[SCM] PostGIS branch master updated. 3.7.0beta2-5-g10b5cd953
Sun Aug 9 23:45:09 PDT 2026
the project "PostGIS".
       via  10b5cd9534f6a436a73af191a367ed6e8be7155f (commit)
       via  3cdb2994be6a4d06faeeb847f8ff181e5f12656f (commit)
      from  2affb0e413349726510e5aa901d996aeed3f612e (commit)
revisions in full, below.
commit 10b5cd9534f6a436a73af191a367ed6e8be7155f
Merge: 2affb0e41 3cdb2994b
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 23:45:07 2026 -0700
    Merge pull request 'ci: preserve failures in killed Woodpecker pipelines' (!714) from Komzpa/postgis:fix/master-woodpecker-killed-status-correction-20260810 into master
    ## Summary
    A killed Woodpecker pipeline may already contain a decisive failed step. Keep such a pipeline failed instead of masking it as unjudged.
    The report now recognizes Docker cancellation and deadline-expiry errors at exit 0 as agent loss, while retaining ordinary nonzero failed steps as failures.
    ## Validation
    `python3 utils/docs/tests/test_ci_status.py`
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/714
commit 3cdb2994be6a4d06faeeb847f8ff181e5f12656f
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Aug 10 10:43:15 2026 +0400
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index d74c2a589..b0644ed7a 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -537,32 +537,61 @@ def woodpecker_leaf_steps(workflow):
     return [workflow]
+def woodpecker_step_is_agent_loss(step):
+    state = str(step.get("state") or step.get("status")).lower()
+    if step.get("exit_code") != 0:
+        return False
+    if state == "killed":
+        return True
+    if state != "failure":
+        return False
+    error = " ".join(
+        str(step.get(key) or "")
+        for key in ("error", "message")
+    ).lower()
+    return (
+        "context deadline exceeded" in error
+        or "canceled" in error
+        or "cancelled" in error
+def woodpecker_has_conclusive_failure(pipeline):
+    for workflow in pipeline.get("workflows") or []:
+        for step in woodpecker_leaf_steps(workflow):
+            status = normalize_woodpecker_status(step.get("state") or step.get("status"))
+            if status == FAILURE and not woodpecker_step_is_agent_loss(step):
+                return True
+    return False
 def woodpecker_killed_details(pipeline):
     workflows = pipeline.get("workflows") or []
     if not workflows:
         return None
     non_success = []
-    killed_zero = []
+    agent_loss = []
     for workflow in workflows:
             if status == SUCCESS:
                 continue
             non_success.append(step)
-            if str(step.get("state") or step.get("status")).lower() == "killed" and step.get("exit_code") == 0:
-                killed_zero.append(step)
+            if woodpecker_step_is_agent_loss(step):
+                agent_loss.append(step)
-    if not non_success or len(non_success) != len(killed_zero):
+    if not non_success or len(non_success) != len(agent_loss):
         return None
     labels = [
         str(step.get("name") or f"step {step.get('pid') or step.get('id')}")
-        for step in killed_zero[:3]
+        for step in agent_loss[:3]
-    suffix = f" ({', '.join(labels)}" + (", ..." if len(killed_zero) > len(labels) else "") + ")"
+    suffix = f" ({', '.join(labels)}" + (", ..." if len(agent_loss) > len(labels) else "") + ")"
     return {
-        "message": f"agent lost: {plural(len(killed_zero), 'step')} killed at exit 0{suffix}",
+        "message": f"agent lost: {plural(len(agent_loss), 'step')} stopped at exit 0{suffix}",
         "status_label": "Agent lost",
@@ -605,6 +634,11 @@ def woodpecker_check(check, branch, timeout):
         except RECOVERABLE_PROVIDER_ERRORS:
             pass
     current_status = normalize_woodpecker_status(current.get("status"))
+    if (
+        str(current.get("status")).lower() == "killed"
+        and woodpecker_has_conclusive_failure(current)
+        current_status = FAILURE
     message = current.get("message")
     extra = {}
     if current_status != SUCCESS:
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index 0cf9bf95e..d29a5b51a 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -688,7 +688,77 @@ class CIStatusTest(unittest.TestCase):
         self.assertEqual(CI_STATUS.UNKNOWN, result["status"])
         self.assertEqual("Agent lost", result["status_label"])
-        self.assertEqual("agent lost: 3 steps killed at exit 0 (clone, prepare, check-xml)", result["message"])
+        self.assertEqual("agent lost: 3 steps stopped at exit 0 (clone, prepare, check-xml)", result["message"])
+    def test_woodpecker_killed_pipeline_with_deadline_exceeded_is_agent_loss(self):
+        check_config = {
+            "name": "Woodpecker",
+            "provider": "woodpecker",
+            "required": True,
+            "api_url": "https://woodie.example.test/api/repos/30/pipelines",
+            "web_url": "https://woodie.example.test/repos/30",
+        branch = {"name": "stable-3.6", "label": "3.6"}
+        pipeline = {
+            "number": 6852,
+            "event": "push",
+            "branch": "stable-3.6",
+            "ref": "refs/heads/stable-3.6",
+            "status": "killed",
+            "commit": "e" * 40,
+            "workflows": [
+                    "pid": 1,
+                    "name": "regress",
+                    "state": "killed",
+                    "children": [{
+                        "pid": 4,
+                        "name": "test-upgrades",
+                        "state": "failure",
+                        "exit_code": 0,
+                        "error": "Post docker.sock/wait: context deadline exceeded",
+        with mock.patch.object(CI_STATUS, "http_json", return_value=[pipeline]):
+            result = CI_STATUS.woodpecker_check(check_config, branch, timeout=5)
+        self.assertEqual(CI_STATUS.UNKNOWN, result["status"])
+        self.assertEqual("Agent lost", result["status_label"])
+    def test_woodpecker_killed_pipeline_with_nonzero_failure_is_failure(self):
+        check_config = {
+            "required": True,
+        branch = {"name": "master", "label": "master"}
+        pipeline = {
+            "number": 6874,
+            "event": "push",
+            "branch": "master",
+            "ref": "refs/heads/master",
+            "commit": "f" * 40,
+            "workflows": [
+                    "pid": 1,
+                    "name": "tools",
+                    "children": [{"pid": 4, "name": "build", "state": "failure", "exit_code": 2}],
+        self.assertEqual(CI_STATUS.FAILURE, result["status"])
+        self.assertEqual("failed: tools (build)", result["message"])
     def test_woodpecker_running_workflows_are_summarized(self):
         check_config = {
Summary of changes:
 utils/docs/ci_status/report.py     | 48 +++++++++++++++++++++----
 utils/docs/tests/test_ci_status.py | 72 +++++++++++++++++++++++++++++++++++++-
 2 files changed, 112 insertions(+), 8 deletions(-)
hooks/post-receive
