[SCM] PostGIS branch master updated. 3.7.0beta2-7-g8c59690f6
git at osgeo.org
git at osgeo.org
Mon Aug 10 01:29:49 PDT 2026
the project "PostGIS".
via 8c59690f60446d9659a254dc99c3d59103169a99 (commit)
via 912cc17d85274a76a8a28d616c8249999c1250db (commit)
from 10b5cd9534f6a436a73af191a367ed6e8be7155f (commit)
revisions in full, below.
commit 8c59690f60446d9659a254dc99c3d59103169a99
Merge: 10b5cd953 912cc17d8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Aug 10 01:29:48 2026 -0700
Merge pull request 'Document split-component backpatching' (!708) from Komzpa/postgis:docs/backpatch-pre-split-components-20260810 into master
Reworks the maintainer backpatching checklist so it stays focused on
backpatch-specific decisions and links to the docs that own adjacent workflow
rules.
The updated page keeps the branch-sweep guidance concise, removes stale
branch-range examples and generic pull-request prose, and links out for commit,
branch, metadata, project-inventory, and testing details.
It also documents the parts that are easy to miss:
* a complete backpatch sweep must inspect the split component repositories
listed in the project inventory;
* the sweep must include backpatchable fixes from component history, not only
commits already copied into the PostGIS tree;
* old stable branches need small in-tree ports that match their branch layout,
generated SQL state, build rules, and test semantics;
* component-only packaging, CI, release, and layout changes stay in the
component repository;
* separate source fixes should stay separate in the target branch; do not squash
unrelated component commits into one broad backpatch commit only because they
were found in one sweep;
* target commits should use the source author when they are mainly a manual port
of one source commit, and `Co-authored-by` should name only people who helped
write that target commit.
Validation:
* `git diff --check upstream/master...HEAD`
* scoped file gate: only `doc/development/maintenance/backpatching.md`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/708
commit 912cc17d85274a76a8a28d616c8249999c1250db
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 10 01:44:30 2026 +0400
diff --git a/doc/development/maintenance/backpatching.md b/doc/development/maintenance/backpatching.md
index 4531fdc19..446e86b64 100644
--- a/doc/development/maintenance/backpatching.md
+++ b/doc/development/maintenance/backpatching.md
@@ -5,202 +5,124 @@ weight: 20
geekdocHidden: false
-Backpatching keeps supported release lines consistent without turning stable
-branches into feature branches. Use this checklist when a bug fix, release-line
-CI fix, or security fix may need to move between `master` and supported
-`stable-*` branches.
+Use this checklist to propagate bug fixes between `master` and supported
+`stable-*` branches. For general branch, commit, and authorship rules, see
+[Commit and branch guidelines](commit-guidelines.md). For pull request labels,
+milestones, and draft state, see
+[Pull request metadata](pull-request-metadata.md).
-## Supported Branch Set
+## Select Target Branches
-Start from the active support window. At the time of writing, the supported
-branch set is `master` through `stable-3.2`. Exclude end-of-life branches unless
-the release manager explicitly asks for an exceptional backpatch.
+Determine the current support window from the release state. Fetch the
+canonical OSGeo Gitea branches, then inspect `Version.config` and the top
+`NEWS` section on each candidate branch. Do not backpatch to an end-of-life
+branch without release-manager approval.
-Confirm the current branch state before editing:
+Check open pull requests before preparing a branch. An existing pull request
+may already contain all or part of the same fix lineage.
-* fetch the canonical OSGeo Gitea repository;
-* inspect `Version.config` and the top `NEWS` section on each target branch;
-* check for existing open pull requests that already carry part of the same
- backpatch lineage.
+## Scan In Both Directions
-GitHub pull requests are review surfaces. The canonical source branch remains
-the OSGeo Gitea branch.
+First scan from older branches towards newer branches. Compare adjacent release
+lines to find fixes committed directly to an older stable branch but missing
+from a newer branch or `master`.
-## Pull Request Family Shape
+Then scan from newer branches towards older supported branches. For each fix,
+continue until the first branch where the bug or affected code does not exist.
+Do not introduce a feature or a new API only to make a fix apply to an older
+release.
-Keep one pull request per target branch in a backpatch family: one common
-`master` pull request when the lineage still needs `master` work, plus one pull
-request for each supported `stable-*` branch that needs the fix. If several
-`master`-only follow-ups are found while repairing the family, fold them into
-the common `master` pull request instead of opening separate `master` pull
-requests by subtopic.
+Classify candidates by behavior, not by commit or pull request ranges. Include
+fixes for runtime correctness, crashes, security, installation, upgrades,
+packaging, supported builds, and user-facing documentation. Exclude version
+bumps, release preparation, translations, refactoring, and feature work unless
+they contain a distinct backpatchable fix.
-Cross-link the common `master` pull request and the stable pull requests in
-their bodies. When a subtopic is intentionally `master`-only, say that in the
-stable pull-request bodies instead of creating a second `master` lane.
