[SCM] PostGIS branch stable-3.6 updated. 3.6.4-125-gf61abf9048
git at osgeo.org
git at osgeo.org
Sun Aug 9 14:19:23 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via f61abf9048731850fe7a401cc3624873d18232e4 (commit)
via ad95093e0ba8721e3046f0c8a9cb109919580392 (commit)
via c02eadfa621fc1af62c94b6bc7f80aa159b382a7 (commit)
from 918f1c9cd870e0a7fde02ade51be65d2164955a4 (commit)
revisions in full, below.
commit f61abf9048731850fe7a401cc3624873d18232e4
Merge: 918f1c9cd8 ad95093e0b
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 14:19:21 2026 -0700
Merge pull request 'regress: make stable-3.6 fixtures CI-mode independent' (!705) from Komzpa/postgis:fix/stable-3.6-regress-compat-20260810 into stable-3.6
Fix the stable-3.6 regression tests for supported GEOS output and
`standard_conforming_strings = off`.
The Delaunay expected output now matches the normalized TIN returned by the
current GEOS matrix. Malformed FlatGeobuf bytea fixtures use `decode()` so they
remain byte-for-byte identical regardless of string-literal settings.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/705
commit ad95093e0ba8721e3046f0c8a9cb109919580392
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 9 12:51:33 2026 -0400
Use decode in test so don't have to worry about standardard conforming strings
(cherry picked from commit 244be27079cb4113b193a37ea1139c356be40f1a)
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 6d8ba9148e..0b6b23d9ae 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -179,10 +179,10 @@ select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
select '--- Malformed input detection ---';
-- Magic bytes plus a truncated size prefix.
-select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201010203'::bytea);
+select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, decode('6667620366676201010203', 'hex'));
-- Valid magic bytes plus a header size prefix that exceeds the remaining input.
-select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201ffffffff'::bytea);
+select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, decode('6667620366676201ffffffff', 'hex'));
-- NULL bytea input should be handled by STRICT rather than reaching the C decoder.
select 'MI3', count(*) from ST_FromFlatGeobuf(null::flatgeobuf_t1, null::bytea);
commit c02eadfa621fc1af62c94b6bc7f80aa159b382a7
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 10 00:12:33 2026 +0400
regress: expect normalized Delaunay TIN output
diff --git a/regress/core/delaunaytriangles_expected b/regress/core/delaunaytriangles_expected
index 5b61b195c8..0c29ab9cdf 100644
--- a/regress/core/delaunaytriangles_expected
+++ b/regress/core/delaunaytriangles_expected
@@ -2,8 +2,8 @@
2|GEOMETRYCOLLECTION(POLYGON((5 5,8 9,6 0,5 5)),POLYGON((5 5,7 9,8 9,5 5)))
3|GEOMETRYCOLLECTION(POLYGON((5 5,7 9,6 0,5 5)))
4|MULTILINESTRING((6 0,7 9),(5 5,7 9),(5 5,6 0))
-5|GEOMETRYCOLLECTION(POLYGON((5 5,7 9,6 0,5 5)))
-6|GEOMETRYCOLLECTION(POLYGON((5 5,8 9,6 0,5 5)),POLYGON((5 5,7 9,8 9,5 5)))
-7|GEOMETRYCOLLECTION(POLYGON((5 5,7 9,6 0,5 5)))
+5|TIN(((5 5,7 9,6 0,5 5)))
+6|TIN(((5 5,7 9,8 9,5 5)),((5 5,8 9,6 0,5 5)))
+7|TIN(((5 5,7 9,6 0,5 5)))
10|GEOMETRYCOLLECTION Z (POLYGON Z ((5 5 3,7 9 1,6 0 2,5 5 3)))
-11|GEOMETRYCOLLECTION Z (POLYGON Z ((5 5 1,7 9 3,6 0 2,5 5 1)))
+11|TIN Z (((5 5 1,7 9 3,6 0 2,5 5 1)))
Summary of changes:
regress/core/delaunaytriangles_expected | 8 ++++----
regress/core/flatgeobuf.sql | 4 ++--
2 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
