[SCM] PostGIS branch stable-3.5 updated. 3.5.7-104-g36c1a703f5
Sun Aug 9 09:56:31 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  36c1a703f5846d898c08fd32473858613c64fbb9 (commit)
       via  530d094fb22f55b3e71eab1fc212de62f45afda3 (commit)
       via  207ae9af8a2caf12885c4c1cd629ba1df9964d6a (commit)
      from  a3192f3232f67d539bfcfc373c5b31d8c2175475 (commit)
revisions in full, below.
commit 36c1a703f5846d898c08fd32473858613c64fbb9
Merge: a3192f3232 530d094fb2
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 09:56:30 2026 -0700
    Merge pull request 'regress: backport interrupt timing baseline to stable-3.5' (!621) from Komzpa/postgis:fix/interrupt-relative-timing-stable-3.5-20260729 into stable-3.5
    Backport of the interrupt regression timing fix from GT-619 to stable-3.5.\n\nThe relate interrupt checks now compare timeout latency to same-machine uninterrupted runtime, so loaded workers do not fail only because their absolute wall-clock reporting is slow. The assertion remains meaningful because a build that stops propagating PostgreSQL cancellation into GEOS reaches the local baseline and reports interrupted late.\n\nReferences https://gitea.osgeo.org/postgis/postgis/pulls/619
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/621
commit 530d094fb22f55b3e71eab1fc212de62f45afda3
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Jul 29 19:19:26 2026 +0400
    regress: keep interrupt relate input bounded
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index fb29babd73..0e0e85ff63 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -6,7 +6,7 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
    ST_Point(cos(radians(x)),sin(radians(270-x))),
    ST_Point(sin(radians(x)),cos(radians(60-x)))
    ) g
- FROM generate_series(1,1440) x
+ FROM generate_series(1,720) x
  ) foo
commit 207ae9af8a2caf12885c4c1cd629ba1df9964d6a
Date:   Wed Jul 29 02:32:22 2026 +0400
    regress: compare interrupt timing to local baseline
diff --git a/NEWS b/NEWS
index 4319b581d9..d93cf87035 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,9 @@ PostGIS 3.5.8
 * Bug Fixes *
+  - GT-619, Make interrupt regression tests compare timeout latency to
+    same-machine uninterrupted runtime, avoiding false failures under
+    slow CI load (Darafei Praliaskouski)
   - GT-569, Initialize GSERIALIZED peek test fixtures so check-unit stays
     clean under Valgrind (Darafei Praliaskouski)
   - GT-582, Make the computed-columns regression test assert the query plan
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index 78f30166e4..c9fc993b6a 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -17,4 +17,7 @@ SELECT _timecheck('segmentize', '300ms');
 -- Not affected by old timeout
 SELECT '1',ST_AsText(ST_Segmentize('LINESTRING(0 0,4 0)'::geometry, 2));
+DROP FUNCTION _timecheck(text);
 DROP FUNCTION _timecheck(text, interval);
+DROP FUNCTION _timecheck_baseline(text);
+DROP FUNCTION _timecheck_start();
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index fd942e1e6d..204ecae936 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -29,3 +29,6 @@ SELECT _timecheck('buffer', '350ms');
 SELECT '1', ST_NPoints(ST_Buffer('POINT(4 0)'::geometry, 2, 1));
index 9df2262d71..fb29babd73 100644
    ) g
- FROM generate_series(1,720) x
+ FROM generate_series(1,1440) x
  ) foo
@@ -16,29 +16,69 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
 -- IM9 based predicates
+DO $$
+BEGIN
+  PERFORM _timecheck_start();
+  PERFORM ST_Contains(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('contains');
+END;
 BEGIN;
 SET LOCAL statement_timeout TO 100;
 select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('contains', '220ms');
