[SCM] PostGIS branch master updated. 3.7.0beta2-3-g2affb0e41
git at osgeo.org
git at osgeo.org
Sun Aug 9 23:30:32 PDT 2026
the project "PostGIS".
via 2affb0e413349726510e5aa901d996aeed3f612e (commit)
via 1003cc6cd5b39511dd388ab430acc0e3830774be (commit)
from 2de9db8c6baaa10fd64a668b4835245d1c8f3f7a (commit)
revisions in full, below.
commit 2affb0e413349726510e5aa901d996aeed3f612e
Merge: 2de9db8c6 1003cc6cd
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 23:30:31 2026 -0700
Merge pull request 'ci: classify killed Woodpecker pipelines as unjudged' (!707) from Komzpa/postgis:fix/master-woodpecker-killed-status-20260810 into master
A killed Woodpecker pipeline has no test outcome. Report it as unjudged rather
than as a source failure, while retaining the agent-loss diagnostic when the
provider supplies it.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/707
commit 1003cc6cd5b39511dd388ab430acc0e3830774be
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 10 10:25:57 2026 +0400
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index 7f4376d42..d74c2a589 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -388,7 +388,7 @@ def normalize_woodpecker_status(value):
"success": SUCCESS,
"failure": FAILURE,
"error": FAILURE,
- "killed": FAILURE,
+ "killed": UNKNOWN,
"blocked": IN_PROGRESS,
"declined": FAILURE,
"running": IN_PROGRESS,
@@ -604,13 +604,14 @@ def woodpecker_check(check, branch, timeout):
current = {**current, **http_json(detail_url, timeout=timeout)}
except RECOVERABLE_PROVIDER_ERRORS:
pass
+ current_status = normalize_woodpecker_status(current.get("status"))
message = current.get("message")
extra = {}
- if normalize_woodpecker_status(current.get("status")) != SUCCESS:
+ if current_status != SUCCESS:
details = None
if str(current.get("status")).lower() == "error" and not (current.get("workflows") or []):
details = woodpecker_error_details(current)
- if not details and str(current.get("status")).lower() == "failure":
+ if not details and str(current.get("status")).lower() in ("failure", "killed"):
details = woodpecker_killed_details(current)
if not details:
details = woodpecker_workflow_details(current, web_url)
@@ -618,10 +619,12 @@ def woodpecker_check(check, branch, timeout):
message = details["message"]
run_url = details.get("url") or run_url
extra.update({key: details[key] for key in ("status_label",) if key in details})
+ if details.get("status_label") == "Agent lost":
+ current_status = UNKNOWN
result = make_result(
check,
branch,
- normalize_woodpecker_status(current.get("status")),
+ current_status,
url=run_url or web_url,
debug_url=url,
revision=current.get("commit"),
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index 6683ebb0f..0cf9bf95e 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -562,8 +562,8 @@ class CIStatusTest(unittest.TestCase):
with mock.patch.object(CI_STATUS, "http_json", side_effect=([pipeline], pipeline_detail)) as http_json:
result = CI_STATUS.woodpecker_check(check_config, branch, timeout=5)
- self.assertEqual(CI_STATUS.FAILURE, result["status"])
- self.assertEqual("failed: regress/18", result["message"])
+ self.assertEqual(CI_STATUS.UNKNOWN, result["status"])
+ self.assertEqual("unknown: regress/18", result["message"])
self.assertEqual("https://woodie.example.test/repos/30/pipeline/5430/18", result["url"])
self.assertEqual("a" * 40, result["revision"])
self.assertEqual(
@@ -686,7 +686,7 @@ class CIStatusTest(unittest.TestCase):
timeout=5,
self.assertEqual("Agent lost", result["status_label"])
self.assertEqual("agent lost: 3 steps killed at exit 0 (clone, prepare, check-xml)", result["message"])
Summary of changes:
utils/docs/ci_status/report.py | 11 +++++++----
utils/docs/tests/test_ci_status.py | 6 +++---
2 files changed, 10 insertions(+), 7 deletions(-)
hooks/post-receive
