[SCM] PostGIS branch master updated. 3.7.0beta1-229-g69521e4737
Wed Aug 5 00:39:15 PDT 2026
the project "PostGIS".
       via  69521e47372defbc6e4c0a68d619befa353c7319 (commit)
      from  4d5bedcf352f950ed8a55e19baf5fb0729b5a6b5 (commit)
revisions in full, below.
commit 69521e47372defbc6e4c0a68d619befa353c7319
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Wed Aug 5 07:19:27 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 90.6% (5473 of 6037 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 1e5aebdf0b..99525d0149 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-05 05:39+0000\n"
+"PO-Revision-Date: 2026-08-05 07:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -17794,6 +17794,8 @@ msgid ""
 "The cells are returned together so their relative sizes remain visible in a "
 "shared coordinate frame."
 msgstr ""
+"セルがまとめて返るので、相対サイズを共通の座標フレーム内で見ることができます"
 #. Tag: para
 #, no-c-format
@@ -22538,6 +22540,11 @@ msgid ""
 "literal> prefix used for <type>bytea</type> display. Specifying "
 "<literal>NDR</literal> makes the byte order deterministic."
 msgstr ""
+"PostgreSQLの <link xlink:href=\"https://www.postgresql.jp/document/current/"
+"html/functions-binarystring.html\"><function>encode</function></link> 関数で"
+"、 <type>bytea</type> 表示に使われる <literal>\\x</literal> が無い 16進数 "
+"WKB 文字列を作ります。<literal>NDR</literal> などを指定することで"
+"バイトオーダーを決定します。"
 #. Tag: para
 #, no-c-format
@@ -22635,6 +22642,10 @@ msgid ""
 "after multiplying coordinates by 10 raised to the requested "
 "<varname>precision</varname>."
 msgstr ""
+"<link xlink:href=\"https://developers.google.com/maps/documentation/"
+"utilities/polylinealgorithm\">Encoded Polyline Algorithm Format</link> による"
+"ジオメトリーを返します。書式は 10の <varname>precision</varname> 乗を掛けてか"
+"ら、緯度、経度、これらの差分を整数で保存します。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 13 ++++++++++++-
 1 file changed, 12 insertions(+), 1 deletion(-)
hooks/post-receive