+SELECT _timecheck('contains');
+DO $$
+BEGIN
+  PERFORM ST_Covers(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('covers');
+END;
 BEGIN;
 select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('covers', '220ms');
+SELECT _timecheck('covers');
+DO $$
+BEGIN
+  PERFORM ST_CoveredBy(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('coveredby');
+END;
 BEGIN;
 select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('coveredby', '250ms');
+SELECT _timecheck('coveredby');
+DO $$
+BEGIN
+  PERFORM ST_Crosses(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('crosses');
+END;
 BEGIN;
 select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('crosses', '220ms');
+SELECT _timecheck('crosses');
+DO $$
+BEGIN
+  PERFORM ST_Equals(g,st_reverse(g)) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('equals');
+END;
 -- NOTE: we're reversing one of the operands to avoid the
 --       short-circuit described in #3226
@@ -46,7 +86,15 @@ BEGIN;
 select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('equals', '220ms');
+SELECT _timecheck('equals');
+DO $$
+BEGIN
+  PERFORM ST_Intersects(g,ST_Segmentize(g,1e-4)) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('intersects');
+END;
 -- NOTE: intersects became very fast, so we segmentize
 --       input to make it slower
@@ -54,19 +102,38 @@ BEGIN;
 select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('intersects', '210ms');
+SELECT _timecheck('intersects');
+DO $$
+BEGIN
+  PERFORM ST_Overlaps(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('overlaps');
+END;
 BEGIN;
 select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('overlaps', '220ms');
+SELECT _timecheck('overlaps');
+DO $$
+BEGIN
+  PERFORM ST_Relate(g,g) FROM _inputs WHERE id = 1;
+  PERFORM _timecheck_baseline('relate');
+END;
 BEGIN;
 select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('relate', '220ms');
+SELECT _timecheck('relate');
 DROP TABLE _inputs;
diff --git a/regress/utils/timecheck.sql b/regress/utils/timecheck.sql
index 75f3bbbbd0..c28fe265e3 100644
--- a/regress/utils/timecheck.sql
+++ b/regress/utils/timecheck.sql
@@ -1,3 +1,21 @@
+CREATE FUNCTION _timecheck_start() RETURNS void
+AS $$
+BEGIN
+  UPDATE _time SET t = clock_timestamp();
+END;
+$$ LANGUAGE 'plpgsql' VOLATILE;
+CREATE FUNCTION _timecheck_baseline(label text) RETURNS void
+AS $$
+BEGIN
+  INSERT INTO _time_baseline
+  SELECT label, clock_timestamp() - t
+  FROM _time;
+END;
 CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
 AS $$
 DECLARE
@@ -37,6 +55,43 @@ BEGIN
 END;
+CREATE FUNCTION _timecheck(label text) RETURNS text
+AS $$
+DECLARE
+  ret TEXT;
+  lap INTERVAL;
+	rec RECORD;
+BEGIN
+	-- We use now() here to get the time at the
+	-- start of the transaction, which started when
+	-- this function was called, so the earliest
+	-- possible time
+  SELECT now() - t lap, b.baseline, b.baseline * 0.9 tolerated
+	FROM _time t
+	JOIN _time_baseline b ON b.label = _timecheck.label
+	INTO rec;
+	RAISE DEBUG 'Uninterrupted baseline: %', rec.baseline;
+	RAISE DEBUG 'Resulting tolerance: %', rec.tolerated;
+  IF rec.lap < rec.tolerated THEN
+		ret := format(
+			'%s interrupted on time',
+			label
+  ELSE
+		ret := format(
+			'%s interrupted late: %s (%s tolerated)',
+			label, rec.lap, rec.tolerated
+  END IF;
+  RETURN ret;
+END;
 CREATE TEMPORARY TABLE _time AS
 SELECT
 	now() t,
@@ -45,3 +100,7 @@ SELECT
     '1'
   )::float8 sf;
+CREATE TEMPORARY TABLE _time_baseline (
+  label text PRIMARY KEY,
+  baseline interval NOT NULL
Summary of changes:
 NEWS | 3 +++
 1 file changed, 3 insertions(+)
hooks/post-receive
