[SCM] PostGIS branch master updated. 3.7.0beta1-272-gff62ffc93a
git at osgeo.org
git at osgeo.org
Sun Aug 9 09:33:40 PDT 2026
the project "PostGIS".
via ff62ffc93adaccbee6aed555ec2e83561d4da1fa (commit)
via 94cc593de819c917edc0d0a49c9c2ee76a5f88ce (commit)
from f03f1cf99496832fbc7d2881f41187124b113718 (commit)
revisions in full, below.
commit ff62ffc93adaccbee6aed555ec2e83561d4da1fa
Merge: f03f1cf994 94cc593de8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 09:33:39 2026 -0700
Merge pull request 'Fix memory leaks found by post-3.6 split audit' (!677) from Komzpa/postgis:fix/split-review-findings-20260809 into master
Audit of master changes after the 3.6 branch split found two live SQL-callable memory leaks and one stale development-doc pointer.
Changes:
- Free the deserialized parent geometry in ST_GeometryN, including NULL-result paths.
- Free both deserialized geometries in the ST_DWithin brute-force fallback.
- Update Version.config to point at the flattened release-process.md document.
- Add a 3.7.0beta2 NEWS entry.
Validation:
- git diff --check
- ./autogen.sh && ./configure --without-raster --without-topology --without-protobuf --without-sfcgal
- make -C postgis lwgeom_ogc.o lwgeom_geos_predicates.o
- python3 -B utils/docs/tests/test_check_news.py
- python3 -B utils/docs/tests/test_check_contributor_credits.py
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/677
commit 94cc593de819c917edc0d0a49c9c2ee76a5f88ce
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 9 20:27:55 2026 +0400
Fix memory leaks found by split review
diff --git a/NEWS b/NEWS
index 0991688ce2..f5a8cbbc25 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,8 @@ These are only changes since 3.7.0beta1.
- GT-675, Preserve TRIANGLE children while normalizing malformed TINs
(Darafei Praliaskouski)
+ - GT-677, Fix memory leaks in ST_GeometryN and ST_DWithin
+ (Darafei Praliaskouski)
- GT-671, Harden extension install and upgrade SQL against attacker-controlled
object resolution in writable schemas
(reported by Eric Ridge, PlanetScale;
diff --git a/Version.config b/Version.config
index 5576a8572d..2e5a68cb5e 100644
--- a/Version.config
+++ b/Version.config
@@ -1,7 +1,7 @@
# Version numbering central repository, to be included from various
# places during the build process
-# See doc/development/release-process/ for definitions of those three.
+# See doc/development/release-process.md for definitions of those three.
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=7
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index 670410f4c5..e09b536688 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -1200,6 +1200,8 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
LWGEOM *lwgeom1 = lwgeom_from_gserialized(geom1);
LWGEOM *lwgeom2 = lwgeom_from_gserialized(geom2);
mindist = lwgeom_mindistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
+ lwgeom_free(lwgeom1);
+ lwgeom_free(lwgeom2);
is_dwithin = (tolerance >= mindist);
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index 0270116d23..01d54f5f1c 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -438,7 +438,11 @@ Datum LWGEOM_geometryn_collection(PG_FUNCTION_ARGS)
subgeom = lwgeom_extract_geometry_n(lwgeom, idx, false);
if (!subgeom)
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 0);
PG_RETURN_NULL();
/* If not returning the original geometry */
if (subgeom != lwgeom)
@@ -448,6 +452,7 @@ Datum LWGEOM_geometryn_collection(PG_FUNCTION_ARGS)
if (lwgeom->bbox) lwgeom_add_bbox(subgeom);
result = geometry_serialize(subgeom);
PG_RETURN_POINTER(result);
Summary of changes:
NEWS | 2 ++
Version.config | 2 +-
postgis/lwgeom_geos_predicates.c | 2 ++
postgis/lwgeom_ogc.c | 5 +++++
4 files changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
