[SCM] PostGIS branch master updated. 3.7.0beta1-274-g531e51fc93
git at osgeo.org
git at osgeo.org
Sun Aug 9 09:44:55 PDT 2026
the project "PostGIS".
via 531e51fc93346b85c0eb97fe5dfb20a2f6cb630e (commit)
via a668bbef629d771625d50ee905bcccf672a2c297 (commit)
from ff62ffc93adaccbee6aed555ec2e83561d4da1fa (commit)
revisions in full, below.
commit 531e51fc93346b85c0eb97fe5dfb20a2f6cb630e
Merge: ff62ffc93a a668bbef62
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 09:44:53 2026 -0700
Merge pull request 'regress: avoid setup hooks during dump restore' (!678) from Komzpa/postgis:fix/regress-hook-dump-restore-20260809 into master
The regression harness runs `--after-create-db-script` hooks before the initial
PostGIS installation. A dump/restore run creates a second empty database, and
running those hooks there as well can conflict with objects restored from the
dump.
Run the setup hooks only for the initial database. The restored database stays
empty until the dump is loaded, while the initial install and upgrade paths keep
their existing hook coverage.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/678
commit a668bbef629d771625d50ee905bcccf672a2c297
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 9 20:28:30 2026 +0400
regress: skip setup hooks before dump restore
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 622d6d5645..119956f6c9 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1552,12 +1552,6 @@ sub create_db
return 0 if system($createcmd);
- foreach my $hook (@OPT_HOOK_AFTER_CREATE_DB)
- print "Running after-create-db-script $hook\n";
- die unless load_sql_file($hook, 1);
return 1;
@@ -1568,6 +1562,12 @@ sub create_spatial
$rv = create_db();
+ foreach my $hook (@OPT_HOOK_AFTER_CREATE_DB)
+ print "Running after-create-db-script $hook\n";
+ die unless load_sql_file($hook, 1);
# Count database objects before installing anything
$OBJ_COUNT_PRE = count_db_objects();
Summary of changes:
regress/run_test.pl | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
