[SCM] PostGIS branch master updated. 3.7.0beta1-288-ga9fc28c341
git at osgeo.org
git at osgeo.org
Sun Aug 9 13:53:50 PDT 2026
the project "PostGIS".
via a9fc28c341713aa70bfd43ad1200d9fdd4559400 (commit)
via b3aa5da4ddaddd7d5d88f6d38cb991c8974ed809 (commit)
from 1fce5eae5fa48ee513913b0bce7c6ac6eee000b5 (commit)
revisions in full, below.
commit a9fc28c341713aa70bfd43ad1200d9fdd4559400
Merge: 1fce5eae5f b3aa5da4dd
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 13:53:48 2026 -0700
Merge pull request 'fuzzers: compare GSERIALIZED bytea round trips semantically' (!704) from Komzpa/postgis:fix/ossfuzz-gserialized-bytea-544223869 into master
## Summary
OSS-Fuzz issue 544223869 found that `gserialized_from_bytea_fuzzer` could abort on an assertion while round-tripping arbitrary GSERIALIZED input through WKB bytea.
The testcase carries GSERIALIZED bbox metadata that is not preserved by WKB bytea output. This patch keeps the fuzzer's serializer size checks, but compares the bytea round trip by geometry metadata and coordinate semantics after dropping bbox metadata instead of requiring byte-for-byte GSERIALIZED equality.
`NEWS` is updated under the unreleased 3.7.0beta2 bug-fix section.
## Validation
- `git clang-format --extensions cpp --diff upstream/master`
- `make -C fuzzers dummyfuzzers FUZZER_OUT=...`
- `gserialized_from_bytea_fuzzer` replay of testcase 6383202993504256
- `make -C fuzzers check-corpus FUZZER_OUT=...`
- `git diff --check upstream/master`
- `utils/check_news.sh .`
- `make check-contributor-credits`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/704
commit b3aa5da4ddaddd7d5d88f6d38cb991c8974ed809
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 10 00:50:07 2026 +0400
OSS-Fuzz issue 544223869 exposed that arbitrary GSERIALIZED input may carry bbox metadata that is not preserved by WKB bytea output. Keep serializer size checks, but compare the round-tripped geometry metadata and coordinates after dropping bbox metadata.
diff --git a/NEWS b/NEWS
index f5a8cbbc25..69e2923566 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta1.
* Bug Fixes *
+ - OSSFuzz 544223869, compare GSERIALIZED bytea round trips by geometry
+ semantics instead of volatile bbox bytes (Darafei Praliaskouski)
- GT-675, Preserve TRIANGLE children while normalizing malformed TINs
- GT-677, Fix memory leaks in ST_GeometryN and ST_DWithin
diff --git a/fuzzers/gserialized_from_bytea_fuzzer.cpp b/fuzzers/gserialized_from_bytea_fuzzer.cpp
index 41c37ea859..087f97d3e3 100644
--- a/fuzzers/gserialized_from_bytea_fuzzer.cpp
+++ b/fuzzers/gserialized_from_bytea_fuzzer.cpp
@@ -48,15 +48,6 @@ geometry_to_bytea(const LWGEOM *lwgeom)
return lwgeom_to_wkb_varlena(lwgeom, WKB_NDR | WKB_EXTENDED);
-static void
-assert_equal_gserialized(const GSERIALIZED *left, size_t left_size, const GSERIALIZED *right, size_t right_size)
- postgis_fuzzer_assert(left_size == LWSIZE_GET(left->size));
- postgis_fuzzer_assert(right_size == LWSIZE_GET(right->size));
- postgis_fuzzer_assert(left_size == right_size);
- postgis_fuzzer_assert(memcmp(left, right, left_size) == 0);
static void
assert_gserialized_bytea_roundtrip(LWGEOM *lwgeom)
@@ -74,7 +65,21 @@ assert_gserialized_bytea_roundtrip(LWGEOM *lwgeom)
GSERIALIZED *second = gserialized_from_lwgeom(from_bytea, &second_size);
postgis_fuzzer_assert(second != NULL);
- assert_equal_gserialized(first, first_size, second, second_size);
+ postgis_fuzzer_assert(first_size == LWSIZE_GET(first->size));
+ postgis_fuzzer_assert(second_size == LWSIZE_GET(second->size));
+ postgis_fuzzer_assert(lwgeom->type == from_bytea->type);
+ postgis_fuzzer_assert(lwgeom->srid == from_bytea->srid);
+ postgis_fuzzer_assert(FLAGS_GET_Z(lwgeom->flags) == FLAGS_GET_Z(from_bytea->flags));
+ postgis_fuzzer_assert(FLAGS_GET_M(lwgeom->flags) == FLAGS_GET_M(from_bytea->flags));
+ postgis_fuzzer_assert(FLAGS_GET_GEODETIC(lwgeom->flags) == FLAGS_GET_GEODETIC(from_bytea->flags));
+ /* WKB bytea does not preserve GSERIALIZED bounding boxes. Arbitrary
+ * GSERIALIZED input can carry a bbox that is not byte-for-byte reproduced
+ * after geometry->bytea->geometry, so compare the semantic geometry.
+ lwgeom_drop_bbox(lwgeom);
+ lwgeom_drop_bbox(from_bytea);
+ postgis_fuzzer_assert(lwgeom_same(lwgeom, from_bytea));
lwgeom_free(from_bytea);
lwfree(first);
Summary of changes:
NEWS | 2 ++
fuzzers/gserialized_from_bytea_fuzzer.cpp | 25 +++++++++++++++----------
2 files changed, 17 insertions(+), 10 deletions(-)
hooks/post-receive
