[SCM] PostGIS branch master updated. 3.7.0beta1-276-g57916f4714
git at osgeo.org
git at osgeo.org
Sun Aug 9 09:57:19 PDT 2026
the project "PostGIS".
via 57916f4714c4afd722a0222711a291db7a6b409f (commit)
via 244be27079cb4113b193a37ea1139c356be40f1a (commit)
from 531e51fc93346b85c0eb97fe5dfb20a2f6cb630e (commit)
revisions in full, below.
commit 57916f4714c4afd722a0222711a291db7a6b409f
Merge: 531e51fc93 244be27079
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 09:57:17 2026 -0700
Merge pull request 'Use decode in test so don't have to worry about standardard conforming strings' (!681) from robe/postgis:fix-standard-conforming into master
Fix for regression test
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/681
commit 244be27079cb4113b193a37ea1139c356be40f1a
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 9 12:51:33 2026 -0400
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 6d8ba9148e..0b6b23d9ae 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -179,10 +179,10 @@ select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
select '--- Malformed input detection ---';
-- Magic bytes plus a truncated size prefix.
-select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201010203'::bytea);
+select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, decode('6667620366676201010203', 'hex'));
-- Valid magic bytes plus a header size prefix that exceeds the remaining input.
-select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201ffffffff'::bytea);
+select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, decode('6667620366676201ffffffff', 'hex'));
-- NULL bytea input should be handled by STRICT rather than reaching the C decoder.
select 'MI3', count(*) from ST_FromFlatGeobuf(null::flatgeobuf_t1, null::bytea);
Summary of changes:
regress/core/flatgeobuf.sql | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
