[SCM] PostGIS branch master updated. 3.7.0beta1-268-gfa5de5802b
Sun Aug 9 08:19:59 PDT 2026
the project "PostGIS".
       via  fa5de5802ba7fcee8ebf4b70d231debf4353bd9a (commit)
       via  80a8dcabf7d9f0b19abae1d853571473cbd9c075 (commit)
      from  a269ced55cc38f5114b17d59e2cc874d6c4a60c1 (commit)
revisions in full, below.
commit fa5de5802ba7fcee8ebf4b70d231debf4353bd9a
Merge: a269ced55c 80a8dcabf7
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 08:19:51 2026 -0700
    Merge pull request 'Fix ST_Normalize TIN child normalization' (!675) from Komzpa/postgis:fix/st-normalize-tin-20260809 into master
    ## Summary
    - keep ST_Normalize from placing non-TRIANGLE children back into TIN collections
    - fall back to the original TRIANGLE when GEOS normalization returns a polygon shape that cannot be represented as a TRIANGLE
    - add a regression test for malformed WKB TRIANGLE input inside a TIN
    ## Validation
    - ./autogen.sh && ./configure --without-raster --without-topology --without-protobuf
    - make -C liblwgeom -j2
    - make -C postgis -j2
    - make -C doc comments
    - make -C regress staged-install
    - make -C regress check TESTS=./core/normalize
    - git diff --check
    - git clang-format gitea/master --diff -- liblwgeom/lwgeom_geos.c
    - utils/docs/check_news.sh --base-ref gitea/master .
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/675
commit 80a8dcabf7d9f0b19abae1d853571473cbd9c075
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Aug 9 18:48:24 2026 +0400
diff --git a/NEWS b/NEWS
index 320f9e7ab2..0991688ce2 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta1.
 * Bug Fixes *
+ - GT-675, Preserve TRIANGLE children while normalizing malformed TINs
+          (Darafei Praliaskouski)
  - GT-671, Harden extension install and upgrade SQL against attacker-controlled
           object resolution in writable schemas
           (reported by Eric Ridge, PlanetScale;
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 8bf2261591..a1fadbec06 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -682,22 +682,31 @@ lwgeom_compare_by_xdr_ewkb(const void *a, const void *b)
 static LWGEOM *
-lwgeom_normalized_polygon_to_triangle(LWGEOM *geom)
+lwgeom_normalized_triangle_or_clone(const LWGEOM *triangle_in, LWGEOM *normalized)
 	LWPOLY *poly;
 	LWTRIANGLE *triangle;
 	POINTARRAY *points;
-	if (!geom || geom->type != POLYGONTYPE)
-		return geom;
+	if (normalized && normalized->type == TRIANGLETYPE)
+		return normalized;
-	poly = lwgeom_as_lwpoly(geom);
-	if (poly->nrings != 1 || !poly->rings[0] || poly->rings[0]->npoints != 4)
-		return geom;
+	if (!normalized || normalized->type != POLYGONTYPE)
+		lwgeom_free(normalized);
+		return lwgeom_clone_deep(triangle_in);
+	poly = lwgeom_as_lwpoly(normalized);
+	if (poly->nrings != 1 || !poly->rings[0])
 	points = ptarray_clone_deep(poly->rings[0]);
 	triangle = lwtriangle_construct(poly->srid, NULL, points);
-	lwgeom_free(geom);
 	return lwtriangle_as_lwgeom(triangle);
@@ -717,7 +726,7 @@ lwgeom_normalize_lwgeom(const LWGEOM *geom)
 		normalized = lwgeom_normalize(col->geoms[i]);
 		if (col->type == TINTYPE && col->geoms[i]->type == TRIANGLETYPE)
-			normalized = lwgeom_normalized_polygon_to_triangle(normalized);
+			normalized = lwgeom_normalized_triangle_or_clone(col->geoms[i], normalized);
 		lwgeom_free(col->geoms[i]);
 		col->geoms[i] = normalized;
diff --git a/regress/core/normalize.sql b/regress/core/normalize.sql
index b3998aa3b2..30d7a21d52 100644
--- a/regress/core/normalize.sql
+++ b/regress/core/normalize.sql
@@ -17,3 +17,24 @@ select 4, GeometryType(ST_Normalize(
 select 5, GeometryType(ST_GeometryN(ST_Normalize(
 'GEOMETRYCOLLECTION(POLYHEDRALSURFACE(((0 0,2 0,0 2,0 0))))'
 ::geometry), 1));
+with normalized as (
+	select ST_Normalize(ST_GeomFromWKB(decode(
+	'0110000000010000000111000000010000000500000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000',
+	'hex'))) as geom
+select 6, GeometryType(normalized.geom), GeometryType((dumped).geom)
+from normalized
+cross join lateral ST_Dump(normalized.geom) as dumped;
+	'hex'))) as geom
+), rotated as (
+	'01100000000100000001110000000100000005000000000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f',
+	'hex'))) as geom
+select 7, ST_AsEWKB(normalized.geom) = ST_AsEWKB(rotated.geom)
+from normalized, rotated;
diff --git a/regress/core/normalize_expected b/regress/core/normalize_expected
index 92ce31db3f..3070e4c875 100644
--- a/regress/core/normalize_expected
+++ b/regress/core/normalize_expected
@@ -3,3 +3,5 @@
 3|POLYHEDRALSURFACE
 4|TIN
 5|POLYHEDRALSURFACE
+6|TIN|TRIANGLE
+7|t
Summary of changes:
 NEWS                            |  2 ++
 liblwgeom/lwgeom_geos.c         | 25 +++++++++++++++++--------
 regress/core/normalize.sql      | 21 +++++++++++++++++++++
 regress/core/normalize_expected |  2 ++
 4 files changed, 42 insertions(+), 8 deletions(-)
hooks/post-receive
