[SCM] PostGIS branch master updated. 3.7.0beta1-248-gd445e93754
git at osgeo.org
git at osgeo.org
Sun Aug 9 00:20:21 PDT 2026
the project "PostGIS".
via d445e93754117d6e55b5092ac73623d55a2b1ae0 (commit)
from 83b0e724322a8d737bd45fe5558222c9a6a7d642 (commit)
revisions in full, below.
commit d445e93754117d6e55b5092ac73623d55a2b1ae0
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 9 02:48:22 2026 -0400
Move adding geometry column to partitioned table after
Prevent hook-after-create table from disabling triggers on partitioned tables
It triggers error ERROR: cannot specify storage parameters for a partitioned table
when running the full test suite and there are partitioned tables involved
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 07cb6e6f1a..e04f022e9a 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1850,7 +1850,7 @@ BEGIN
SELECT count(*) INTO n FROM geometry_columns
WHERE f_table_schema = 'test6110';
- IF n <> 1501 THEN
+ IF n <> 2002 THEN
RETURN 'FAIL: count=' || n || ' (expected 1000)';
END IF;
@@ -1871,15 +1871,18 @@ $$ LANGUAGE plpgsql;
DO $$
DECLARE i integer;
BEGIN
- CREATE TABLE test6110.typmod_partition(id bigint, geom geometry(LINESTRING, 4269), part_key integer)
+ CREATE TABLE test6110.geom_partition(id bigint, part_key integer)
PARTITION BY LIST (part_key);
FOR i IN 1..500 LOOP
EXECUTE format('CREATE TABLE test6110.typmod_%s (geom geometry(Point, 4326))', i);
EXECUTE format('CREATE TABLE test6110.constraint_%s (id integer)', i);
EXECUTE format('SELECT AddGeometryColumn(%L, %L, %L, 4326, %L, 2, false)',
'test6110', 'constraint_' || i, 'geom', 'POINT');
- EXECUTE format('CREATE TABLE test6110.partition_%s PARTITION OF test6110.typmod_partition FOR VALUES IN(%s)', i, i);
+ EXECUTE format('CREATE TABLE test6110.geom_partition_%s PARTITION OF test6110.geom_partition FOR VALUES IN(%s)', i, i);
END LOOP;
+ ALTER TABLE test6110.geom_partition ADD COLUMN geom_typmod geometry(LINESTRING, 4269);
+ EXECUTE format('SELECT AddGeometryColumn(%L, %L, %L, 4326, %L, 2, false)',
+ 'test6110', 'geom_partition', 'geom_constraint', 'POINT');
END
diff --git a/regress/hooks/hook-after-create.sql b/regress/hooks/hook-after-create.sql
index 56492bbc80..1ff418994a 100644
--- a/regress/hooks/hook-after-create.sql
+++ b/regress/hooks/hook-after-create.sql
@@ -18,6 +18,9 @@ BEGIN
LOOP
IF obj.object_identity = 'public.spatial_ref_sys' THEN
CONTINUE;
+ END IF;
+ IF (SELECT relkind FROM pg_catalog.pg_class WHERE oid = obj.objid) = 'p' THEN
+ CONTINUE;
END IF;
EXECUTE format('ALTER TABLE %s SET (autovacuum_enabled = false);',obj.object_identity);
END LOOP;
Summary of changes:
regress/core/tickets.sql | 9 ++++++---
regress/hooks/hook-after-create.sql | 3 +++
2 files changed, 9 insertions(+), 3 deletions(-)
hooks/post-receive
