[SCM] PostGIS branch master updated. 3.7.0beta1-246-g39bf9d6a75
Sat Aug 8 22:06:19 PDT 2026
the project "PostGIS".
       via  39bf9d6a75e43a9c75f7b06ed23facb8f4ea3edd (commit)
       via  6e70ac547130f53432bd174a19a755f6d5ceca4f (commit)
      from  239c3ddb0370b02d2dabda0aafa31dc35423bed0 (commit)
revisions in full, below.
commit 39bf9d6a75e43a9c75f7b06ed23facb8f4ea3edd
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 9 01:06:01 2026 -0400
    Prep for 3.7.0beta2 release
diff --git a/NEWS b/NEWS
index 0d9e68a988..fb04f30d07 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.7.0beta2
-2026/xx/xx
+2026/08/08
 This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp.
 To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
 To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
@@ -175,13 +175,9 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
  - #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
  - #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
- - #5950, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)
- - #4332, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)
  - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
- - #5109, Document the meaning of topology.next_left_edge and topology.next_right_edge links (Darafei Praliaskouski)
  - #5889, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)
  - #2614, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)
- - #6022, Document ST_AsMVTGeom tile-coordinate simplification (Darafei Praliaskouski)
  - GH-839, ST_Multi support for TIN and surfaces (Loïc Bartoletti)
  - #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
  - #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
@@ -189,13 +185,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GT-270, Add NURBSCurve (Loïc Bartoletti)
  - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
- - [fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts,
-          prefer requested CXX over pg_config --cc for internal C++ checks, and
-          make fuzzer linking/runtime dependency packaging portable
-          (Darafei Praliaskouski)
- - #1416, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve
-          and linearizes other curve geometries
 * Enhancements *
  - #2045, pgsql2shp query dumps no longer require temporary table
@@ -204,31 +193,21 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           to open shapefile sidecar files (Darafei Praliaskouski)
  - #3158, Move geometry and geography typmod bit helpers out of the
           public liblwgeom header (Darafei Praliaskouski)
+ - #3776, [raster] Keep distinct 32-bit integer pixel values separate in
+          ST_DumpAsPolygons (Darafei Praliaskouski)
  - #4678, [raster] Move st_sum4ma neighborhood callback to C
  - #2116, [raster] Add ST_Value nearest-neighbor boundary options
  - #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
           and pass callback call data as actual arguments (Darafei Praliaskouski)
- - #2898, Document SQL function cost tiers for contributors
- - #5638, Move and reorganize developer, maintainer, governance,
-          website, internals, style, release-process, Trac wiki, and
-          postgis.net documentation into doc/
  - #6062, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)
  - #6065, Improved winding order computation robustness for rings having collapsed elements
           (Sandro Santilli)
- - #3743, #4385, [raster loader] Document raster2pgsql -s FROM_SRID:SRID
-          reprojection support and clarify index creation timing for append loads
  - #2137, [raster] Reuse matching source raster overviews in raster2pgsql -l
  - #4749, Use point-in-polygon predicate fast paths for point-only
           GeometryCollections (Darafei Praliaskouski)
- - #5532, Validate the manual against DocBook XMLSchema in check-xml
- - #6087, Add a repository-owned CI status checker and static dashboard
-          generator (Darafei Praliaskouski)
  - #2807, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs
  - #2832, [raster] Avoid padding single-tile raster2pgsql overviews
@@ -237,7 +216,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           shapefiles (Darafei Praliaskouski)
  - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
- - #2386, Add raster2pgsql man page (Darafei Praliaskouski)
  - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
           available so LTO can optimize same-DSO calls to exported PostGIS
           entry points directly instead of routing through the module PLT; in
@@ -249,13 +227,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #2808, Clarify postgis_full_version() output when installed component
           scripts are newer than core scripts (Darafei Praliaskouski)
- - #5593, Docs: render manual images with GraphicsMagick without temporary files,
-          enabling parallel builds, keeping ImageMagick fallbacks working, and
-          documenting the generator workflow for contributors (Darafei Praliaskouski)
- - #5645, Docs: keep code operators ("=>") intact in translated manuals
-          by enforcing verbatim CSS (Darafei Praliaskouski)
- - #1408, Docs: flatten transparent manual images onto white backgrounds for
-          PDF builds while keeping HTML images transparent (Darafei Praliaskouski)
  - #2838, Emit valid X3D Coordinate nodes for 2D polygon output
  - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
@@ -268,16 +239,12 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
- - GH-1161, Render manual geometry examples as build-time SVG in HTML
-          and PDF (Darafei Praliaskouski)
           GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)
  - #3676, Mark geometry and geography btree comparison support functions
           as leakproof (Darafei Praliaskouski)
  - GH-875, Allow ST_OrderingEquals joins to use hash and merge join plans
- - #2557, #2805, Document ST_MapAlgebra callback argument
-          signatures and return semantics (Darafei Praliaskouski)
  - #1168, [raster] Support curved geometry inputs in ST_AsRaster
@@ -285,6 +252,11 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #3705, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries
           and GeometryCollections (Darafei Praliaskouski)
+ - GT-484, Use column-level SELECT privileges for metadata views
+          (Arthur Bazin)
+ - #1408, #2386, #2557, #2805, #2898, #3743, #4323, #4332, #4385, #5109,
+          #5532, #5593, #5638, #5645, #5950, #6022, #6082, GH-1161, GT-584,
+          Numerous doc enhancements (Darafei Praliaskouski)
 * Bug Fixes *
@@ -298,8 +270,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #5904, [topology] Avoid MinGW format warnings when logging topology ids
- - #6082, Fix Japanese PDF build by avoiding non-ASCII arrows in SQL
-          program listings (Darafei Praliaskouski)
  - GH-888, [sfcgal] Avoid stale detoasted geometry access in
           CG_Visibility empty-input handling for SFCGAL < 2.2
diff --git a/Version.config b/Version.config
index 5576a8572d..d5b81dda4f 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=7
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0beta2
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
commit 6e70ac547130f53432bd174a19a755f6d5ceca4f
Date:   Sat Aug 8 23:34:25 2026 -0400
    More work on geometry_columns
    - Get rid of aliases and just call the CTE s
    - Prefilter for only check constraints
    - reduce the timing on the tests and add partitioned table to the test
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index cd8cc4cb8d..5b77260c1a 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6611,13 +6611,14 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 -- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
 CREATE OR REPLACE VIEW geometry_columns AS
-WITH constraint_defs AS NOT MATERIALIZED (
+WITH s AS NOT MATERIALIZED (
     -- Trim trailing NOT VALID so metadata inference works before constraint validation (#4828).
