[SCM] PostGIS branch master updated. 3.7.0beta1-247-g83b0e72432
git at osgeo.org
git at osgeo.org
Sat Aug 8 22:46:32 PDT 2026
the project "PostGIS".
via 83b0e724322a8d737bd45fe5558222c9a6a7d642 (commit)
from 39bf9d6a75e43a9c75f7b06ed23facb8f4ea3edd (commit)
revisions in full, below.
commit 83b0e724322a8d737bd45fe5558222c9a6a7d642
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 9 01:46:26 2026 -0400
Try to fix ERROR: cannot specify storage parameters for a partitioned table in regress test by removing primary key on partitioned
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index a7d47d5e60..07cb6e6f1a 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1871,7 +1871,7 @@ $$ LANGUAGE plpgsql;
DO $$
DECLARE i integer;
BEGIN
- CREATE TABLE test6110.typmod_partition(id bigint, geom geometry(LINESTRING, 4269), part_key integer, CONSTRAINT pk_typmod_partition PRIMARY KEY(id, part_key))
+ CREATE TABLE test6110.typmod_partition(id bigint, geom geometry(LINESTRING, 4269), part_key integer)
PARTITION BY LIST (part_key);
FOR i IN 1..500 LOOP
EXECUTE format('CREATE TABLE test6110.typmod_%s (geom geometry(Point, 4326))', i);
Summary of changes:
regress/core/tickets.sql | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
