECT'
+        AND (acl.grantee OPERATOR(pg_catalog.=) 0 OR pg_catalog.pg_has_role(acl.grantee, 'USAGE'))
     OR EXISTS (
       SELECT 1
-      FROM aclexplode(a.attacl) AS acl
+      FROM pg_catalog.aclexplode(a.attacl) AS acl
Summary of changes:
 .woodpecker/mingw-wine.yml  |  2 +-
 .woodpecker/portability.yml |  2 +-
 NEWS                        |  2 ++
 postgis/geography.sql.in    | 28 +++++++--------
 postgis/postgis.sql.in      | 84 ++++++++++++++++++++++-----------------------
 5 files changed, 60 insertions(+), 58 deletions(-)
hooks/post-receive