     SELECT connamespace,
            conrelid,
            conkey,
            pg_catalog.regexp_replace(pg_catalog.pg_get_constraintdef(oid), $$\s+NOT\s+VALID$$, '', 'i') AS consrc
       FROM pg_catalog.pg_constraint
+			WHERE contype OPERATOR(pg_catalog.=) 'c'::pg_catalog."char"
 SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog,
     n.nspname AS f_table_schema,
@@ -6635,7 +6636,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
                   s.conrelid,
                   s.conkey,
                   (pg_catalog.regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::pg_catalog.text AS type
-             FROM constraint_defs AS s
+             FROM s
             WHERE s.consrc OPERATOR(pg_catalog.~*) $$geometrytype\(\w+\)\s*=\s*'\w+'$$::pg_catalog.text
      ) st ON st.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (st.conkey))
      LEFT JOIN (
@@ -6643,7 +6644,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
                   s.conrelid,
                   s.conkey,
                   (pg_catalog.regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
+             FROM s
             WHERE s.consrc OPERATOR(pg_catalog.~*) $$ndims\(\w+\)\s*=\s*\d+$$::pg_catalog.text
      ) sn ON sn.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (sn.conkey))
      LEFT JOIN (
@@ -6651,7 +6652,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
                   s.conrelid,
                   s.conkey,
                   (pg_catalog.regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
+             FROM s
             WHERE s.consrc OPERATOR(pg_catalog.~*) $$srid\(\w+\)\s*=\s*\d+$$::pg_catalog.text
      ) sr ON sr.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (sr.conkey))
   WHERE (c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['r'::pg_catalog."char", 'v'::pg_catalog."char", 'm'::pg_catalog."char", 'f'::pg_catalog."char", 'p'::pg_catalog."char"]))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 80eb6d8b24..a7d47d5e60 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1844,13 +1844,13 @@ DECLARE
     n bigint;
     tolerance interval;
 BEGIN
-    tolerance := interval '2 seconds' * COALESCE(
+    tolerance := interval '0.25 seconds' * COALESCE(
         NULLIF(current_setting('test.executor_slow_factor', true), ''), '1'
     )::double precision;
     SELECT count(*) INTO n FROM geometry_columns
       WHERE f_table_schema = 'test6110';
-    IF n <> 1000 THEN
+    IF n <> 1501 THEN
         RETURN 'FAIL: count=' || n || ' (expected 1000)';
     END IF;
@@ -1871,11 +1871,14 @@ $$ LANGUAGE plpgsql;
 DO $$
 DECLARE i integer;
 BEGIN
+		CREATE TABLE test6110.typmod_partition(id bigint, geom geometry(LINESTRING, 4269), part_key integer, CONSTRAINT pk_typmod_partition PRIMARY KEY(id, part_key))
+			PARTITION BY LIST (part_key);
     FOR i IN 1..500 LOOP
         EXECUTE format('CREATE TABLE test6110.typmod_%s (geom geometry(Point, 4326))', i);
         EXECUTE format('CREATE TABLE test6110.constraint_%s (id integer)', i);
         EXECUTE format('SELECT AddGeometryColumn(%L, %L, %L, 4326, %L, 2, false)',
                        'test6110', 'constraint_' || i, 'geom', 'POINT');
+				EXECUTE format('CREATE TABLE test6110.partition_%s PARTITION OF test6110.typmod_partition FOR VALUES IN(%s)', i, i);
     END LOOP;
 END
Summary of changes:
 NEWS                     | 46 ++++++++--------------------------------------
 Version.config           |  2 +-
 postgis/postgis.sql.in   |  9 +++++----
 regress/core/tickets.sql |  7 +++++--
 4 files changed, 19 insertions(+), 45 deletions(-)
hooks/post-receive