+Before porting a fix, check the target branch's capabilities. Relevant
+differences may include:
-## First Pass: Older Fixes Missing From Newer Branches
+* C and SQL APIs, function signatures, and generated tables;
+* build targets and dependency versions;
+* extension objects and upgrade paths;
+* regression fixtures and expected semantics.
-Before pushing changes from new branches to old branches, scan in the opposite
-direction. A fix may have been committed directly to an older stable branch and
-missed `master` or a newer stable line.
+Stop when the affected behavior is absent or the fix would require unsupported
+infrastructure. Record the reason in the pull request or maintainer handoff.
-Compare adjacent branches:
+## Inspect Split Component Repositories
-* `stable-3.6` not in `master`
-* `stable-3.5` not in `stable-3.6`
-* `stable-3.4` not in `stable-3.5`
-* `stable-3.3` not in `stable-3.4`
-* `stable-3.2` not in `stable-3.3`
+A backpatch sweep must inspect relevant split component repositories, even when
+the report or pull request names only the PostGIS tree. Use the repository links
+in the [PostGIS project inventory](../governance/project-inventory.md). Review
+component commits, pull requests, release notes, and tests for the same bug and
+for follow-up fixes. Do not limit the sweep to commits already present in the
+PostGIS repository.
-Classify only real fix candidates: runtime correctness, crashes, security,
-packaging, install or upgrade behavior, release-line CI blockers, and
-user-facing documentation corrections. Ignore release-prep commits, version
-bumps, translation churn, broad refactors, and feature work unless they expose a
-missing regression test or `NEWS` entry for a real bug fix.
+For new work, use the component repository. When a supported stable branch
+still contains that component in the PostGIS tree, port the applicable fix to
+the branch's in-tree source:
-If an older branch contains a real fix that still applies to `master`, open a
-pull request to `master` first. If `master` has already fixed the same bug by a
-different implementation, consider whether the regression test or `NEWS` entry
-is still missing before opening a code PR.
+* `address_standardizer` uses `extensions/address_standardizer/`;
+* `postgis_tiger_geocoder` uses `extras/tiger_geocoder/`.
-## Second Pass: Newer To Older
+Inspect the target branch's files, build rules, generated data, loader scripts,
+and regression targets before editing. Carry only the code fix and tests that
+fit that branch. Leave component-only packaging, CI, release, and repository
+layout changes in the component repository.
-After the upward scan, walk from newer branches to older supported branches.
-For each fix lineage, cherry-pick or port the fix until reaching the first older
-branch that does not have the affected bug.
+If the fix changes generated or year-specific SQL, use the target branch's
+generation path when it exists and produces a focused change. Otherwise update
+the stored SQL directly and keep the diff limited to the affected behavior.
-Stop when the affected code path, SQL function, extension object, build target,
-or regression test does not exist on the older branch. Do not backport a new
-feature only to make a bug fix fit an older release line.
+Adapt tests to the target branch's public behavior. Do not copy expected output
+for functions or cases that the branch does not support.
-Backport by branch capability, not by pull-request number range. For each
-source hunk, check that the target branch has the same API surface and test
-contract before carrying it over:
+## Preserve Provenance
-* C enum values, pixel types, version macros, and generated lookup tables;
-* SQL wrappers versus C functions with planner support hooks;
-* function signatures, default arguments, and sentinel values;
-* build-system variables and recursive `make` entry points;
-* supported PostgreSQL and dependency versions in CI;
-* regression-test fixtures and expected output semantics.
-Do not backpatch fuzzer harnesses, seed corpora, OSS-Fuzz input-target
-plumbing, or fuzzer-only CI repairs to stable branches unless that exact stable
-branch runs the fuzzer target. In the normal PostGIS branch layout, fuzzer
-target work is `master`-only; stable branches should receive the runtime fix and
-any ordinary regression coverage that exercises shipped code, not the fuzzer
-driver used to find or smoke-test it.
-If a source test only proves behavior introduced on newer branches, omit or
-adapt that subtest on older branches. Keep the regression that protects the
-portable bug fix, but do not force an expected row only because it appeared in
-the newer branch. A missing expected row means: first inspect the SQL query and
-the target branch's function semantics, then decide whether the code or the
-test is non-portable.
-Record the stop reason in the pull request or maintainer handoff, for example:
-```text
-Stops at stable-3.3 because stable-3.2 does not have CG_AlphaShape.
-## Commit Shape And Provenance
-Prefer one source commit to one target commit. Clean cherry-picks should use
-`git cherry-pick -x` so the source commit hash is preserved.
-When cherry-picking a commit that is already a cherry-pick, keep only the
-provenance that helps reviewers trace the backpatch. Avoid stacking repeated
-`(cherry picked from commit ...)` lines mechanically; collapse noisy duplicate
-trailers into one clear source commit, or use a `Ported-from:` line for a manual
-port.
