[SCM] PostGIS branch master updated. 3.7.0beta1-286-g1fce5eae5f
Sun Aug 9 13:50:08 PDT 2026
the project "PostGIS".
       via  1fce5eae5fa48ee513913b0bce7c6ac6eee000b5 (commit)
       via  a17c85d5b9885b24f518cfbee86f6fd7c4ffb163 (commit)
      from  d7e291c966e15441130306b7c4a9c02b4800818d (commit)
revisions in full, below.
commit 1fce5eae5fa48ee513913b0bce7c6ac6eee000b5
Merge: d7e291c966 a17c85d5b9
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 13:50:06 2026 -0700
    Merge pull request 'ci: match Jenkins matrix children to parent build' (!700) from Komzpa/postgis:fix/master-jenkins-matrix-parent-20260810 into master
    ## Summary
    - report only Jenkins matrix children belonging to the current parent build
    - add a regression for stale child results from an earlier parent build
    ## Validation
    - `python3 utils/docs/tests/test_ci_status.py`
    - `git diff --check`
    The live status page attributed failed PG14/PG15 children from parent #5208 to current master parent #5212. This retains the current PG18 running child and excludes the stale failures.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/700
commit a17c85d5b9885b24f518cfbee86f6fd7c4ffb163
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Aug 10 00:43:24 2026 +0400
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index 172adbd89d..7f4376d429 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -1058,7 +1058,7 @@ def jenkins_matrix_configuration_label(configuration, selected):
     return configuration.get("name") or configuration.get("url") or "configuration"
-def jenkins_matrix_details(job_url, timeout):
+def jenkins_matrix_details(job_url, timeout, parent_build_number):
     try:
         configurations = jenkins_matrix_configurations(job_url, timeout)
     except RECOVERABLE_PROVIDER_ERRORS:
@@ -1075,6 +1075,8 @@ def jenkins_matrix_details(job_url, timeout):
     for configuration in configurations:
         build = configuration.get("lastBuild") or {}
+        if build.get("number") != parent_build_number:
+            continue
         status = normalize_jenkins_status(build)
         if status == SUCCESS:
             continue
@@ -1195,7 +1197,7 @@ def jenkins_check(check, branch, timeout):
         message=f"build {current.get('number')}",
     if result["status"] != SUCCESS:
-        details = jenkins_matrix_details(job_url, timeout)
+        details = jenkins_matrix_details(job_url, timeout, current.get("number"))
         if details:
             result["message"] = f"{result['message']}; {details['message']}"
             if details.get("url"):
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index 4249b539ca..6683ebb0f8 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -415,6 +415,58 @@ class CIStatusTest(unittest.TestCase):
         self.assertEqual("build 7808", result["message"])
         self.assertEqual("https://ci.example.test/job/PostGIS_Make_Dist/7808/", result["url"])
+    def test_jenkins_matrix_ignores_another_parent_build(self):
+        check_config = {
+            "name": "Jenkins / Debbie main",
+            "provider": "jenkins",
+            "required": True,
+            "job_url": "https://ci.example.test/job/PostGIS_trunk/",
+        branch = {
+            "name": "master",
+            "label": "master",
+            "version_or_trunk": "trunk",
+        current = {
+            "number": 5212,
+            "building": True,
+            "result": None,
+            "url": "https://ci.example.test/job/PostGIS_trunk/5212/",
+        matrix = [
+                "name": "PG_VER=14,OS_BUILD=64",
+                "lastBuild": {
+                    "number": 5208,
+                    "result": "FAILURE",
+                    "url": "https://ci.example.test/job/PostGIS_trunk/PG_VER=14/5208/",
+                "name": "PG_VER=18,OS_BUILD=64",
+                "lastBuild": {
+                    "number": 5212,
+                    "building": True,
+                    "result": None,
+                    "url": "https://ci.example.test/job/PostGIS_trunk/PG_VER=18/5212/",
+        with (
+            mock.patch.object(CI_STATUS, "jenkins_queued_check", return_value=None),
+            mock.patch.object(CI_STATUS, "jenkins_builds", return_value=[current]),
+            mock.patch.object(CI_STATUS, "jenkins_matrix_configurations", return_value=matrix),
+            result = CI_STATUS.jenkins_check(check_config, branch, timeout=5)
+        self.assertEqual(CI_STATUS.IN_PROGRESS, result["status"])
+        self.assertEqual("build 5212; running: PG18", result["message"])
+        self.assertEqual(
+            "https://ci.example.test/job/PostGIS_trunk/PG_VER=18/5212/",
+            result["url"],
     def test_jenkins_queue_prefers_current_branch_revision(self):
         check_config = {
             "name": "Jenkins / Berrie",
Summary of changes:
 utils/docs/ci_status/report.py     |  6 +++--
 utils/docs/tests/test_ci_status.py | 52 ++++++++++++++++++++++++++++++++++++++
 2 files changed, 56 insertions(+), 2 deletions(-)
hooks/post-receive
