[SCM] PostGIS branch master updated. 3.7.0beta1-270-gf03f1cf994
git at osgeo.org
git at osgeo.org
Sun Aug 9 08:56:17 PDT 2026
the project "PostGIS".
via f03f1cf99496832fbc7d2881f41187124b113718 (commit)
via d064fc038ec6fbcecd1375909d6ded791a871f0d (commit)
from fa5de5802ba7fcee8ebf4b70d231debf4353bd9a (commit)
revisions in full, below.
commit f03f1cf99496832fbc7d2881f41187124b113718
Merge: fa5de5802b d064fc038e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 08:56:15 2026 -0700
Merge pull request 'raster: document IntersectionFractions float buffer contract' (!676) from Komzpa/postgis:fix/intersection-fractions-float-contract-20260809 into master
### Motivation
`ST_IntersectionFractions` has been repeatedly flagged as if `GEOSGridIntersectionFractions` wrote double-precision output into the raster band. The GEOS 3.14+ C API is declared with a `float *buf` output parameter, so the existing `PT_32BF` band is the matching raster storage type.
Make that contract harder to misread in source review and static analysis.
### Description
- Keep the output band as `PT_32BF`.
- Name the GEOS output buffer as `float *geos_fractions` before calling GEOS.
- Add a defensive size check that `PT_32BF` matches the GEOS float buffer element size.
- Expand the nearby comment to say that `PT_64BF`/double would mismatch the GEOS API rather than make the call safer.
No `NEWS` entry: this does not change user-visible behavior; it documents and guards the existing GEOS/PostGIS buffer contract.
### Validation
- `./autogen.sh && ./configure --with-raster --without-topology --without-protobuf`
- `git clang-format gitea/master --diff -- raster/rt_core/rt_spatial_relationship.c`
- `make -C raster/rt_core -j2`
- `make -C raster/rt_pg -j2`
- `make -C regress staged-install`
- `make -C raster/test/regress check TESTS=./rt_intersection_fractions`
- `git diff --check`
- `utils/docs/check_news.sh --base-ref gitea/master .`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/676
commit d064fc038ec6fbcecd1375909d6ded791a871f0d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 9 19:31:59 2026 +0400
diff --git a/raster/rt_core/rt_spatial_relationship.c b/raster/rt_core/rt_spatial_relationship.c
index 625b2ead26..d1b55eb6a8 100644
--- a/raster/rt_core/rt_spatial_relationship.c
+++ b/raster/rt_core/rt_spatial_relationship.c
@@ -1304,6 +1304,7 @@ rt_raster_intersection_fractions(
rt_band band_out = NULL;
int band_num;
unsigned int width, height;
+ float *geos_fractions = NULL;
GEOSGeometry *geos_geom = NULL;
int geos_result;
@@ -1333,8 +1334,11 @@ rt_raster_intersection_fractions(
/* Shallow clone a new raster with no bands */
rast_out = rt_raster_clone(rast_in, 0);
- /* GEOSGridIntersectionFractions writes float values into float* buf,
- * so the output band must stay PT_32BF rather than PT_64BF. */
+ * GEOSGridIntersectionFractions is declared with a float *buf output
+ * parameter in the GEOS 3.14+ C API. Keep this band PT_32BF; using
+ * PT_64BF/double would mismatch the GEOS API rather than make it safer.
band_num = rt_raster_generate_new_band(
rast_out, /* rast */
PT_32BF, /* pixel type */
@@ -1350,6 +1354,14 @@ rt_raster_intersection_fractions(
rterror("%s: Failed to create output band", __func__);
return NULL;
+ if (rt_pixtype_size(PT_32BF) != (int)sizeof(*geos_fractions))
+ rt_raster_destroy(rast_out);
+ rterror("%s: PT_32BF size does not match GEOS float buffer", __func__);
+ return NULL;
+ geos_fractions = rt_band_get_data(band_out);
+ assert(geos_fractions != NULL);
/* Prepare for GEOS call */
/* Initialize GEOS to handle notices and errors */
@@ -1367,12 +1379,7 @@ rt_raster_intersection_fractions(
/* Call the core GEOS function */
geos_result = GEOSGridIntersectionFractions(
- geos_geom,
- rast_env.MinX, rast_env.MinY,
- rast_env.MaxX, rast_env.MaxY,
- width, height,
- rt_band_get_data(band_out)
+ geos_geom, rast_env.MinX, rast_env.MinY, rast_env.MaxX, rast_env.MaxY, width, height, geos_fractions);
/* The GEOS geometry is no longer needed after this call, so we can clean it up */
GEOSGeom_destroy(geos_geom);
Summary of changes:
raster/rt_core/rt_spatial_relationship.c | 23 +++++++++++++++--------
1 file changed, 15 insertions(+), 8 deletions(-)
hooks/post-receive