-When a clean cherry-pick is not possible, make the smallest faithful port and
-record the source in the commit body:
+Prefer one source commit per target commit. Use `git cherry-pick -x` for a clean
+cherry-pick. For a manual port, record the source commit in the commit body, for
+example:
```text
Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/<sha>
-If several source commits were iterative attempts to fix one bug, it is fine to
-collapse them into a smaller, correct target series. Do not collapse unrelated
-fixes into one commit, and do not rewrite public PR history only to hide later
-CI follow-up commits. Once a branch has been pushed for review, append focused
-follow-up commits for target-branch CI issues unless the maintainer explicitly
-asks for a rewrite.
+Keep separate source fixes separate in the target branch. Do not squash
+unrelated component commits into one broad backpatch commit only because they
+were found in the same sweep. If a target commit is mainly a manual port of one
+source commit, use that source commit's author. Add `Co-authored-by` trailers
+only for people who helped write that target commit.
-Use source-commit subjects where they remain accurate. If the target branch API
-or file layout differs, adjust the subject to describe the target-branch fix
-while keeping the `Ported-from:` line.
+If several source commits are attempts at one fix, they may be reduced to a
+smaller correct series. Follow [Commit and branch guidelines](commit-guidelines.md)
+for subjects, tracker references, and authorship.
-## NEWS
+## Update NEWS
-Assume a backpatch-worthy fix needs `NEWS` on every branch where it lands,
-including `master`, unless investigation shows it is purely internal and not
-release-note-worthy. A `NEWS` entry should describe the user-visible bug or
-supported build behavior, not the branch archaeology.
+Inspect the top `NEWS` section on every target branch. Add an entry when the fix
+is user-visible, release-note-worthy, security-relevant, or tracked as a bug.
+Use the target branch's current release section and existing heading style.
+Describe the fixed behavior, not the branch history.
-Put the entry under the top release section for the target branch and match that
-branch's existing heading style. Use:
+Keep wording consistent across branches, but adjust details that differ by
+release line. Follow [Commit and branch guidelines](commit-guidelines.md) for
+tracker notation and contributor credit.
-* `#NNNN` for Trac tickets;
-* `GH-NNN` for GitHub pull requests only inside `NEWS`;
-* `GT-NNN` for Gitea pull requests only inside `NEWS`.
+## Validate Each Port
-When a bug fix has no existing ticket, use concise user-facing wording and the
-contributor name if the surrounding section uses contributor credits.
-## Tests And Validation
-Every code backpatch should carry a regression test when a focused test is
-practical. For test-output drift caused by newer dependencies, make the test
-less brittle when possible instead of only replacing expected output with one
-machine's result.
-Before pushing a backpatch PR, run at least:
+Run validation on each target branch; success on the source branch is not
+evidence for the port. At minimum, run:
* `git diff --check`;
-* syntax or build smoke relevant to the touched files;
-* the focused regression target when the target branch can realistically run in
- the local environment.
+* the relevant build or syntax check;
+* the focused regression target when the branch and local environment support
+ it;
+* the repository's `NEWS` checks when `NEWS` changes.
-If local validation is not practical, state the exact blocker in the pull
-request. After pushing, read back the PR head SHA and CI state. The goal is a
-mergeable, green PR. If CI finds target-branch-only drift or harness breakage,
-fix it in the same PR when it belongs to making that backpatch mergeable.
+Use [Testing and debugging](../testing/_index.md) for build and regression
+commands. If a focused test cannot run, state the exact blocker and the
+validation that was completed.
-## Existing Backpatch Pull Requests
-Before creating a new PR, check open stable-branch pull requests. Preserve an
-existing PR when it is clean and correctly scoped. Supersede or repair it only
-when it has the wrong base, misses commits from the same lineage, lacks `NEWS`
-or tests, has misleading public text, or has conflicts that are cleaner to fix
-by replacing the branch.
-Do not fold unrelated master feature PRs into the backpatch sweep merely because
-they are open. Include only stable-base PRs, clear backpatch PRs, and PRs that
-the branch comparison proves are part of the fix lineage.
-## Pull Request Body
-The PR body should let reviewers trace the fix without reading local notes.
-Include:
-* the source commit or commits, preferably as OSGeo Gitea URLs;
-* the target branch;
-* whether the change was a clean cherry-pick, manual port, or collapsed fix
- series;
-* validation that was run, and any validation that was not practical;
-* any stop reason for older branches.
-For ticketed fixes, include a concrete Trac follow-up line for the oldest branch
-that will contain the fix after merge:
-```text
-After merge: update https://trac.osgeo.org/postgis/ticket/6081 fixed version to 3.5.7.
-Use the target branch's next release version from `Version.config` and `NEWS`.
-If the same ticket lands on several branches, the follow-up should name the
-oldest supported release that contains the fix.
+The pull request or handoff should identify the source commit, whether the
+change is a cherry-pick or manual port, validation performed, and the stop
+reason for any older branch that was considered but not changed.
Summary of changes:
doc/development/maintenance/backpatching.md | 266 ++++++++++------------------
1 file changed, 94 insertions(+), 172 deletions(-)
hooks/post-receive
