[SCM] PostGIS branch master updated. 3.7.0beta1-242-gd44fea5336
git at osgeo.org
git at osgeo.org
Sat Aug 8 01:33:47 PDT 2026
the project "PostGIS".
via d44fea5336f85fde27e59e4bd82d210a6c671f80 (commit)
via 491813e413afff546779b988e79ad7eb20559c46 (commit)
from 14f1002deb9776219ad069045daec1fe7f5173fc (commit)
revisions in full, below.
commit d44fea5336f85fde27e59e4bd82d210a6c671f80
Merge: 14f1002deb 491813e413
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 8 01:33:46 2026 -0700
Merge pull request 'liblwgeom: reject truncated encoded polylines' (!667) from Komzpa/postgis:fix/encoded-polyline-bounds-540137187 into master
## Summary
Reject truncated encoded polyline input before `lwgeom_from_encoded_polyline`
reads beyond the supplied string.
The decoder now checks bounds for both coordinate varints and reports malformed
input. The new CUnit cases cover a missing longitude and an unterminated
latitude varint.
## Validation
- `make -C liblwgeom -j32`
- `make -C liblwgeom/cunit -j32 cu_tester`
- `./liblwgeom/cunit/cu_tester encoded_polyline_input`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/667
commit 491813e413afff546779b988e79ad7eb20559c46
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 8 12:22:14 2026 +0400
fix(liblwgeom): reject truncated encoded polylines
diff --git a/NEWS b/NEWS
index 6f297904d6..0bb868dbe9 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,8 @@ These are only changes since 3.7.0beta1.
where it could deadlock with autovacuum (Darafei Praliaskouski)
- [liblwgeom] Reject malformed GSERIALIZED NURBS before curve
evaluation (Darafei Praliaskouski)
+ - OSSFuzz 5877056525893632, reject truncated encoded polyline input
+ (Darafei Praliaskouski)
- GT-619, Make interrupt regression tests compare timeout latency to
same-machine uninterrupted runtime, avoiding false failures under
slow CI load (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_in_encoded_polyline.c b/liblwgeom/cunit/cu_in_encoded_polyline.c
index 6af16b9a23..9cd4a7e1fe 100644
--- a/liblwgeom/cunit/cu_in_encoded_polyline.c
+++ b/liblwgeom/cunit/cu_in_encoded_polyline.c
@@ -62,6 +62,13 @@ static void in_encoded_polyline_test_close_points(void)
"SRID=4326;LINESTRING(38.903876 55.336448,38.903875 55.336448)");
+static void in_encoded_polyline_test_truncated_input(void)
+ /* A latitude without a longitude and an unterminated latitude varint. */
+ CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("A", 5));
+ CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("`", 5));
** Used by test harness to register the tests in this file.
@@ -72,4 +79,5 @@ void in_encoded_polyline_suite_setup(void)
PG_ADD_TEST(suite, in_encoded_polyline_test_geoms);
PG_ADD_TEST(suite, in_encoded_polyline_test_precision);
PG_ADD_TEST(suite, in_encoded_polyline_test_close_points);
+ PG_ADD_TEST(suite, in_encoded_polyline_test_truncated_input);
diff --git a/liblwgeom/lwin_encoded_polyline.c b/liblwgeom/lwin_encoded_polyline.c
index 2bb9f73417..d1af103eab 100644
--- a/liblwgeom/lwin_encoded_polyline.c
+++ b/liblwgeom/lwin_encoded_polyline.c
@@ -29,6 +29,7 @@
#include <stdint.h>
#include "liblwgeom.h"
+#include "lwgeom_log.h"
#include "../postgis_config.h"
LWGEOM*
@@ -52,6 +53,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
int res = 0;
char shift = 0;
do {
+ if (idx >= length) {
+ lwerror("lwgeom_from_encoded_polyline: input is truncated");
+ ptarray_free(pa);
+ return NULL;
byte = encodedpolyline[idx++] - 63;
res |= (byte & 0x1F) << shift;
shift += 5;
@@ -62,6 +68,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
shift = 0;
res = 0;
do {
+ ptarray_free(pa);
+ return NULL;
shift += 5;
Summary of changes:
NEWS | 2 ++
liblwgeom/cunit/cu_in_encoded_polyline.c | 8 ++++++++
liblwgeom/lwin_encoded_polyline.c | 11 +++++++++++
3 files changed, 21 insertions(+)
hooks/post-receive
